Reading file -- E:\11\DESIGN1.asc
& n' V! J2 m+ q* x2 m9 OCan't find part Type item < SR0603 >
5 y1 Z* P2 c6 VR121 SR06037 z! f( ~, }% X7 b. s1 @% P8 H
Can't find part Type item < SR0603 >" k' J8 z8 R/ v
R122 SR0603. ~$ s4 f7 B8 A2 R9 z- ]& A) F. ?9 V
Can't find part Type item < LED24 >
" `; z3 ?- |( C" ^+ F3 ^& k4 N/ kU1 LED24
/ {4 G& J* j6 }- w2 w3 c7 h*Part name not found R121. {7 m6 I: `9 |. Y* G
R121.1
5 q Q! _" V) o( b% W, {*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal LED
7 a" ?$ X7 }. U! r7 o) G*Part name not found U1. z0 ?( r: Z- p1 H+ K2 k: |, Y
U1.3+ K4 Z" Q6 V5 Z7 y0 S# n
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal mcu_VDD
3 M( r2 p% t4 {; ]" I* C*Part name not found R122
5 M5 {0 r3 _0 g) ?# O! y* ?, n C2 ZR122.1
" l7 r' a( K, k, ]. ^' ~5 ~*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal GND5 n7 r A; h4 D* n1 o3 }6 Z# @4 D
*Part name not found U1# E* B& ^$ d7 M
U1.4 R121.2
8 K: P( U. u* x4 D9 j5 k, O i0 {# X*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N00160: p2 h/ |0 p% F, o; H5 K
+ P9 u6 [, H/ H" U' R4 PU1.1& N" I( G# ?& m! \
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal VDD5V
. L1 p/ s9 ~( d4 K*Part name not found U1( ^0 K2 [# j) V; a( v# T1 @
U1.2 R122.2
, ?, a& b. h! d( ^*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N002048 g% l- K* `9 f! n7 l% g3 ]1 ?4 F
Warning: deleting signal LED
0 _' I) d: x6 ]: d! s; SWarning: deleting signal MCU_VDD
2 h: [7 n$ {5 d. d5 B) w! hWarning: deleting signal GND
1 n( Y) |+ Y/ J; n& |3 g1 `: GWarning: deleting signal N001600 [$ E# K) x7 r& M. {
Warning: deleting signal VDD5V% U9 D+ S5 N/ ?+ h( g
Warning: deleting signal N00204
2 @; [: E: ^2 c6 `**INPUT WARNINGS FOUND**
2 Z' e2 G l5 ?但是我的pads库里是有这些元件呀,可是就是说找不到,不知道怎么回事,请高手解答一下谢谢 |
