我在用pads2007自带的translator软件转protel99se的文件时,转出来后元器件的封装不对,如:在protel99se里面R0603的封装在pads2007里面变成了R0603/2,这是怎么回事呢?4 }, S7 V6 t! A* u! G! V
下面是在转出来的警告:& Y# {9 t+ Y' |$ e9 w
[W] Renamed pins with duplicate names: 2 in device SOT223 renamed 2/25
% c3 b2 w' o/ H8 v[W] Renamed pins with duplicate names: 2 in device SOT223 renamed 2/26
* [4 v! X; u' ^[W] Renamed symbols with the same pattern: R0805 renamed R0805/44 m, W" q( f5 I9 F8 g6 `
[W] Renamed symbols with the same pattern: CAP0.7 renamed CAP0.7/21 ~ { d7 u: P
[W] Renamed symbols with the same pattern: CAP0.4 renamed CAP0.4/2
' ^# Y8 X, C3 o4 k[W] Renamed symbols with the same pattern: C0603 renamed C0603/2
/ c/ w6 `1 i: H+ F9 D9 s[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/26 _0 a7 s3 j$ K! b2 h# o; g
[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/3
: ?( V8 e) h" V9 n8 w/ K[W] Renamed symbols with the same pattern: R0603 renamed R0603/4: }' v2 W' G! z- P: c) _: W3 t
[W] Renamed symbols with the same pattern: SOT223 renamed SOT223/2
9 v7 P( C5 F0 U( h[W] Renamed symbols with the same pattern: C0603 renamed C0603/3
3 E1 p& q; [" G4 J7 l[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/4
0 U. z5 H' ^" m8 Z7 U" U7 m+ F; G
]$ I. E: n0 F, n/ n+ I# T等等 |
