查看: 4955|回复: 2
Part name R403 not found
发表于 2009-7-15 19:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
元件封装属性都对应上了,为什么发送网表到LAYOUT  EC0 检查时会丢失元件呢??谢谢!!
/ r( c9 r/ g4 A* c& B4 [Line 47 , Section *NET*
; N( [% z& p: K0 V. z) bC402.1  TC402.1  U402.2  R406.2
( U4 g9 s4 M' N. [9 G1 |* j* Part name C402 not found) q) b9 i1 H+ }6 u  N" b
* Part name U402 not found
: C0 E5 S) ]% f! I; y; B8 s* Part name R406 not found
1 b  {$ w& {( k& ~+ K- ^. E5 g' ELine 49 , Section *NET*
1 L2 T: d8 T8 e5 OQ401.1  R403.2
2 Q. p6 s4 E% v9 m$ g* Part name Q401 not found, m0 Y; d  h" d6 \6 @
* Part name R403 not found6 M6 [* V8 E6 D
Line 51 , Section *NET*
  Q. p1 O) o0 u/ KC404.2  Q401.3
: C1 |8 O" m1 I! \* Part name C404 not found5 m# j1 G& j1 H
* Part name Q401 not found' o$ i; p% A/ T$ B. i
Line 53 , Section *NET*
$ I+ T. o' j8 w% {* Q, X6 @U3.1  U4.1  Q401.2  C405.2  C406.25 M  W0 Y, F! w2 o/ q" T. c
* Part name Q401 not found  }: i5 }- O; ~4 o, l
* Part name C405 not found7 j$ F$ t- |, p% A) H  x4 u- @
* Part name C406 not found
8 b% O5 J+ ?; x- C2 cLine 55 , Section *NET*1 r: Y. v! N6 ~1 K" b7 W
C405.1  R401.1  U3.2
) J3 w: R" e3 l8 @" R2 O- G2 [* Part name C405 not found" T2 {; S0 o0 a  [* l! V: w6 P
* Part name R401 not found
2 C# A# d  [  f" v$ n8 \. h$ sLine 57 , Section *NET*
+ L( |# e, m# |6 `C406.1  R402.1  U4.2  i7 \2 D& z# N- i+ i, ~
* Part name C406 not found5 b# `  _8 Q# h" W6 p8 u
* Part name R402 not found+ V0 G- b2 `4 v2 a% G  _: l
Line 59 , Section *NET*
% }4 Z9 F* Q" `) L; y% tC401.1  TC401.1  L401.2  U401.60 R/ V! c% X" N; D& o
* Part name C401 not found
% l9 B5 N; Y/ O" k" X  aLine 61 , Section *NET** j" f+ {1 o* A+ |: s$ v+ `# u4 [
U401.18  C401.2  TC401.28 }$ }4 m& V& h3 k- K6 C' c
* Part name C401 not found. H9 a0 u5 l4 O: C+ Y0 \% Q
Line 79 , Section *NET*
% V6 e1 G  s8 s( ~R404.1  U402.1  C403.2  C402.2  TC402.2  XS401.36 v8 Z+ l3 }5 `( _
* Part name R404 not found
, W; z: E% V0 t  p4 D/ G* Part name U402 not found
: G! \; r3 H( d( }8 m. a: Z$ p* Part name C403 not found
4 _5 n- G  f8 K6 ]5 P! @* Part name C402 not found
) z  e  v" m5 d+ k, bLine 81 , Section *NET*
* O- L+ W) M2 _: O3 t) e5 HXS401.1  C403.1  R405.2  U402.30 E) e! ]4 N/ y  ?# L, Z
2 j7 n, t1 j- l* Part name R405 not found+ K. _5 I+ {% M: n
* Part name U402 not found- d* M; Q% W" o5 }0 V3 A
Line 85 , Section *NET*, ~9 ^# S* z% {' ?$ X1 ~6 Q1 O+ U$ m
3 l6 o+ t- `( H/ [/ Y0 {4 {+ \
  r3 U4 Z+ a- }; V" T! O% E3 S+ d& I+ j5 }0 u, ?
3 d) c7 t$ C( x2 j$ ?# G* F0 c- c5 _* k: [4 s4 _4 t' d, x& b( m
CB Net List Errors Report - default.sch - Wed Jul 15 19:17:47 2009
/ G; ]2 I( m1 k  W% K8 n. l--------------------------------------------------------------------
: f' ~! B/ T8 K- jDesign to Library Part Consistency Check
" O% w- `0 f5 r; g5 ~* }----------------------------------------
3 B' a. z4 r/ tNo Library consistency checking errors.
/ P/ q  {' D5 ^! Q/ H0 e; q/ }) xSingle/Zero Pin Net Warnings1 J# ?3 t0 h8 }# p
----------------------------6 P$ S! V. X: t, Q$ j. m5 `4 p
No single or zero pin nets.
5 e; A2 Z$ O1 x( J2 KSchematic Connectivity Errors
  [# N- |( w1 L: G) F-----------------------------" z7 ^4 }- O1 e+ }/ l
Dangling Connections with a Net Name
发表于 2009-7-16 08:34 | 只看该作者
R403等器件的封装没有对应上。
发表于 2009-9-6 18:06 | 只看该作者
2# jimmy 好想是说你的元件热03在元件库中找不到。
GMT+8, 2025-9-21 18:52 , Processed in 0.109375 second(s), 24 queries , Gzip On.
