1. 作品用途:VS100RX+IP175D+H7019FNL+EP91H0 PCB
2. 软件版本:allegro16.6
3. 层数:6层
4. 用到的主要芯片:VS100RX+IP175D+H7019FNL+EP91H0
Bill of Material Report (Condensed) | | | | | |
SYM_NAME | COMP_DEVICE_TYPE | COMP_VALUE | COMP_CLASS | QUANTITY | REFDES |
名称 | 类型 | 属性 | 类别 | 数量 | 位号 |
5X7 | OSC8/SM_0_5X7_125MHZ CMOS | 125MHz CMOS | IC | 1 | X1 |
6X11 | CAPACITOR POL_6X11_NI_10UF/100V | NI_10uF/100V | IC | 1 | C500 |
402 | CAP NP_0402_100NF | 100nF | IC | 118 | C2; C3; C4; C5; C6; C7; C8; C9; C22; C23; C26; C29; C45; C46; C48; C49; C50; C51; C53; C54; C55; C56; C68; C69; C70; C71; C72; C73; C74; C75; C76; C77; C78; C79; C80; C81; C82; C83; C84; C85; C86; C87; C88; C89; C90; C91; C92; C93; C94; C95; C96; C97; C98; C99; C100; C101; C102; C103; C104; C105; C106; C107; C108; C109; C110; C111; C112; C113; C114; C115; C119; C122; C123; C124; C125; C126; C128; C129; C130; C131; C132; C133; C134; C135; C136; C140; C143; C144; C145; C146; C147; C148; C149; C150; C151; C152; C155; C158; C159; C163; C164; C165; C177; C502; C503; C505; C506; C507; C702; C801; C802; C808; C809; C811; C812; C813; C815; C816 |
402 | CAP NP_0402_10NF/100V | 10nF/100V | IC | 2 | C14; C15 |
402 | CAP NP_0402_NI | NI | IC | 4 | C16; C17; C162; C178 |
402 | CAP NP_0402_10NF | 10nF | IC | 2 | C19; C21 |
402 | CAP NP_0402_390PF | 390pF | IC | 10 | C24; C25; C27; C28; C30; C31; C34; C35; C170; C171 |
402 | CAP NP_0402_15PF | 15pF | IC | 2 | C42; C43 |
402 | CAP NP_0402_470NF | 470nF | IC | 2 | C117; C137 |
402 | CAP NP_0402_1NF | 1nF | IC | 2 | C121; C141 |
402 | CAP NP_0402_3.3NF | 3.3nF | IC | 1 | C156 |
402 | CAP NP_0402_220PF | 220pF | IC | 1 | C160 |
402 | CAP NP_0402_33NF | 33nF | IC | 1 | C161 |
402 | CAP NP_0402_22NF | 22nF | IC | 1 | C179 |
402 | CAP NP_0402_NI_180PF | NI_180pF | IC | 1 | C803 |
402 | CAP NP_0402_100PF | 100pF | IC | 1 | C806 |
402 | R_0402_1K | 1K | IC | 31 | R1; R2; R5; R6; R7; R32; R35; R39; R40; R41; R42; R80; R109; R134; R508; R509; R510; R511; R512; R513; R514; R515; R516; R532; R806; R808; R809; R810; R819; R832; R837 |
402 | R_0402_49R9 | 49R9 | IC | 33 | R10; R11; R12; R13; R14; R15; R16; R17; R43; R44; R46; R47; R48; R49; R50; R51; R52; R53; R54; R55; R61; R62; R64; R65; R137; R138; R139; R140; R811; R812; R813; R814; R828 |
402 | R_0402_4.53K | 4.53K | IC | 1 | R18 |
402 | R_0402_NI | NI | IC | 21 | R19; R23; R75; R76; R77; R112; R115; R116; R119; R121; R123; R143; R144; R145; R147; R159; R160; R827; R830; R835; R836 |
402 | R_0402_75R | 75R | IC | 3 | R20; R22; R805 |
402 | R_0402_100R | 100R | IC | 2 | R21; R148 |
402 | R_0402_100K | 100K | IC | 7 | R24; R26; R129; R800; R801; R815; R817 |
402 | R_0402_4.02K | 4.02K | IC | 1 | R25 |
402 | R_0402_27K | 27K | IC | 1 | R27 |
402 | R_0402_1.62K | 1.62K | IC | 2 | R28; R29 |
402 | R_0402_402R | 402R | IC | 1 | R30 |
402 | R_0402_1.7K | 1.7K | IC | 2 | R31; R34 |
402 | R_0402_200R | 200R | IC | 1 | R33 |
402 | R_0402_0R | 0R | IC | 15 | R38; R69; R72; R73; R74; R85; R111; R113; R114; R118; R120; R122; R127; R133; R136 |
402 | R_0402_220R | 220R | IC | 9 | R45; R56; R86; R87; R88; R89; R90; R141; R142 |
402 | R_0402_4.7K | 4.7K | IC | 10 | R67; R68; R78; R79; R81; R92; R93; R94; R95; R96 |
402 | R_0402_NC | NC | IC | 1 | R82 |
402 | R_0402_6.19K | 6.19K | IC | 1 | R83 |
402 | R_0402_499R | 499R | IC | 3 | R91; R156; R157 |
402 | R_0402_20K | 20K | IC | 1 | R124 |
402 | R_0402_2.5K | 2.5K | IC | 1 | R126 |
402 | R_0402_10K | 10K | IC | 5 | R128; R821; R822; R829; R833 |
402 | R_0402_49.9K | 49.9K | IC | 2 | R130; R831 |
402 | R_0402_5K | 5K | IC | 2 | R131; R132 |
402 | R_0402_5.6K | 5.6K | IC | 1 | R135 |
402 | R_0402_2.49K | 2.49K | IC | 1 | R146 |
402 | R_0402_1.1K | 1.1K | IC | 1 | R158 |
402 | R_0402_NI_1K | NI_1K | IC | 2 | R523; R816 |
402 | R_0402_NI_392R | NI_392R | IC | 1 | R802 |
402 | R_0402_5R1 | 5R1 | IC | 2 | R803; R804 |
402 | R_0402_392R | 392R | IC | 1 | R807 |
402 | R_0402_33R | 33R | IC | 2 | R818; R834 |
402 | R_0402_39K | 39K | IC | 1 | R820 |
402 | R_0402_137R | 137R | IC | 1 | R838 |
603 | BEAD_0603_FERRITE 120R/2A | Ferrite 120R/2A | IC | 1 | B800 |
603 | TRISIL_BIDIR_0603_PGB1010603-MR | PGB1010603-MR | IC | 2 | ESD2; ESD3 |
603 | R_0603_100R | 100R | IC | 2 | R110; R117 |
603 | R_0603_10R | 10R | IC | 1 | R125 |
603 | R_0603_NI_0R | NI_0R | IC | 2 | R524; R525 |
603 | R_0603_NI | NI | IC | 4 | R528; R529; R530; R531 |
0603_LED | LED_0603_LED_LED | LED | IC | 8 | D5; D6; D7; D8; D9; D13; D14; D803 |
0603_LED | LED_0603_LED_NI_LED | NI_LED | IC | 1 | D22 |
805 | BEAD_0805_FERRITE 600R | Ferrite 600R | IC | 2 | B801; B802 |
805 | CAP NP_0805_4.7UF | 4.7uF | IC | 2 | C10; C11 |
805 | CAP NP_0805_2.2UF | 2.2uF | IC | 1 | C12 |
805 | CAP NP_0805_NI_100NF/63V | NI_100nF/63V | IC | 1 | C501 |
805 | CAP NP_0805_10UF | 10uF | IC | 3 | C800; C810; C814 |
805 | CAP NP_0805_1UF | 1uF | IC | 2 | C804; C805 |
805 | INDUCTOR_0805_BLM21PG600SN1 | BLM21PG600SN1 | IC | 1 | FB1 |
805 | INDUCTOR_0805_10UH | 10uH | IC | 2 | L1; L800 |
805 | R_0805_100R | 100R | IC | 1 | R155 |
1008 | 74479787210_1008_NI_74479787210 | NI_74479787210 | IC | 1 | FB3 |
1206 | CAP NP_1206_100NF/50V | 100nF/50V | IC | 3 | C13; C38; C39 |
1206 | CAP NP_1206_1NF/2KV | 1nF/2KV | IC | 1 | C18 |
1812 | CAP NP_1812_10NF/1.5KV | 10nF/1.5KV | IC | 2 | C700; C701 |
1812 | R_1812_NI | NI | IC | 2 | R825; R826 |
744273 | TRAN_HM33_0_744273_744273801 | 744273801 | IC | 1 | CM500 |
744273 | TRAN_HM33_0_744273_NI_744273801 | NI_744273801 | IC | 1 | CM501 |
AG6100-SIM | AG6100_AG6100-SIM_NI_AG6100 | NI_Ag6100 | IC | 1 | PSE1 |
AG9605-SIM | AG9605-2BR_AG9605-SIM_AG9605-2B | Ag9605-2BR | IC | 1 | PD1 |
BGA-268 | VS100-SNK_BGA-268_VS100RX | VS100RX | IC | 1 | U1 |
CASE-B | CAPACITOR POL_CASE-B_100UF | 100uF | IC | 13 | C1; C20; C44; C47; C52; C66; C120; C138; C142; C172; C504; C718; C807 |
CASE-B | CAP POL_CASE-B_100UF | 100uF | IC | 4 | C116; C127; C153; C154 |
CASE-B | CAP POL_CASE-B_22UF | 22uF | IC | 2 | C118; C139 |
CASE-B | CAP POL_CASE-B_47UF | 47uF | IC | 1 | C157 |
CASE-D | CAP POL_CASE-D_470UF | 470uF | IC | 2 | C67; C181 |
CON-HDMI-19 | HDMI_A_0_CON-HDMI-19_HDMI_A | HDMI_A | IC | 1 | J2 |
CONPWR | CONN JACK PWR_0_CONPWR_NI_PWR J | NI_PWR JACK | IC | 1 | J11 |
DIPSW8-SMD-M | SW DIP-8/SM_DIPSW8-SMD-M_SW DIP | SW DIP-8/SM | IC | 1 | SW500 |
DO1608C | INDUCTOR_DO1608C_NI | NI | IC | 4 | L622; L623; L624; L625 |
FIDUCIAL | HEADER 1_FIDUCIAL_FID | FID | IC | 8 | FD1; FD2; FD3; FD4; FD5; FD6; FD7; FD8 |
H7001NL_80MIL | H7001NL_H7001NL_80MIL_H7019FNL | H7019FNL | IC | 1 | TR1 |
HC49_US | CRYSTAL_HC49_US_25MHZ | 25MHZ | IC | 1 | Y1 |
HOLE43P | TEST POINT_HOLE43P_TP | TP | IC | 8 | TP9; TP10; TP11; TP12; TP13; TP14; TP15; TP800 |
IRM0101 | PL-IRM0101-3_IRM0101_PL-IRM0101 | PL-IRM0101-3 | IC | 1 | IR1 |
LEDIRTX | LED_1_LEDIRTX_NI_LED_IR | NI_LED_IR | IC | 1 | D801 |
LED_TH_90 | LED_0_LED_TH_90_LED | LED | IC | 4 | D1; D2; D3; D11 |
MH126P | TEST POINT_MH126P_MH | MH | IC | 4 | MH1; MH2; MH3; MH4 |
PQFP-128 | 175C_DEMO_MII_0_PQFP-128_IP175D | IP175D | IC | 1 | U8 |
QSOP-16 | MAX8505EEE_QSOP-16_MAX8505EEE | MAX8505EEE | IC | 1 | REG3 |
RCLAMP0524P | RCLAMP0524_0_RCLAMP0524P_RCLAMP | Rclamp0524 | IC | 5 | U3; U4; U6; U803; U804 |
RJ45X8_P | CONN RECT 8_0_RJ45X8_P_RJ45 | RJ45 | IC | 1 | J3 |
RJ00812 | RJ45_TRNS_0_RJ00812_RJ45_TRNS | RJ45_TRNS | IC | 1 | J6 |
SJ1-3515-SMT | PHONOJACK STEREO-15_2_SJ1-3515- | CONN 3.5MM SW | IC | 4 | J13; J501; J502; J503 |
SOIC-14 | EP91H0_SOP14_SOIC-14_EP91H0 | EP91H0 | IC | 1 | U801 |
SOIJ-SOIC-8 | 25LC512-I-SN_SOIJ-SOIC-8_M95M02 | M95M02-DRMN6TP | IC | 1 | U7 |
SON2X2-6-EP | TPS60151DRVT_SON2X2-6-EP_TPS601 | TPS60151DRVT | IC | 1 | U2 |
SOT23-5 | AD820/SO_0_SOT23-5_ADCMP600BRJZ | ADCMP600BRJZ | IC | 2 | U9; U800 |
SOT23-5 | NC7SZ14/SOT23_SOT23-5_NC7S14M5X | NC7S14M5X | IC | 2 | U11; U13 |
SOT23-5 | NC7S08/SOT23_0_SOT23-5_NC7SZ08M | NC7SZ08M5X | IC | 1 | U12 |
SOT23-5 | NC7SZ32/SOT23_0_SOT23-5_NC7SZ32 | NC7SZ32M5X | IC | 2 | U802; U806 |
SOT23-5 | NC7SZ384/SOT23_0_SOT23-5_NC7SZ1 | NC7SZ126M5X | IC | 1 | U805 |
SOT-23 | MMBT2907A/SOT_0_SOT-23_MMBT2907 | MMBT2907A | IC | 1 | Q2 |
SOT-23 | DS1818-10_SOT-23_DS1818-10 | DS1818-10 | IC | 1 | U5 |
SOT-23-SMALL | BAT54C/SOT_0_SOT-23-SMALL_BAT54 | BAT54C | IC | 4 | D4; D12; D800; D802 |
SOT-23-SMALL | MMBT2222A/SOT_2_SOT-23-SMALL_MM | MMBT2222A | IC | 1 | Q1 |
SWSM_IND | INDUCTOR_SWSM_IND_1UH/3A | 1uH/3A | IC | 3 | L6; L7; L611 |
TDFN-EP-10 | MAX1556ETB_TDFN-EP-10_MAX1556ET | MAX1556ETB | IC | 2 | REG1; REG2 |
TPSMD | T POINT S_TPSMD_TPSMD | TPSMD | IC | 12 | TP1; TP8; TP16; TP700; TP701; TP702; TP801; TP802; TP803; TP804; TP805; TP806 |
TSSOP-14 | 74HC74_0_TSSOP-14_MM74HC74AMTC | MM74HC74AMTC | IC | 1 | U807 |
TSSOP-16 | MAX3232_2_TSSOP-16_MAX3232CUE | MAX3232CUE | IC | 1 | U22 |
TSW-105 | HEADER 5X2_TSW-105_HEADER 5X2M | HEADER 5X2M | IC | 1 | J504 |
TSW-105-S | CONN RCPT 5_TSW-105-S_NI_HEADER | NI_HEADER 5 | IC | 1 | J500 |
VLF4012A | INDUCTOR_VLF4012A_3.3UH/1.2A | 3.3uH/1.2A | IC | 4 | L2; L3; L4; L5 |
