查看: 1806|回复: 5
大家进来看看,帮个忙好吗?
发表于 2009-7-21 09:46 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
---- Photoplot outline rectangle not found ... using drawing extents
* q5 V! v; y6 Z. ~1 i
/ r. o; f# o/ y7 e* D( e8 BResults from parameter file ...3 [% P& @: t( ^1 m
    DEVICE-TYPE           GERBER_RS274X/ x) ?# K; j9 K& x, t
    OUTPUT-UNITS          INCHES0 `. z( y, y9 S; k( x- ^
    FILM-SIZE             2400000 1600000
) R; q: w. j" W8 \0 a/ ~3 f8 Q( m    FORMAT                2.5& t: B0 j! X' @& G  ?. J" w
    ABORT-ON-ERROR        NO
1 j: T: P6 p; J    SCALE                 1. \- E, O: R: V, b2 c+ l
    SUPPRESS-LEAD-ZEROES  YES
$ Q6 a# H7 m1 b4 m6 |. c9 ]8 V    SUPPRESS-TRAIL-ZEROES NO
1 q3 [7 n* O6 Z8 |$ w1 D2 W    SUPPRESS-EQUAL        NO; p, z! e+ R, G2 m
    UNDEF-APT-CONT        NO  {3 c! ]. K( e. ?. s: c: v
3 y0 E$ S1 z, ?* @
================================================================  |' F+ p  U" C5 F! R3 s
     PROCESSING FILM < POWER >3 @2 d9 r" Y! r( p
     TO FILE < E:/test-layer4/test-layer4/testpcb/POWER.art > ...' R+ s6 V: n2 P2 z' _
================================================================" X, U: L3 z4 g: Z8 ^* k3 G$ [
  FILM PARAMETERS :
$ q/ j1 v! M. j/ Z1 ~+ I% N  ---------------------------------------------------------
; e! a3 q: w+ T  Undefined line width                6.0
  D( {4 @& ]0 q% d* J$ e) R' G  Mirror code                         NONE4 j4 S7 f: q) t# h$ v+ t
  Rotate angle                        NONE
4 c( O. |" c8 c3 u  Offset x:                           0.0
; K' ~; N" y- c+ C4 e9 p  Offset y:                           0.0; B2 T+ s8 I9 L. N+ B5 L' W) P
  Plot negative                       YES
! e8 |! `4 M3 e7 l  Suppress unconnected internal pads  NO2 M7 g4 |3 k, e4 [8 \: x  u
    ERROR:  Layer polarity of class ETCH subclass POWER does not- J8 v- G* F/ \( K% n2 h  D
              match film polarity of Negative.  DRC may be unreliable.9 X+ E2 G) S9 t) F
    WARNING: 0 width line found at (0.0 0.0)
# D# q+ j  v, p/ _1 y! Q           ... using undefined line width of 6.0
3 k2 D* I- {1 j, {  x% n- E# x, d- X
    ERROR: aborting film - Shape with first seg=(10.1 10.1) [layer=POWER]" B- z# z$ \5 R- ^# J* w
has a void with extents [(5474.7 106.1) (5724.9 256.3)] that touches
5 \7 D+ J8 M( O' i another shape with first seg=(10.1 10.1). Manually resolve problem.; k# }% \2 d& z! }
    ERROR: aborting film - artwork will not be generated!
, {: f5 U5 v+ v+ O Error in POWER--halting output.  Artwork file not generated.
4 u4 X2 z, @5 m, z+ U7 o *** ERROR with POWER/ w: L3 t/ @. L$ {# `2 n" a% L
* @' B# R0 p' V3 }
+ F5 O1 m# n/ B- `
------------------------------------------------------/ y- {' E. j/ p1 K0 @: g+ F8 I3 H) S2 I
SUMMARY:; I. V- u, R/ |8 s7 b5 S- H. ]
2 J  E. T. N; K( b ARTWORK Error
发表于 2009-7-21 09:58 | 只看该作者
问题在这里:ERROR: aborting film - Shape with first seg=(10.1 10.1) [layer=POWER]
& F# N* d" K9 Y! i. X! W- A: `. p' C: K1 G. [EDA设计师论坛 has a void with extents [(5474.7 106.1) (5724.9 256.3)] that touches& ~' E3 D9 f9 N) u
8 ]6 m- C: {: T4 j$ q5 h  w6 XEDA设计师论坛 another shape with first seg=(10.1 10.1). Manually resolve problem.4 k0 @+ v  N+ F# O5 @
/ P+ M& e$ s  F! Y' A你看一下是否有挖掉的铜,修一下边试试
发表于 2009-7-21 16:28 | 只看该作者
你的check动作做完没
发表于 2009-8-9 15:32 | 只看该作者
我也出现这个问题,找不到原因。
 楼主| 发表于 2009-8-10 17:46 | 只看该作者
呵呵,解决了
发表于 2011-12-12 18:29 | 只看该作者
power层有两个bound连接到一起了,去掉一个再重新画上一个应该就可以了,注意两个bound不要连接在一起。
GMT+8, 2025-7-27 16:04 , Processed in 0.125000 second(s), 24 queries , Gzip On.
