返回列表 发新帖
楼主: dxdesigner
解决spb16.3不能识别stroke
16#
发表于 2012-7-19 18:33 | 只看该作者
谢谢!!可以使用了
$ `7 x1 U6 l6 n  Q+ M# g
/ J, T9 F: C7 R. f3 \
4 x# u3 ?8 w% q8 N用文字编辑器打开x:\Cadence\SPB_16.3\share\local\pcb\skill\example.ilinit,建议不要用记事本打开,因为记事本打开会有很多的小方块,具体内容如下:" C5 d+ W" h- b# T2 I
8 D8 m( b' e" n: v4 L3 A  ;! W( o- u& H- f
2 @& x" E8 E# t  ; This example file shows how to load Skill files (those with the$ V1 ~$ \# {2 {' A& [, v% F5 |
  P( o8 Z* k! D9 W9 ~
  ; extension ".il" in the current directory.7 U5 i) G) J5 c* R
2 v9 F( O* ]: A1 z  ; To use copy to allegro.ilinit if to be used by all Allegro based programs
# d# T- J  n$ S. _! ^5 \; F+ |3 X
' n& S0 F4 T4 d' }* H  ; or .ilinit if intended for only one program
( |2 i+ L% ^% K# X$ l. S( V1 o. @& t% r' Y/ Z  I9 M8 `8 z
' Y* X/ g$ f0 I3 ^7 L
" M# W# e! O6 k7 x4 N; E. Z  ; Setting Allegro environment variable, LoadSkillFilesDebug will turn/ a0 }2 L4 M0 s* U, ~5 x9 e
) @" I6 c$ ~; x: F
  ; on printing the name of each file as it is loaded.3 l/ q( V' B2 s& m; ?( |' `4 G- ]9 g
( s$ k+ `( C  h+ X* E  unless(boundp('LoadSkillFilesDebug)# Z5 d2 V8 D" T: P
% }* ^" H% @2 C4 A/ i+ g" d
  LoadSkillFilesDebug = axlGetVariable("LoadSkillFilesDebug"))
& r9 T: {. k9 q7 [- b* W& Z- M3 D
  when(LoadSkillFilesDebug printf("\n"))- N) q, j. t  q: w. U
+ S" S* ]7 ~& m, P: _% m
  (foreach file (rexMatchList "\\.il$" (getDirFiles "."))  F: S6 E; ?2 D3 b
$ f1 j2 y7 \6 |" a3 D+ \) C8 [
  when(LoadSkillFilesDebug printf("Loading Skill file: %s\n" file)). i" ^. d: k0 T) V
9 G5 d# T; {8 ~) k& a, Y3 E  (load strcat("./" file))
0 e. A( m& P$ ^5 [, {, F5 y
8 U# i3 s0 o; B' `6 D1 n  )0 Q( r! k' ~5 E) g  @4 K0 {
4 h/ z, F( r  [. m' t! S
  ; Load any ini files (containing axlCmdRegister)& B+ `; e; i' [
/ o" t# [& ?: c! B0 y! C# g  (foreach file (rexMatchList "\\.ini$" (getDirFiles "."))
* ?+ S1 V1 B  e% T/ D1 B6 y! c7 d2 k" o4 G
3 v* \. |$ P+ {& r" d  n- Q) V3 w9 A( i, {; m! S2 P
  (load strcat("./" file))1 ~% @9 E0 o1 K' r, u, {
& P8 B1 g- }$ t+ l, x8 ^  U  )
9 r" r, N2 D: }
) W3 `' F3 U9 G8 ^9 b% ?' `  when(LoadSkillFilesDebug printf("\n"))
, G0 Z9 m' P1 I7 K
8 e- P% x: y1 Q5 N3 H) X2 W  在文件的末尾加上,% I3 u% l. {$ I4 T/ J8 ^6 z( c6 X1 ^8 v
' P1 X, D# ~2 e  procedure(stroke_fix_163(t_open)5 G: j$ T$ s* a% w* v1 X1 e2 j
( `$ ^( L9 F6 ^; |8 J  c& Y
  axlShell("strokefile allegro")
  y! F% d, P2 e: ~& i. g8 `; M; I; i% i. U; D1 G9 A
  axlMsgPut("Strokes now enabled in Allegro 16.3 base release") )
8 Y) f! O* ]. Y+ y
6 n" E2 ?. k: B! j  axlTriggerSet('open 'stroke_fix_163)
" y& E! n9 n, ~  Q% T6 s# l$ M* q  T2 _! j& X
  然后另存为Allegro.ilinit,存盘路径是pcbenv文件夹下。
% P, T  ]8 a* i- x" J- ^: |( W. T2 S4 g
17#
发表于 2012-10-27 11:51 | 只看该作者
可以用,谢谢
    2024-5-2 15:45
    18#
    发表于 2012-11-28 08:17 | 只看该作者
    照着楼主说的去做了,当时可以虽然命令框里面有错误提示但是stroke功能还是实现了,但是我第二天再打开电脑的时候 PCB edit就打不开了,这是为什么呀?我的是16.3版本的。
    19#
    发表于 2012-11-28 09:24 | 只看该作者
    1. 有這麼麻煩嗎?
    4 [! x1 U, i/ ~8 Q. l6 c  T! Q7 d2. 奉勸樓主儘量不要去動到系統內部的設定.- i! D: p2 r! k6 J/ H
    萬一出問題了都沒法救了. 儘可能把環境掛在 pcbenv 裡面.
    % @1 P9 Z& X- K7 G- V3. V16.3 的原始版本 Stroke功能是有問題的 , 無法正常使用. 不過您如果有安裝 S006 以後的補丁 , 那就正常了.
    20#
    发表于 2012-11-28 16:02 | 只看该作者
    楼上说那么多,有的人可能还是用不了,还不如直接了当的告诉大家去找最新的补丁把补丁打上就彻底解决了,不过就是必须在你安装后,和谐前,把补丁打上...想必大家都懂的{:soso_e130:}
    21#
    发表于 2013-9-2 14:13 | 只看该作者
    {:soso_e179:}
    GMT+8, 2025-10-6 07:53 , Processed in 0.156250 second(s), 19 queries , Gzip On.
