查看: 245|回复: 1
这是arm的最简单的点阵LED代码,但是却有很奇怪的现象,请大神帮忙看看
发表于 2019-12-30 13:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
加上".data"后bin文件居然有33kb不加".data"有1kb,程序无反映,代码是在Linux交叉编译链汇编的
.equ GPX2CON,0x11000C40
8 T5 G% y, X. n4 Z.equ GPX2DAT,0x11000C44: l8 i/ s9 p) R- m  \- ]5 N
.TEXT
( i; g9 _, W- O7 c$ `main:3 W/ s. @# @; K2 E. G3 V
bl Init_Port+ m4 z2 G, i9 M
loop:
6 h$ \, k/ O1 }( ~$ ]* b9 L& @' X- k+ Y6 Q
ldr r2,=map+4 @点亮led1
  I4 n0 h2 d  q( D. P% Q3 w0 ^ldr r6,[r2]" b1 P6 |: k$ Z1 b" H
mov r7,#0xff
0 l/ l9 o% w. s% Q$ c/ r+ }( Astr r7,[r6]
! y# e8 \* S) M9 `5 R0 I# u: z1 ]+ q
6 F$ s# a, }) Y2 z# h( \7 ^* W4 Mbl delay1s& g# D3 s# l" {+ R& q" Q
ldr r2,=map+4 @no点亮led11 @( M5 D2 v1 l
ldr r7,[r2]9 S8 `/ F0 U' e7 U3 R% C" K' s
mov r3,#0x00
5 R: c) d. v$ |% J0 R( Q' R7 tstr r3,[r7]& J, F% l/ {% d9 B! g, {& n6 c
b loop
2 \# L# f  s$ \5 d: ]main_end:
: u2 z( z: U4 {8 E6 N$ K3 Q, T' fb main_end: ?0 Y7 p, P/ c
" y! _1 H5 m( R# @. d@ 延时1 E" u$ V! e6 B5 _. ]! V; r
@------------------------------------------------5 {( o! u/ l& g4 X0 K" O. X& \4 j
1 K. J2 L& k# D+ B6 b
delay1s:: s9 S0 k7 ~/ ~9 Z5 d
ldr r4,=0x5ffffff4 e# ?; {' {+ r: M: E! O
. x* ~; ~/ t1 x3 e- y- P, o8 N/ Q3 edelay1s_loop:6 r9 p! P3 ~5 n, v! y3 R
sub r4,r4,#1
  h: ]6 c% ?2 S5 e* Ccmp r4,#0' i2 w- E+ |1 ]/ j' v5 {6 F
: M2 G/ u9 K# z$ Y0 k6 z6 ^5 tbne delay1s_loop) Z! p9 g; {5 G5 e
mov pc,lr   z$ }4 B: x, ?
0 R, d" i" ?' R" r@ Map& G) q: J1 g1 M( T- W( t" h
* ?) G% i( i6 l. I+ D1 x' b3 r' W; ^, H7 p! E( @, U
.data
- a; F2 e) O; m) Kmap:
' S3 L+ ]8 U) i2 `6 `) |.word GPX2CON,GPX2DAT. @' w0 V0 ~  T# u" b7 b" \2 H, B
@------------------------------------------------8 ~# {6 e( N2 Q$ x& X3 g. C) {3 z4 w
@ 端口配置
" O4 a: E; b" F@------------------------------------------------
1 F% m- n1 C! z/ N, c# [( LInit_Port:& u' N3 V& {0 F: {' k2 H
ldr r0,=map @LED1配置
3 Y0 y! {, g1 B! qLDR R2,[R0]7 e4 t# r* B% D  g
LDR R1,[R2]/ d" P2 q/ J8 k6 Q: G
AND R1,#0X0FFFFFFF
8 o7 _8 ?* X4 K% }0 _$ NORR R1,#0X100000007 J2 u' I4 j  ?4 S- Z: \. d# S
str r1,[r2]. b# c: E% b9 `5 u7 U- j+ m% Q
Init_Port_end:
0 e, Z+ B3 I& T. x9 j: ^8 Pmov pc,lr
  V/ J3 G& Z* C1 x# Z: Q* d. D.END
5 y3 J. I( n2 K0 Z% Z
发表于 2019-12-30 13:54 | 只看该作者
1111111111111111111111111111111111111111111
GMT+8, 2025-9-24 02:26 , Processed in 0.109375 second(s), 23 queries , Gzip On.
