我用另一个老文件导入就没问题,新建一个板框就出问题。高手看看。
$ [( H5 q/ F+ W( L
+ p1 |, k) |8 R! c8 l
; S0 I' p6 [( t( ?' p- j0 w#1 ERROR(305) Device/Symbol check error detected.
" V' E3 d+ o0 X2 @9 H4 k, }
/ r5 t' Y# w0 Z3 f( ^- vUnable to load symbol 'USB5PIN_MINI_BOT' for device 'USBCONNB_1_USB5PIN_MINI_BOT_USB': Couldn't find padstack: T_RD37X37D37NP
# y% ^. p2 u) g0 Z8 d2 v; j9 o due to Unable to load Flash symbol 47.) g/ O6 Q, C: e; t& Q4 M
, p& q& D: v. z7 U#2 ERROR(305) Device/Symbol check error detected.( h) q, M& C% O0 f0 i
6 b- u3 b# H( o# _; X, A, jUnable to load symbol 'TF-CARD' for device 'TF_0_TF-CARD_TF': Couldn't find padstack: PAD40CIR40U! [7 J- `) J$ N0 V. D
due to Unable to load Flash symbol 70.
# t4 t" N( ~. q# V! C7 @$ M. l. p( d! d3 o, D
#3 ERROR(305) Device/Symbol check error detected.3 O- R( u+ n0 N+ b# h
6 P8 \8 I1 Q t" ~9 q' w& F3 w9 fUnable to load symbol 'HOLD' for device 'HOLD_0_HOLD_HOLD': Couldn't find padstack: PAD36CIR36U, ], p! A. ^! O& A! S1 B' ~ B
due to Unable to load Flash symbol 66.# z/ {* v4 u+ P- z3 J& `7 C" K
) g$ N$ q% z: a' E#4 ERROR(305) Device/Symbol check error detected.' j9 D M, a3 V
, P; w1 z" m& a2 nUnable to load symbol 'K-4' for device 'K-4_K-4_K-4': Couldn't find padstack: PAD24CIR24D
& I$ c! P$ Z( A6 P due to Unable to load Flash symbol 54.
$ z2 v- S! {8 U" f" P: p
5 Z2 n, f& g4 C" \#5 ERROR(305) Device/Symbol check error detected.
. t7 x, C# z( A) Y) F
* C0 I9 J. [5 T0 Z' k/ uUnable to load symbol 'TSOP_54' for device 'SDRAM-1M-16-4_3_TSOP_54_SDRAM': Couldn't find padstack: PAD2
/ a2 J% l8 A/ Q/ V due to Unable to load Flash symbol PAD2. |
