查看: 1455|回复: 16
[allegro16.3][6层]1GspsADCfmc卡(ADS54JXX+LMK04828+SMVT)原理图和pcb文件
发表于 2019-12-31 17:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
$ e) |3 O5 ~# w5 F& \% l( ][allegro16.3][6层]1GspsADCfmc卡(ADS54JXX+LMK04828+SMVT)原理图和pcb文件  Z$ ~% f( |7 N
  [5 @+ C, h# p9 R, [3 q( Q3 R" ?
文件描述:* s# n: v4 M6 F$ a
$ k! h$ Z. j# F3 a# ^0 d/ e
1. 作品用途:1GspsADCfmc卡
, F1 p: v) J; x- @2. 软件版本:allegro16.36 N0 i- U5 R! h" j, e
3. 层数:6层! B. @  u/ J5 \3 |8 V  ?' G" s5 G+ M
4. 用到的主要芯片:ADS54JXX+LMK04828+SMVT- s0 o* T8 p6 G7 p$ V2 B4 U
5. pcb尺寸:5350*2700  MIL
& d; K3 P' \- `9 j% {7 U( D# {5 t7 T" y
作品截图如下:- }$ P+ e/ X8 M1 z# K# C8 e
+ B  b! C) e( V# Q3 D% `# z5 n- |
顶层截图:2 u/ W% Q3 W( K6 ], `. D  [
( i( N, z4 g0 w" }; H# \" Y5 P
底层截图:+ _% L3 |/ z, Z/ N( Y( `8 G: _3 T
% G# K8 H2 O5 V' h3 i* _, v5 `0 L# O# `
& E: l4 e& x, k全层截图:
7 G# D2 L0 N  z2 f/ j+ I; P3 m7 |) \) f( O$ n% z
' v  s# G3 \) l/ A5 D( c. m4 P叠层阻抗信息如下:
6 ^2 _, q! ]( q' G, k
- f4 N  h1 M& |. l6 j# `. hBOM:. M5 {6 c( V1 Y. `, [5 T/ e
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
201CAP_0201_0.1UF_0201_.1UF_10%.1uFIC16C28; C29; C30; C31; C32; C33; C34; C36; C37; C38; C39; C46; C48; C49; C50; C51
201CAP0402_0_0201_.1UF_10%_.1uFIC22C40; C41; C42; C43; C44; C45; C47; C52; C53; C54; C55; C56; C57; C58; C59; C60; C61; C62; C66; C67; C70; C71
201CAP0402_0_0201_.01UF_+/-10%_.01uFIC2C68; C69
201RES_0201_200_H_0201_100_1%100IC2R32; R34
402CAP_0603_0.1UF_H_0402_.1UF_10%.1uFIC8C1; C3; C6; C7; C12; C13; C14; C15
402CAP0402_1_0402_.1UF_10%_.1uFIC2C2; C16
402CAP0603_0402_.1UF_10%_.1uFIC4C4; C5; C10; C11
402CAP_0402_1UF_0402_1UF1uFIC7C8; C105; C108; C112; C113; C114; C115
402CAP_0402_2PF_0402_2.0PF2.0pFIC2C9; C17
402CAP0402_0_0402_.1UF_10%_.1uFIC5C35; C64; C65; C72; C73
402CAP0603_0402_.1UF_10%.1uFIC1C74
402CAP NP_0_0402_.1UF_10%_.1uFIC3C75; C119; C122
402CAP NP_0_0402_.68UF_5%_.68uFIC1C76
402CAP NP_0_0402_47PF_1%_47pFIC1C77
402CAP NP_0_0402_3900PF_5%_3900pFIC1C78
402CAPACITOR_NP_1_0402_.1UF_10%.1uFIC13C79; C80; C82; C83; C84; C86; C87; C88; C93; C95; C97; C117; C118
402CAP_0402_0.1UF_H_0402_.1UF_10%.1uFIC3C81; C89; C90
402CAP NP_0_0402_.1UF_10%__1.1uFIC1C91
402CAP_0402_2200PF_H_0402_2200PF2200pFIC1C96
402CAP_0402_10PF_H_0402_10PF10pFIC1C98
402CAPACITOR_NP_1_0402_1UF_1uFIC2C99; C102
402CAPACITOR_NP_1_0402_.01UF_10%.01uFIC7C101; C104; C106; C107; C109; C110; C111
402CAP NP_1_0402_1UF_1uFIC1C116
402CAP0603_0402_DISCRETE_47PF_1%47pFDISCRETE2C120; C121
402RES0603_0402_24.9_.1%_24.9IC4R1; R13; R16; R24
402RES_0201_H_0402_4.99_1%_4.99IC4R2; R5; R17; R25
402RES_0603_ZERO_H_DNI_0402_00IC6R3; R4; R7; R10; R21; R22
402RES_0402_ZERO_H_0402_00IC6R6; R8; R38; R39; R41; R119
402RES_0402_ZERO_0402_00IC5R9; R14; R20; R23; R54
402RES0603_0402_0_1%_0IC2R11; R18
402R_0402_0_5%0IC2R12; R19
402R_1_0402_DISCRETE_1K_1%_1KDISCRETE1R27
402RES0603_0402_1K_1%1KIC3R28; R30; R31
402R_1_0402_DISCRETE_620_1%_620DISCRETE1R36
402R_1_0402_DISCRETE_39K_1%_39KDISCRETE1R37
402RES_0402_100_H_0402_100100IC2R40; R48
402RES_0402_49.9_0402_49.9_1%49.9IC3R42; R49; R51
402RES_0402_249_0402_240240IC4R43; R44; R46; R47
402RES_0402_ZERO_H_DNI_0402_00IC2R45; R55
402RES_0402_2.1K_0402_2.1K2.1KIC1R56
402RES_0402_ZERO_DNI_0402_00IC1R57
402RES_0603_100K_0402_100100IC1R58
402RES_0402_48.7K_0402_48.7K48.7KIC1R59
402RES_0402_4.75K_0402_4.75K4.75KIC2R60; R61
402RES_0402_ZERO_H_0402_22.122.1IC3R65; R69; R70
402RES_0402_1K_0402_1K_1%1KIC1R74
402RES_0402_10K_H_0402_10K10KIC2R120; R121
603CAP NP_0_0603_.01UF_5%_.01uFIC16C63; C147; C148; C149; C158; C159; C160; C171; C172; C173; C182; C183; C184; C193; C194; C195
603CAP_0603_100PF_H_0603_100PF100pFIC2C85; C92
603CAP NP_2_0603_DISCRETE_10UF_10%10uFDISCRETE3C94; C138; C162
603CAP_0603_22UF_0603_22UF22uFIC2C139; C163
603CAP_0603_0.1UF_0603_0.1UF0.1uFIC5C141; C152; C165; C176; C187
603CAP NP_0_0603_1UF__1uFIC5C142; C153; C166; C177; C188
603CAP NP_1_0603_1UF_1uFIC5C146; C157; C170; C181; C192
603RESISTOR_0_0603_DISCRETE_750_750DISCRETE3R50; R52; R53
603RES_0603_ZERO_DNI_0603_00IC1R63
603R_0603_0_5%0IC2R68; R110
603RES_0603_47.5K_0603_47.5K47.5KIC5R78; R88; R95; R105; R112
603RES_0603_590K_0603_590K590KIC1R80
603RES_0603_162K_0603_162K162KIC2R81; R98
603RES_0603_ZERO_H_DNI_0603_00IC4R82; R85; R89; R92
603RES_0603_ZERO_H_0603_00IC8R83; R84; R86; R87; R90; R91; R93; R94
603RES_0603_301K_0603_301K301KIC1R96
603R_0603_0_0IC10R99; R102; R104; R106; R109; R111; R113; R114; R115; R117
603R_0603_0_1%0IC7R100; R101; R103; R107; R108; R116; R118
805CAP NP_1_0805_10UF_10%10uFIC11C126; C140; C150; C151; C161; C164; C174; C175; C185; C186; C196
805CAP0201_0_0805_10UF_20%_10uFIC5C145; C156; C169; C180; C191
1206CAP NP_0_1206_47UF_20%47uFIC5C143; C154; C167; C178; C189
1206FUSE_0_1206_FUSE 10A 63V FASTFUSE 10A 63V FASTIC1F1
1206FERRITE_BEAD_0402_H_1206_120 OH120 OHM @ 100MHzIC16FB1; FB2; FB3; FB4; FB5; FB6; FB7; FB8; FB9; FB10; FB11; FB13; FB14; FB15; FB16; FB17
1806FERRITE_BEAD_0402_H_1806_1K OHM1K OHM @ 100MHzIC1FB12
3528CAPACITOR POL_0_3528_10UF_20%_10uFIC2C100; C103
CON_RAPC722_JACK_THVT_3CONN JACK PWR_CON_RAPC722_JACK_CONN, JACK, PWR, MINI, R/A, THIC1J9
CON_SMRT_USBMNE20_FUSB_MINI_AB_MNE20-5G5P10_CON_SMCONN, USB MINI AB, SMTIC1J8
CON_SMVT_40X10_SEAM_MTGCON_SMVT_40X10_ASP-134487-01_COCON, SMVT, HS, FIELD ARRAY, 400POS, MALEIC1J7
DBV5TPS2400_DBV5_TPS2400TPS2400IC1U10
JUMPER_SMD_L_0603JUMPER_SMD_L_0603_JUMPER_SMD_L_JUMPER_L_0603_SMTIC2SJP1; SJP3
JUMPER_SMT_1X2_0603JUMPER_SMD_1X2_JUMPER_SMT_1X2_0SOLDER JUMPER, 0603IC1SJP2
LED_1206LED_LED_1206_LED GREENLED GREENIC3D1; D2; D3
LED_1206LED_GREEN_0_LED_1206_LED GREENLED GREENIC1D4
MFG125_PLATEDMOUNTING_HOLE_MFG125_PLATED_STASTANDOFF, FEMALE, 4-40 X 1 3/16", ALIC2MT1; MT2
MOSFET_8_2MMX2MM_0P65PWR_MOSFET_CSD17313Q2_MOSFET_8_CSD17313Q2IC1Q1
PROBE_POINT_30PADPROBE_POINT_0_PROBE_POINT_30PADPROBE POINTIC1PP1
QFN_10_81X61_RSESN65LVDS4_QFN_10_81X61_RSE_SN65SN65LVDS4IC1U5
QFN_64_360X360_0P50MM_PWRPADLMK04828_0_QFN_64_360X360_0P50MLMK04828IC1U4
QFN_72_10MMX10MM_0P50MM_PWRPADADS54J60_72QFN_QFN_72_10MMX10MMADS54JXXIC1U3
SMA_SMEL_DUAL_PSF-S01_250X215SMA-END_PLUG_ROUND_SMA_SMEL_DUACONN, SMA, JACK, 50 OHM, EDGE MNTIC5J1; J2; J3; J4; J5
SMA_THVT_312X312SMA-THVT_142-0701-201_REC_SMA_TCONN, SMA, JACK, 50 OHM, THVTIC1J6
SO_8_207X207_5024C65_SO_8_207X207_50_24C6524C65IC1U14
SSOP_28_413X220_26FT245RL_SSOP_28_413X220_26_FT24FT245RLIC1U7
SW_SMVT_SPST_EVQPJX_2SPST_EVQ-PJ_0_SW_SMVT_SPST_EVQPSWITCH, SMT, PUSHBUTTON, SPSTIC1SW1
TANT_BCAP POL-B_0_TANT_B_47UF_10%_47uFIC1C125
TANT_BCAP POL-B_0_TANT_B_33UF_10%_33uFIC5C144; C155; C168; C179; C190
TESTPOINT_62DRILL_THMTESTPOINT_BLK_TESTPOINT_62DRILLBLKIC6TP1; TP2; TP3; TP4; TP5; TP6
TESTPOINT_62DRILL_THMTESTPOINT_RED_TESTPOINT_62DRILLREDIC6TP7; TP8; TP9; TP10; TP11; TP12
TFMR_6_310X280_100_BH292ADT4-1T_0_TFMR_6_310X280_100_BHJTX-2-10TA+IC1T2
TFMR_6_RF_DUAL_FOOTPRINTXFMR_6_ADT2-1T+_TFMR_6_RF_DUAL_ADT1-1WT+IC4T1; T3; T4; T5
TP_THVT_100_RNDTESTPOINT_BLUE_TP_THVT_100_RND_BLUIC4TP13; TP14; TP15; TP16
USIL_8_3MMX2P8MM_0P65MMTPS82085_USIL_8_3MMX2P8MM_0P65MTPS82085IC2U2; U11
VCXO_6_CUSTOMOSC_SM_6_TCO-2100-SERIES_2_VCXO122.88MHzIC1Y1
VQFN_14_138X138_0P50_RGYTXS0104E_VQFN_VQFN_14_138X138_0TXB0104IC1U6
VQFN_20_138X138_0P50_RGRTPS7A8300_VQFN_20_138X138_0P50_TPS7A8300IC5U1; U8; U9; U12; U13
附件:0 g* \) }* S* ^# c: C3 r
原理图和PCB文件如下:
( k& p" s! H  I; ^
游客,如果您要查看本帖隐藏内容请回复
  R3 g5 z8 ~1 G, S& C- B& R5 _' m; r9 t4 ^- F/ P
    慵懒
    2022-8-22 15:56
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    推荐
    发表于 2025-6-20 09:51 | 只看该作者
    谢谢分享,学习一下! n8 H% l- X# i- c. ~- U) {
    奋斗
    2025-9-29 15:41
  • 签到天数: 144 天
    [LV.7]常住居民III
    推荐
    发表于 2023-9-6 12:04 | 只看该作者
    不错,感谢楼主分享.
    推荐
    发表于 2023-9-5 09:03 | 只看该作者
    感谢分享,学习学习
    2021-10-7 15:37
  • 签到天数: 44 天
    [LV.5]常住居民I
    发表于 2020-4-15 18:23 | 只看该作者
    谢谢楼主的分享
    “来自电巢APP”
    发表于 2020-5-24 06:42 | 只看该作者
    开发板么
    “来自电巢APP”
    2024-8-26 15:16
    发表于 2020-5-24 10:34 | 只看该作者
    非常感谢分享资料
    / S+ D8 c- g) p6 z& b1 G" R! E
    发表于 2020-6-25 22:19 | 只看该作者
    非常感谢分享资料
    发表于 2022-6-22 18:26 | 只看该作者
    学习一下,谢谢!
    2024-2-21 15:59
  • 签到天数: 313 天
    [LV.8]以坛为家I
    谢谢楼主的分享
    2024-10-29 15:07
  • 签到天数: 94 天
    [LV.6]常住居民II
    发表于 2022-11-16 16:04 | 只看该作者
    感谢大佬分享 看看
    2025-9-5 15:25
  • 签到天数: 8 天
    [LV.3]偶尔看看II
    13#
    发表于 2022-11-29 10:26 | 只看该作者
    非常感谢楼主分享
    - [3 R9 h9 k  I$ a  r/ f1 a4 N0 H. }
    14#
    发表于 2023-2-3 10:23 | 只看该作者
    谢谢楼主分享
    ' _$ b; i) i! S3 @' x
    2025-10-10 15:06
  • 签到天数: 593 天
    [LV.9]以坛为家II
    15#
    发表于 2023-2-4 16:49 | 只看该作者
    看看,欣赏一下
    慵懒
    2025-7-3 15:03
    16#
    发表于 2025-4-23 20:22 | 只看该作者
    学习一下,谢谢!  D$ y1 N. r; H0 P2 _
    GMT+8, 2025-10-12 08:59 , Processed in 0.171875 second(s), 29 queries , Gzip On.
