查看: 1488|回复: 0
pads2007自带translator软件在转protel99se时的问题
发表于 2009-9-1 16:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我在用pads2007自带的translator软件转protel99se的文件时,转出来后元器件的封装不对,如:在protel99se里面R0603的封装在pads2007里面变成了R0603/2,这是怎么回事呢?
' w' g. v: l' N4 \- k下面是在转出来的警告:
# U% ?1 e$ T" [' R7 a/ ]0 Z[W] Renamed pins with duplicate names: 2 in device SOT223 renamed 2/256 ?/ `; S- a2 ?9 v- M  O
[W] Renamed pins with duplicate names: 2 in device SOT223 renamed 2/26
3 j! s+ K" j$ g; H7 ]2 P[W] Renamed symbols with the same pattern: R0805 renamed R0805/43 z1 @+ T' p7 P5 g+ W' Y5 `& C  t
[W] Renamed symbols with the same pattern: CAP0.7 renamed CAP0.7/26 u. @/ J& R4 f6 v
[W] Renamed symbols with the same pattern: CAP0.4 renamed CAP0.4/2
+ e0 z; B$ r( V/ o& N[W] Renamed symbols with the same pattern: C0603 renamed C0603/2
$ E1 D3 h# C& X3 l( Z[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/2# ]7 C3 k# c5 b4 c% _5 \
[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/3: f% P6 S4 A% Y0 v; v
[W] Renamed symbols with the same pattern: R0603 renamed R0603/4+ e0 f( t& Y, s
[W] Renamed symbols with the same pattern: SOT223 renamed SOT223/2
6 S6 E* H3 a$ _& H  G[W] Renamed symbols with the same pattern: C0603 renamed C0603/3
2 @( S2 A% H3 S- x- j" I[W] Renamed symbols with the same pattern: CAP0.8 renamed CAP0.8/4
" L2 y: e' P# A: l& p6 [
& I( }! G* K1 G1 G等等.是不是软件的问题呢?附件为protel中Examples里面的pcb文件,转出来后封装有些就不对了,有知道的吗?
, D, J* M2 J1 @- F9 Q, u
PCB Benchmark 94.rar
1.31 MB, 下载次数: 45, 下载积分: 威望 -5
GMT+8, 2025-9-21 18:51 , Processed in 0.140625 second(s), 27 queries , Gzip On.
