作品名:[AD 10][2层] 车载主板(ST72321+RS2313M+TDA7384)PCB源文件
% e( \4 F( K( o: ]6 T2 W2 F! h
3 M8 K G1 D: t$ K+ Q+ T x文件描述
3 I2 t8 J7 h/ J8 J1. 作品用途:车载主板
0 [" S( ], \* O: e l2 r0 N2. 软件版本:AD 10
# Y# ]1 {$ E3 q6 j8 r3. 层数:2层板
4 n6 c$ ]! j; E# [+ s4. 用到的主要芯片:ST72321+RS2313M+TDA7384) R; c4 r8 ^5 D
5. PCB尺寸:170mm*164mm/ D3 n; s3 f& z, ~: b
) j4 V9 x( v; {8 D, T作品截图如下:+ X$ S N3 k" o9 e7 E
顶层截图:
x, H- D/ X3 n2 n0 k+ |1 |. E" {
' \, {3 R( n9 j6 [. W# p底层截图:
# Z/ P. d6 a6 \% |8 g
; K6 ]# Y. z5 H+ _% i9 m0 v
全层截图:$ N+ J8 K4 y, U
/ c( s$ B; T2 D" E
叠层信息截图如下:" k, Y8 m* s* X- a& v
% U7 P5 N9 v6 o- WBOM:
# W) X% J4 l0 i- `" A- S- _9 bComment(属性) | Designator(位号) | Footprint(封装) | Quantity(数量) | 104 | C01, C1, C3, C04, C4, C5, C6, C7, C8, C010, C10, C11, C12, C15, C51, C53, C54, C55, C56, C73, C74, C75, C76, C77, C78, C101, C102, C103, C104, C106, C108, C114, C115, C116, C119, C204, C205, C207, C301, C311, C313, C315, C316, C325, C328, C410, C601, C602, C603, C604, C605, C608, C610, C611, C630, C631, C632 | C0603 | 57 | 105 | C02, C03, E312 | C0603 | 3 | 105 | C05, C06, E307, E308, E309, E310 | C0805 | 6 | 152 | C71, C72, C413, C414 | C0603 | 4 | 102 | C109, C317, C318, C319, C320, C321, C322, C323, C324 | C0603 | 9 | 22P | C110, C111 | C0603 | 2 | 103 | C112, C113 | C0603 | 2 | | C280, C281, C401, C404, C405, C406 | C0603 | 6 | 150p | C303, C304, C305, C306 | C0603 | 4 | 223 | C411, C412 | C0603 | 2 | | CE401 | E D型 | 1 | 8PIN | CN1, CN303, CN304 | CN8(2.0) | 3 | DIP10 | CN101 | DIP10 | 1 | CON16 | CN301 | ISO3 | 1 | ANT | CN401 | 2PIN | 1 | 2P2.5L | CN602 | 2PIN | 1 | CON30 | CON100, CON102 | CN30(0.5) | 2 | 4148 | D1, D2, D3, D5, D8, D12, D51, D52, D58, D103, D105 | D0805 | 11 | IN4001 | D4, D9, D10, D11, D13, D14, D50, D601, D602, D603 | SMD5822 | 10 | IN5408 | D301 | D-600 | 1 | IN4148 | D304, D305, D306, D307 | D0805 | 4 | 6.2V | D310, ZD103, ZD601 | D0805 | 3 | 10UF/16V | E1 | CAP 6.3*7 | 1 | 47U/10V | E01, E9, E10, E15, E17, E18, E19 | E D型 | 7 | 47uF/10v | E02 | e-b | 1 | 100U/16V | E3, E4, E16, E51, E53, E55, E101, E102, E327, E410, E601, E603, E608, E609, E610 | E D型 | 15 | 100/16V | E5 | 100U/10V | 1 | 1000/16V | E6, E8 | CAP 11*18 | 2 | 10U | E7, E103, E605, E606 | E-B | 4 | 100U/16V | E11 | CAP 6.3*7 | 1 | 220/16V | E12 | CAP 6.3*7 | 1 | 1000UF/25V | E13 | CAP 11*18 | 1 | 47UF/16V | E14, E415, E416 | E D型 | 3 | 10U/16V | E54, E280 | e-b | 2 | 22U/16V | E71 | E D型 | 1 | 2U2/16V | E72, E715 | E-B | 2 | 10U/16V | E73, E75 | C0805 | 2 | 225 | E74, E076, E76, E077, E77, E78, E79, E710, E711, E714 | C0805 | 10 | 10UF/6.3V | E208 | E-B | 1 | 100UF/10V | E209 | CAP 6.3*7 | 1 | 10U | E301, E302, E303, E304, E314, E315, E316, E317 | C0805 | 8 | 2200U/16V | E311 | CAP 13.5*25 | 1 | 100UF/16V | E313 | CAP 6.3*7 | 1 | | E413, E414 | E-B | 2 | 100UF/10V | E417, E418 | E D型 | 2 | 100UF/16V | E712 | E D型 | 1 | | IC401 | SOL-16 | 1 | SONY-BT | J01 | SONY-BT-DIP | 1 | GPS.CON | J02 | DSW-1-13 | 1 | 50PIN | J4 | CN50(0.5) | 1 | CON12 | J098 | CN12(1.0) | 1 | CON14 | J099 | DIP14(2.54) | 1 | 150UH/3A | L1, L8 | CDH125/100UH1AA | 2 | 100UH | L2 | BCR63B | 1 | FB-310 | L3, L51 | L1206 | 2 | FB-220 | L4 | L1206 | 1 | FB-221 | L5 | L1206 | 1 | FB310 | L7 | L1206 | 1 | 33UH | L52 | L1206 | 1 | 10UH | L601 | L1206 | 1 | 8550 | Q01, Q6, Q8, Q13, Q308, Q604, Q605, Q631 | SOT-23 | 8 | C103 | Q1, Q002, Q3, Q11, Q12, Q305, Q309, Q502, Q602, Q608, Q609, Q630 | SOT-23 | 12 | 8050 | Q2, Q102 | SOT-23 | 2 | 1664 | Q4 | SOT-89 | 1 | 8550 | Q9 | SOT-231 | 1 | BA1424 | Q201, Q613 | SOT-89 | 2 | DTC343 | Q301, Q302, Q303, Q304 | SOT-23 | 4 | NTS9435 | Q412 | SOP-8 | 1 | 15P05 | Q606, Q607 | SOT-252 | 2 | 2SC3879 | Q612 | SOT-89 | 1 | 10R | R01, R02, R622, R623 | R1206 | 4 | 33K | R1, R307, R308, R309, R310 | R0603 | 5 | 0R | R2, R12, R35, R105, R127, R190, R191, R358, R359, R378 | R0603 | 10 | 1.5K | R002, R11, R19, R610, R611 | R0603 | 5 | 2.2R | R3 | R1206 | 1 | 10K | R03, R04, R4, R05, R06, R6, R07, R08, R09, R010, R011, R16, R31, R32, R33, R37, R54, R61, R71, R72, R78, R79, R101, R103, R111, R115, R116, R117, R118, R119, R123, R124, R211, R301, R302, R303, R304, R336, R343, R362, R363, R423, R424, R607, R608, R609, R619, R620, R633 | R0603 | 49 | 1K8 | R5 | R0805 | 1 | 3K3 | R7, R8, R40, R41, R192, R346, R347, R348, R349 | R0603 | 9 | 1K | R9, R10, R26, R43, R44, R51, R74, R75, R102, R107, R110, R212, R280, R281, R385, R602, R604, R605, R632 | R0603 | 19 | 33R | R012, R013, R014, R015, R016, R017, R018 | R0603 | 7 | 220K | R13 | R0603 | 1 | | R17, R50, R407, R413 | R0603 | 4 | 47R | R20, R313, R314, R316, R317 | R0603 | 5 | 220R | R020, R099, R136, R137, R379, R480 | R0603 | 6 | 5.6K | R27 | R0603 | 1 | 100R | R28, R364, R365, R366, R367, R376, R377, R437, R654, R800, R801 | R0603 | 11 | NC | R39, R368 | R0603 | 2 | 75R | R45, R46, R52, R285 | R0603 | 4 | 100R | R47 | R0805 | 1 | 560R | R48, R433, R434, R625 | R0603 | 4 | 2K2 | R49, R353, R354, R355, R626, R630, R710, R711 | R0603 | 8 | 22R | R050, R803, R804 | R0603 | 3 | 4K7 | R53, R59 | R0603 | 2 | 220R | R55 | R1206 | 1 | 20K | R56 | R0603 | 1 | 12K | R57 | R0603 | 1 | 47K | R58, R120, R341, R342, R352, R617, R618, R631 | R0603 | 8 | 100K | R60, R125 | R0603 | 2 | 33R | R73 | R0805 | 1 | 22K | R76, R77, R320, R321, R322, R323, R337, R338, R339, R340, R401, R402, R403, R404 | R0603 | 14 | 4*10K | R129, R130, R131, R132, R133, R134, R135 | RP1206 | 7 | 1M | R138 | R0603 | 1 | 27K | R140 | R0603 | 1 | 470R | R143 | R0603 | 1 | 22R | R144, R145 | R1206 | 2 | 100R | R214 | R1206 | 1 | 4.7K | R282 | R0603 | 1 | 220 | R283, R284, R425 | R0603 | 3 | 104 | R326 | R0603 | 1 | 2.2K | R332, R333, R334, R335, R435, R436, R712, R713 | R0603 | 8 | 0 | R369 | R0603 | 1 | 330R | R370, R371 | R0603 | 2 | 470K | R372, R373 | R0603 | 2 | 3.3K | R426, R427, R428, R429 | R0603 | 4 | 500K | R481 | R0603 | 1 | 限流电阻500mA | R613 | R1812 | 1 | 4R7 | R615, R616 | R1206 | 2 | 5K6 | R715, R716 | R0603 | 2 | TP | TP | TP | 1 | TC-510 | TUNER401 | TC-510 | 1 | 78M05 | U01 | SOT-252-3 | 1 | KIA7029 | U1 | KIA7035(TO-92) | 1 | AP1507 ADJ | U2 | PQ1CZ41H | 1 | LMV-358 | U02 | SOP-8 | 1 | RT9164 33CG | U3, U51 | SOT-223 | 2 | AP1507 5.0 | U4 | PQ1CZ41H | 1 | 7805 | U5, U201, U602 | SOT-252-3 | 3 | NJM2235 | U6, U401 | SOP-8 | 2 | RT9164 1.8V | U50 | SOT-223 | 1 | RS2313M | U71 | SOL-28A | 1 | TC4052BF | U72 | SOP16 | 1 | 24C04 | U100 | SOP-8 | 1 | ST72321 | U101 | QFP64-10*10 | 1 | 74HC04 | U102 | 74HC04 | 1 | BA6287F | U103 | SOP-8 | 1 | FU8A05 | U280 | XF-6 | 1 | TDA7384 | U301 | TA8264AH | 1 | 4558 | U302, U303 | SOP-8 | 2 | 7809 | U601 | SOT-252-3 | 1 | 7808 | U603 | SOT-252-3 | 1 | | X401 | HC-49S | 1 | 8.0M | Y101 | HC-49S | 1 | 6V2 | ZD1 | D0805 | 1 | IN5822 | ZD2, ZD3 | SMD5822 | 2 | | ZD4 | D0805 | 1 | 10V | ZD5 | D0805 | 1 | 5.1V | ZD401 | D1206 | 1 | 9V1 | ZD607 | D0805 | 1 | 7V5 | ZD630 | D0805 | 1 | 附件:' i% l6 {! i; x9 S( g. Q
原理图和PCB源文件如下:& H$ q$ d9 s5 r3 }2 L
- h6 |9 v8 ]' n( e3 L9 o' B$ a/ l4 z" }: Q' @
