查看: 4795|回复: 2
请教:oracd DRC检查没有错误但不能生成网表!
发表于 2009-8-30 18:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大佬:
9 r5 M9 K" [: j1 S/ X; v* I9 X; l* o, p) Y" R! z  M* s) ^2 ~+ i
我是新手,我用orcad画完原理图,drc检查没有错误,但就是不能生成网表,请教:谢谢!
9 l5 _' M- I0 i* I- }7 p2 z8 J9 @& f6 J
log:
0 g; S# S: t' s' V# x/ W* e  T# x  I, d- d3 C
4 q6 C; X4 n% u. A
Loading... C:\Documents and Settings\Administrator.ASUSTEK-4295C4C\桌面\sch\allegro/pstchip.dat
7 Q9 r  I- M7 }. H3 W' Z3 `$ H7 J#72 ERROR(SPCODD-72): A mismatch in the number of sections occurred on line 1701 while parsing logical pins.7 D: S) b0 S" O. o: t
        To avoid such errors, use Part Developer instead of manually editing the library part definition
. ~8 \9 }1 e/ \0 U              ERROR(SPCODD-47): File ./allegro/pstchip.dat could not be loaded, and the packaging operation did not complete. Check the pxl.log file for the errors causing this situation and package the design again.
+ w. {( `0 ^; `. S/ c#53 ERROR(SPCODD-53): Packaging cannot be completed because packaging has encountered a null object ID. The design may not have been saved correctly. Save the schematic and rerun packaging.
, p* O  h6 x# [. h: w, m#21 Error   [ALG0036] Unable to read logical netlist data.
发表于 2009-8-30 19:59 | 只看该作者
中文路径
 楼主| 发表于 2009-8-31 12:53 | 只看该作者
我改成全英文路径也是提示错误,一样de错误log,呜,
GMT+8, 2025-10-12 00:04 , Processed in 0.125000 second(s), 24 queries , Gzip On.
