- z; L( w1 n5 ~: g5 u8 j
Inrush current, input surge current, or switch-on surge is the maximal instantaneous input current drawn by an electrical device when first turned on.
5 ]9 u7 g) P M4 |& r, a8 H5 i% J( Z: K4 {; z& x8 C
The main cause is the current was used to charge into capacitors.5 N' k1 o U# Y' y+ A
To reduce this problem, I often don't use a TVS. Instead I always use a inrush current limit circuit like this:6 y: v$ z- z3 g+ f& A, G
* l7 f2 F5 w: h: o0 k$ e+ q% N) w
9 F; l! i; r& v1 y4 @* w
8 E2 z8 O9 o N- G
6 Y0 Z, s- U% O4 n4 H4 |8 V0 EFor detail infos and how it work, please read attached document.
( M: V) B- E" h
1 w1 N$ C4 x5 j3 |" g& T6 P |
