查看: 821|回复: 10
[allegro16.3][8层] SDI控制卡(XC6SLX45_75_3FGG484C+ADV7511+ADV7612)pcb文件
发表于 2020-2-10 18:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
! o: w3 s$ T9 y$ z% r& K% k; X
8 X# l( y/ Z, ?* [. q+ A  q
% c: w: s' O" B文件描述:
1 d+ M5 }9 w, }
9 ?4 w  f; ?& x) w$ ]: v3 d1. 作品用途:SDI控制卡4 e8 _, J$ \  O5 i# y2 [& G) m& o
2. 软件版本:allegro16.3
) |( m% B& W' `: i9 s3. 层数:8层4 T5 d; ?4 a! x& d# v
4. 用到的主要芯片:XC6SLX45_75_3FGG484C+ADV7511+ADV7612& }( U, ]5 a9 {$ M% J3 O
5. pcb尺寸:6318*5435 MIL
  @! N/ n% i2 W! b& q8 f. X- P. G4 g9 i0 C# m" V6 P# y
作品截图如下:
9 ?0 `. g8 {4 W* i5 N
. J+ H! ?" t; {% l5 I- s顶层截图:5 p- |) F( s$ ^4 u  k9 c0 a
  x) _' R8 q3 Q
底层截图:* y" c2 Z+ D  i  k
1 d  A3 `# X- y2 g7 _! Z
7 `, @; {. p2 ]+ U6 K& ^全层截图:( v/ l' R, l3 M3 u
- Y% T8 o! e' s: n( h
. K9 ^" p* Q4 t  ^" cBOM:. y( Q! M% W1 [: [$ v
Bill of Material Report (Condensed)
SYM_NAMECOMP_DEVICE_TYPECOMP_VALUECOMP_CLASSQUANTITYREFDES
名称类型属性类别数量位号
BNC_RACONBNC_3_BNC_RACON_BNCBNCIC3J28; J32; J33
BUTTON6X6SW4_0_BUTTON6X6_SW4SW4IC1SW1
BUTTON6X6SW4_BUTTON6X6_SW4SW4IC2SW2; SW3
C0402CAP NP_C0402_2.2UF2.2uFIC80C173; C174; C175; C176; C177; C178; C190; C191; C192; C195; C211; C212; C221; C222; C231; C236; C238; C246; C247; C345; C346; C347; C348; C349; C350; C351; C359; C360; C361; C362; C363; C364; C365; C366; C367; C368; C369; C370; C371; C372; C373; C374; C375; C376; C377; C378; C379; C380; C381; C382; C383; C384; C385; C386; C394; C395; C396; C397; C398; C399; C400; C402; C409; C410; C411; C412; C413; C414; C415; C416; C417; C418; C419; C420; C421; C422; C458; C459; C460; C461
C0402CAP NP_C0402_0.01UF0.01uFIC4C241; C242; C243; C245
CAPC2-138-320CAP POL_CAPC2-138-320_470UF470uFIC2C181; C322
CON2-1X2CON2_CON2-1X2_CON2CON2IC7J1; J2; J18; J19; J20; J24; J26
CON3-1X3CON3_CON3-1X3_CON3CON3IC4J23; J25; J34; J35
CON50_2CON50_CON50_2_CON50CON50IC2J13; J14
DC5VCONN JACK PWR_DC5V_CONN JACK PWCONN JACK PWRIC1J22
DIOM6959X26NDIODE SCHOTTKY_2_DIOM6959X26N_SSS34IC2D6; D9
DO-201ADDIODE SCHOTTKY_2_DO-201AD_1.5KA1.5KA6.8AIC1D7
FB2012X11NBEAD_FERRITE_SM_0_FB2012X11N_BLBLM21PG331SN1IC8L1; L2; L3; L13; L18; L20; L22; L23
FB2012X11NBEAD_FERRITE_SM_0_FB2012X11N_10100R/50mR/2AIC19L5; L6; L7; L8; L9; L10; L11; L17; L21; L24; L25; L26; L27; L28; L29; L30; L31; L32; L33
FGG484XC6SLX45_75_3FGG484C_FGG484_XC6XC6SLX45_75_3FGG484CIC1U55
FLYERCON2_FLYER_CON2CON2IC5P2; P3; P4; P5; P6
HDMI-19PFHDMI19FLANGE_3_HDMI-19PF_HDMI19HDMI19FLANGEIC1U58
HDMI-19PFHDMI19FLANGE_4_HDMI-19PF_HDMI19HDMI19FLANGEIC1U59
HDMI-19PFHDMI19FLANGE_5_HDMI-19PF_HDMI19HDMI19FLANGEIC1U60
IDC2X7-2M54HEADER 7X2_IDC2X7-2M54_HEADER 7HEADER 7X2IC3J29; J30; J31
INDM3225X15NINDUCTOR_0_INDM3225X15N_10UH10uHIC3F4; F6; F10
INDM3225X15NINDUCTOR_0_INDM3225X15N_6.8NH6.8nHIC3L34; L35; L36
INDM10090X54NINDUCTOR_0_INDM10090X54N_22UH22uHIC1L15
KB302168KB3021_0_KB302168_KB3021KB3021IC1U43
LEDC2012X120DIODE SCHOTTKY_2_LEDC2012X120_CCD4148IC1D1
LEDSMDLED_0_LEDSMD_LEDLEDIC10D2; D8; D11; D12; D13; D16; D17; D18; D19; D20
LEDSMDDIODE SCHOTTKY_2_LEDSMD_CD4148CD4148IC1D10
LQFP100ADV7511_LQFP100_ADV7511ADV7511IC1U56
LQFP100-PADADV7612_LQFP100-PAD_ADV7612ADV7612IC1U57
POWERCON2CON2_POWERCON2_CON2CON2IC1J17
RTCZTA_RTC_BATTERYBATTERYIC1Y1
SC0402CAP NP_SC0402_0.1UF0.1uFIC4C96; C146; C147; C148
SC0603CAP NP_SC0603_0.1UF0.1uFIC97C1; C3; C7; C9; C10; C11; C12; C13; C14; C15; C16; C17; C18; C19; C20; C21; C22; C23; C27; C37; C49; C50; C53; C54; C55; C56; C89; C90; C92; C93; C94; C95; C103; C110; C117; C124; C131; C138; C145; C150; C151; C152; C154; C158; C160; C161; C162; C164; C165; C169; C171; C180; C183; C188; C189; C198; C199; C203; C206; C210; C218; C219; C225; C226; C234; C235; C237; C251; C252; C253; C254; C267; C268; C274; C279; C287; C288; C292; C298; C299; C312; C314; C315; C354; C355; C388; C390; C393; C401; C430; C437; C444; C449; C450; C452; C455; C456
SC0603CAP NP_SC0603_0.01UF0.01uFIC114C5; C8; C25; C28; C29; C30; C31; C32; C35; C36; C38; C39; C42; C46; C51; C52; C57; C58; C61; C64; C65; C73; C76; C83; C84; C87; C88; C97; C98; C101; C102; C104; C105; C108; C109; C111; C112; C115; C116; C118; C119; C122; C123; C129; C136; C139; C140; C143; C156; C159; C167; C170; C182; C186; C187; C196; C197; C207; C208; C209; C216; C217; C220; C223; C224; C232; C233; C248; C249; C250; C270; C275; C277; C280; C283; C284; C285; C286; C294; C295; C296; C297; C310; C313; C323; C324; C325; C326; C327; C328; C329; C330; C335; C336; C337; C338; C339; C340; C341; C342; C343; C344; C405; C406; C424; C425; C428; C429; C431; C432; C435; C436; C438; C442
SC0603CAP NP_SC0603_DNPDNPIC1C71
SC0603CAP NP_SC0603_1UF1uFIC6C79; C80; C255; C256; C447; C448
SC0603CAP NP_SC0603_4.7UF4.7uFIC4C149; C172; C445; C446
SC0603CAP NP_SC0603_01UF01uFIC2C153; C163
SC0603CAPACITOR NON-POL_SC0603_0.1UF0.1uFIC8C258; C259; C260; C261; C262; C263; C264; C265
SC0603CAP NP_SC0603_27PF27pFIC2C281; C282
SC0603CAP_SC0603_0.1UF0.1uFIC5C301; C303; C307; C308; C454
SC0603CAP_SC0603_33NF33nFIC1C302
SC0603CAP_SC0603_18PF18pFIC4C304; C305; C316; C317
SC0603CAP NP_SC0603_33PF33pFIC80C356; C357; C389; C403; C404; C407; C408; C439; C443; C451; C453; C462; C463; C464; C465; C466; C467; C468; C469; C470; C471; C472; C473; C474; C475; C476; C477; C478; C479; C480; C481; C482; C483; C484; C485; C486; C487; C488; C489; C490; C491; C492; C493; C494; C495; C496; C497; C498; C499; C500; C501; C502; C503; C504; C505; C506; C507; C508; C509; C510; C511; C512; C513; C514; C515; C516; C517; C518; C519; C520; C521; C522; C523; C524; C525; C526; C527; C528; C529; C530
SC0603CAP NP_SC0603_33NF33nFIC1C423
SC0603CAP NP_SC0603_220PF220pFIC1C457
SD_PUSHSOCKET-SD_CARD_0_SD_PUSH_SD CARSD Card SocketIC1J21
SI570SI570 _SI570_SI570SI570IC1Y5
SI595SI595_SI595_SI595SI595IC1Y7
SO8EEPROM-I2C_SO8_24LC0024LC00IC3U40; U47; U50
SO8AT93C46-10_SO8_AT93C46DN-SH-BAT93C46DN-SH-BIC1U49
SOIC127P600X150-16MAX232_SOIC127P600X150-16_MAX32MAX3232IC2U42; U44
SOIC300DS1302_SOIC300_DS1302DS1302IC1U45
SOL16M25P64_SOL16_M25P64M25P64IC2U36; U51
SOP20-26-17374HC245ZY_SOP20-26-173_74HC245Z74HC245ZYIC10U6; U7; U13; U17; U20; U21; U24; U29; U32; U35
SOP86-20-400K4S643232E_SOP86-20-400_K4S6432K4S643232EIC1U41
SOT23DIODE SCHOTTKY_1_SOT23_MA3X704AMA3X704A0LIC1D14
SOT23-5DBVNC7SZ125_SOT23-5DBV_NC7SZ125NC7SZ125IC2U69; U71
SOT23-6DVIULC6_0_SOT23-6_DVIULC6DVIULC6IC29U8; U9; U10; U11; U12; U14; U15; U16; U18; U19; U22; U23; U25; U26; U27; U28; U30; U31; U33; U34; U52; U53; U54; U63; U64; U65; U66; U67; U68
SOT263-3AS2830_SOT263-3_AS2830AS2830IC4U1; U37; U38; U46
SOT263-7LM2678-ADJ_SOT263-7_LM2678-ADJLM2678-ADJIC1U39
SOT-23DIODE SCHOTTKY_0_SOT-23_MA3X704MA3X704A0LIC1D15
SOT-23BPW37/TO_SOT-23_DTD1132KDTD1132KIC4T1; T2; T3; T4
SPL0303BEAD_FERRITE_SM_0_SPL0303_BLM21BLM21PG331SN1IC1L12
SQA48ADS32ELX0421_SQA48A_DS32ELX0421DS32ELX0421IC1U61
SQA48ADS32ELX0124_SQA48A_DS32ELX0124DS32ELX0124IC1U62
SR0603RESISTOR/SM_0_SR0603_33R33RIC4R1; R6; R61; R89
SR0603RESISTOR/SM_0_SR0603_10K10KIC11R2; R4; R53; R110; R140; R141; R142; R143; R148; R149; R196
SR0603RESISTOR/SM_0_SR0603_1K1KIC5R3; R111; R112; R193; R194
SR0603RESISTOR/SM_0_SR0603_100R100RIC14R5; R8; R11; R15; R18; R32; R34; R35; R77; R78; R162; R166; R171; R175
SR0603RESISTOR/SM_0_SR0603_27K27KIC2R7; R126
SR0603RESISTOR/SM_0_SR0603_4.7K4.7KIC60R9; R10; R16; R17; R19; R20; R47; R56; R57; R58; R59; R60; R62; R64; R65; R66; R79; R80; R81; R82; R83; R84; R88; R90; R102; R103; R104; R105; R106; R130; R131; R144; R145; R146; R170; R186; R187; R188; R189; R190; R195; R209; R210; R211; R212; R213; R214; R215; R216; R217; R218; R219; R220; R221; R227; R233; R239; R240; R253; R254
SR0603RESISTOR/SM_0_SR0603_4.99K4.99KIC2R12; R13
SR0603RESISTOR/SM_0_SR0603_180K180KIC1R14
SR0603RESISTOR/SM_0_SR0603_910R910RIC4R21; R24; R27; R236
SR0603RESISTOR/SM_0_SR0603_0R0RIC22R22; R25; R28; R52; R94; R99; R100; R101; R125; R127; R128; R157; R199; R237; R244; R245; R246; R247; R258; R259; R260; R261
SR0603RESISTOR/SM_0_SR0603_DNIDNIIC41R23; R26; R29; R30; R48; R50; R54; R55; R67; R95; R96; R97; R98; R129; R222; R223; R224; R225; R226; R228; R229; R230; R231; R232; R238; R241; R242; R243; R248; R249; R250; R251; R252; R255; R256; R257; R262; R263; R264; R265; R266
SR0603RESISTOR/SM_0_SR0603_2M2MIC1R63
SR0603RESISTOR_SR0603_470R470RIC2R69; R234
SR0603RESISTOR_SR0603_27R27RIC2R70; R71
SR0603RESISTOR_SR0603_1.5K1.5KIC1R72
SR0603RESISTOR_SR0603_10.0K10.0KIC1R73
SR0603RESISTOR_SR0603_1K1KIC1R74
SR0603RESISTOR_SR0603_2.2K2.2KIC1R75
SR0603RESISTOR_SR0603_10K10KIC1R76
SR0603RESISTOR/SM_0_SR0603_DNPDNPIC6R85; R93; R107; R108; R109; R116
SR0603RESISTOR/SM_0_SR0603_2K2KIC1R86
SR0603RESISTOR/SM_0_SR0603_887R887RIC1R87
SR0603RESISTOR/SM_0_SR0603_49.9K49.9KIC2R91; R92
SR0603RESISTOR/SM_0_SR0603_47K47KIC1R115
SR0603RESISTOR/SM_0_SR0603_22R22RDISCRETE10R132; R133; R134; R135; R136; R137; R138; R139; R151; R152
SR0603RESISTOR/SM_0_SR0603_2.2K2.2KIC4R147; R150; R153; R154
SR0603RESISTOR/SM_0_SR0603_1.5K1.5KIC1R155
SR0603RESISTOR/SM_0_SR0603_9.1K9.1KIC1R156
SR0603RESISTOR/SM_0_SR0603_75R75RIC12R158; R159; R160; R161; R200; R201; R202; R203; R204; R205; R206; R207
SR0603RESISTOR/SM_0_SR0603_1.8K1.8KIC19R163; R164; R165; R167; R168; R169; R172; R173; R174; R176; R177; R178; R179; R180; R181; R182; R183; R184; R185
SR0603RESISTOR/SM_0_SR0603_200R200RIC3R191; R192; R235
SR0603RESISTOR/SM_0_SR0603_9K9KIC2R197; R198
SR0603RESISTOR/SM_0_SR0603_37.4R37.4RIC1R208
SR0805RESISTOR/SM_0_SR0805_ORORIC4R31; R49; R51; R68
SRN4-0603RESNW_IS_1_SRN4-0603_22R22RDISCRETE31RN14; RN15; RN16; RN17; RN18; RN19; RN20; RN21; RN22; RN23; RN24; RN25; RN26; RN27; RN28; RN29; RN30; RN31; RN32; RN33; RN34; RN35; RN36; RN37; RN38; RN39; RN40; RN41; RN42; RN43; RN44
STC3528-BCAP POL_STC3528-B_47UF47uFIC11C2; C184; C185; C193; C194; C205; C227; C228; C289; C290; C321
STC3528-BCAP POL_STC3528-B_10UF10uFIC54C4; C6; C24; C26; C33; C34; C40; C41; C47; C48; C59; C60; C74; C75; C85; C86; C91; C99; C100; C106; C107; C113; C114; C120; C121; C134; C135; C141; C142; C155; C157; C166; C168; C244; C266; C269; C271; C276; C278; C309; C311; C334; C352; C353; C358; C387; C391; C392; C426; C427; C433; C434; C440; C441
STC3528-BCAP_STC3528-B_10UF10uFIC2C300; C306
STC7343-DCAP POL_STC7343-D_470UF470uFIC13C200; C201; C202; C204; C213; C215; C229; C230; C239; C240; C257; C291; C293
SX4-0705OSC_ALT_SX4-0705_50MHZ50MHzIC1X1
SX4-0705OSC_ALT_SX4-0705_12MHZ12MHzIC1X2
TQFP80P900X900X160-32AFT245BL_TQFP80P900X900X160-32A_FT245BLIC1U48
USB_A_SHCON4_0_USB_A_SH_CON4CON4IC1J27
XTAL_49USCRYSTAL_0_XTAL_49US_6.000MHZ6.000MHzIC1Y3
XTAL_49USCRYSTAL_0_XTAL_49US_28.63636MHZ28.63636MHzIC1Y4
XTAL_CYLINDERCRYSTAL_0_XTAL_CYLINDER_32.768K32.768kHzIC1Y2
附件:
: _8 {, V% p1 `& aPCB文件如下:0 z! o3 ]) B7 l0 X* o- t
游客,如果您要查看本帖隐藏内容请回复
( o. j7 I* ^  R7 [, j: I
9 _3 `0 V2 h: V3 U0 N4 Z# W1 E
发表于 2021-5-11 21:33 | 只看该作者
看看呢,学习一下1 z: b3 S. V) Q, e  e3 Q$ g
发表于 2022-1-2 11:10 | 只看该作者
看看,学习一下6 n3 O) J. i7 y( b# V! L# B
    2025-10-10 15:06
  • 签到天数: 593 天
    [LV.9]以坛为家II
    发表于 2022-1-3 13:47 | 只看该作者
    看看,学习一下。
    2025-6-11 15:53
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    发表于 2024-1-8 16:55 | 只看该作者
    正好学习下上帝、
    2025-6-11 15:53
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    发表于 2024-1-8 16:56 | 只看该作者
    这么好的东西,一定要支持
    2024-12-10 15:57
  • 签到天数: 6 天
    [LV.2]偶尔看看I
    发表于 2024-10-30 14:46 | 只看该作者
    看看呢,学习一下
    GMT+8, 2025-10-12 15:59 , Processed in 0.156250 second(s), 27 queries , Gzip On.
