查看: 4673|回复: 1
PADS报错Bad CONNECTION
发表于 2009-9-14 17:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
新手,呵呵。报错如下,是哪里错了?封装?发送到Layout,少了很多元件。
( t" B! \% W- G- W& Q; ]Reading file --  D:\pads\PADS Projects\padsnet.asc0 i- E# V) U6 `5 ?+ T& ?/ B" ~
1 Z  t7 _1 `, r8 o4 D/ S
Reading file --  D:\PADS\PADS Projects\padsnet.asc, F* B! S- q' e# a. d) p$ r
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$6016. p! j+ h6 o1 g
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$10194- r* C' k; N$ f. `! B
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal NCEO, ?& G1 U6 |+ [# D/ E
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSEL0
- \6 W+ k5 F+ }& Z7 Y; j5 S*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal 6
# ]1 G  g' ^, I# E, B*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal 9
7 D( f/ y8 K3 _  l6 ]*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSEL1
8 @4 p3 t6 p$ G5 E" a*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal 133 k4 x2 k+ Q+ D% \7 n
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$246185 `1 b3 U; Z7 g/ x. R/ Q2 [
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSEL2! A; N0 d- i* z1 L/ I! h! ?+ }
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal 18
0 M' I) s) R( H7 i6 G) L*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$12745 ascii data format, nets must contain more than one pin. Signal $$$6016
: D/ S/ W- a4 w* `*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$10194
2 t  I7 c3 W  O) I0 H: w*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal NCEO" `3 o2 e! \* z4 f# G$ d
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSEL01 ?# U4 [% Z4 G
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal 6, H# V+ v5 H1 |6 j/ R& J' U7 e
7 L8 x: S& V" G; A- `*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSEL1
" v, o1 \$ H" ?4 B3 i( ]7 {. f*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal 13
& j, p% E1 u3 O5 S% S" s' g*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$24618
2 O+ v+ l  G. v% _; s*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal MSEL20 S+ m7 `% B- p/ m( y3 W5 ^0 t
7 ~' S! i/ _, e( p  P*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal $$$12745
发表于 2009-9-16 11:32 | 只看该作者
单端网络,还有网络的字符有点问题·不能带空格,*号,%,& ,#
GMT+8, 2025-9-21 20:19 , Processed in 0.125000 second(s), 24 queries , Gzip On.
