查看: 12923|回复: 54
spb16.3 补丁已经出来了,安装后用之前破解方法已经功
发表于 2010-2-3 09:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
' P/ ?  j% G3 p' M
: L) J' J8 o* W. b+ c/ ?spb16.3 补丁已经出来了,安装后用之前破解方法不成功,后换另外一种成功; f4 L. |2 ^+ y
: ^: P( U. ]) U
HOTFIX VERSION:  001
' D$ b# z# j5 g/ E6 Z. u, e========================================================================================================
+ U1 |( `0 D* L5 PCCRID      PRODUCT          PRODUCTLEVEL2        TITLE
! j, N; ^8 D& E; {========================================================================================================
" K! D) G- P5 G; r491042     concept_HDL      SECTION              Prevent PackagerXL from changing visibility on SEC attribute
) Z6 |7 {, z! T496910     CAPTURE          NETLIST_allegro      Inconsistent netlist creation6 o( _- s* c4 ^( s2 {+ [' t
558783     Pspice           NETLISTER            Why do  Models with "awb*" prefix need wirte permissions to
" ^* R# Z' |! {0 R$ V1 B643241     CAPTURE          SCHEMATIC_EDITOR     orcad crashed while replacing cache6 m$ M9 i) y' z. i# C
662829     CONCEPT_HDL      GLOBALCHANGE         Global Update should honor property visibility settings in pp
6 p& c9 j; @. N" ~/ t672718     SIP_LAYOUT       EXPORT_DATA          "Export>Symbol Spreadsheet" should export a .cvf not a .txt
  B6 ?# }4 o, @' E0 ~676233     CAPTURE          NETLIST_ALLEGRO      Cross probing stops working if design name has dots* g9 _' c0 y. Z
690618     F2B              BOM                  Write protected template.bom fails to write callouts4 B4 Q6 `% T1 ~+ V8 c( j3 w
700246     CIS              LINK_DATABASE_PART   Need option to update symbol always when linking part in CIS
) ~" \! Y# U5 _, n6 A9 W705393     CONCEPT_HDL      CORE                 ConceptHDL crashes while switching to another hierarchy level
6 w7 X+ X( o7 u4 f2 k, r; I6 U708634     ALLEGRO_EDITOR   SHAPE                Shapes getting incorrectly displayed in 16.2
' y5 f& ^( f: z3 m( D  |) O9 H& @708950     CONCEPT_HDL      CORE                 Tool crashes while trying to change the text on the schematic% D7 @) \  s. |7 q7 G5 G
709823     ALLEGRO_EDITOR   OTHER                Arcs not converted properly when upgrading symbols; K1 e3 y2 D5 G# \" X9 l
713964     F2B              PACKAGERXL           Net property Probe_Number is getting changed during the packa  n' r$ w9 p! Y3 ]8 v5 G
718119     F2B              BOM                  Exclude the callout file name from the template.bom file% P( {( I" H# ~# ]" }) d
718496     SIG_INTEGRITY    SIGWAVE              Frequency at smith chart.
- Q7 p5 p8 u6 d8 |9 B1 {* V721422     CONCEPT_HDL      CHECKPLUS            Checkplus fails if "\\" character is used in the parameter li
  L8 h" ], E1 T721788     SCM              OTHER                SCM unresponsive while closing out a Block without Saving
5 Y+ [6 y3 `/ T! U" o721801     CONCEPT_HDL      CORE                 Save As crashes DE HDL if an existing page is selected in the. U7 K, ~6 u) g% b. `  L6 x$ n
722653     F2B              PACKAGERXL           Packaging does not complete
; J; Z- b9 d: S# y725285     CONCEPT_HDL      CORE                 nconcepthdl does not work same as concepthdl for same script.5 h3 k6 c: r& s) C
725719     CONCEPT_HDL      CORE                 wire pettern of Publish PDF+ L6 I3 e9 U8 y% W1 q
727062     CONCEPT_HDL      CREFER               Custom properties not visible for TOC symbol in schref_1 view
' ?2 Q  e& k! D" I& W/ ?" G727194     CAPTURE          CORRUPT_DESIGN       Random Capture crash. a3 L  G& H" T. ~$ j: D0 W6 u
727704     SCM              PACKAGER             ASA to PCB getting out of sync
% D' q+ E: V9 Z+ Z# P, h728066     CAPTURE          NETLIST_ALLEGRO      Allegro PCB Edtior net cannot be generated if PACK_SHORT is u& q9 I9 g8 l1 ^4 O% k  l! X3 V
729214     CONCEPT_HDL      CORE                 SHOW_PNN_SIGNAME directive used with Windows Mode gives crash
1 q; Y# u( o: A( Z: p$ r730295     SIG_INTEGRITY    OTHER                Filled rectangle shapes not extracted properly
0 y" K1 o7 ~! ~# j- a9 o! D731183     CIS              QUERY_DATABASE       CIS Query fails with ODBC Error for query (Price contains 29)
$ g4 V& I+ N* h, W* b, g# l732073     SIP_LAYOUT       DXF_IF               DXF_OUT generate an incorrect shape
8 |  B( }$ D2 H5 y  A- g732138     CONCEPT_HDL      CORE                 Cannot change SI model assignments
% K+ L5 h2 w( n% D/ r2 s732216     ADW              DBEDITOR             dbeditor crashes doing copy-as-new into lib folder that has p+ x! L8 I5 K$ P: J* F+ m, R
732249     SIG_INTEGRITY    SIMULATION           Probe sim with custom stimulus cause segmentation fault. Linu
; ^0 ]) D8 n* X2 s* Z732847     ALLEGRO_EDITOR   DRC_CONSTR           Manual Void uses Shape to Pin constraint to void Holes
, _- f( m9 W1 R9 r+ t9 }733261     FLOWS            PROJMGR              Project manager does not work with the Restricted User in cli, L  W( ?' x0 {( b3 r: l
733773     CONCEPT_HDL      OTHER                Syntax issues in DEHDL9 J# z5 r) x4 I0 ?# n0 o6 u
734260     APD              COLOR                Why subclasses still remain visible even after global visibil6 {! p6 }  G; j: |
734419     CONCEPT_HDL      CORE                 Concept crashes in windows mode when netname is deleted on sc' G/ B  A3 r2 }3 V8 d* D
735290     CONCEPT_HDL      OTHER                Concept's PDF Publisher has issues.4 \5 v0 x) C) Z" c4 K* g
735892     CONCEPT_HDL      CORE                 "Component Modify" changes visiblilty of Key properties
1 O: A  |( p8 Y3 j) J3 g: j735977     ALLEGRO_EDITOR   mentor               Mentor to Allegro translation fails without any error message5 e  e  {  j+ u* ?  ^/ L
736071     CONCEPT_HDL      CORE                 Property visibility is not retained on the schematic instance
" i# u, d6 x) q9 O+ o736165     SIP_LAYOUT       SCHEMATIC_FTB        about error message of "schematic to layout"3 Z3 @* }9 i2 A* s0 U
736167     CONCEPT_HDL      CORE                 HDL crashes when I select BGA symbol in Component Browser; g- p% ?0 i$ X$ I
736911     ALLEGRO_EDITOR   SHAPE                No DRC displayed when Place Bounds are edge to edge
; V# {/ ]: k  M' c( E: M738035     ALLEGRO_EDITOR   OTHER                Measure function has different result between 15.7 and 16.2 v3 Y- K2 a1 \/ N) A
738276     ALLEGRO_EDITOR   PLACEMENT            No feedback in console window when placing unfound components. c/ E2 |, p; A/ e2 a9 ?" D+ q# a
738454     SIG_INTEGRITY    FIELD_SOLVERS        EMS2D extracts incorrect CPW to Trace spacing
6 U. P# g# Q7 e* T/ n2 e. O738869     ALLEGRO_EDITOR   OTHER                Error msg when cds.lib contains missing SOFTINCLUDE3 k, J: q" i- g; y8 I4 t! b  Y
739225     ALLEGRO_EDITOR   GRAPHICS             Ability to lock the 'Hide Pallette' option
& |& |+ f& r9 k/ }739599     ALLEGRO_EDITOR   DRC_CONSTR           drc_errchk indic$ J- ~4 w) X$ _
739628     ALLEGRO_EDITOR   SYMBOL               Opening a symbol file is crashing allegro.' n' F3 l4 K, h1 O" a
739653     ALLEGRO_EDITOR   SHAPE                Shape created in 15.X .dra changes geometry when uprev'd to 1* {: Y# o1 C2 C! |' L% h7 q* J
739661     ALLEGRO_EDITOR   OTHER                Export netlist creates incorrect via_list syntax.
6 O, l! p, Z; e- e% y739872     ALLEGRO_EDITOR   skill                Crash while peRForming axlExtractToFile in 16.3& K# V+ h4 L/ _/ K( F" L8 M
739934     SIG_INTEGRITY    OTHER                specctraquest crash on changing signal model
: A; ?7 |) \! B& A739937     MODEL_INTEGRIT   PARSE                zero valued estimated parasitics in ibis models' L7 f8 c0 b2 a# Y  @
739942     ALLEGRO_EDITOR   SHAPE                zcopy xhatch shape creates oversize copy/ L7 g. q" `2 s- `9 e2 T* |6 ~, j
740281     ALLEGRO_EDITOR   OTHER                Jumper components where were placed in PCB disappeared+ w  i' ~; I, A; D! v. k, q0 ]) L/ T
740309     SIP_LAYOUT       DIE_EDITOR           Moving a die pad in DIE EDITOR on G69A_U1 causes the die pads( c- ?( d8 S2 k; m6 S
740399     ALLEGRO_EDITOR   COLOR                Cannot automatically load custom color palette in 16.2
  c1 V5 w: f, E5 T# y741210     ALLEGRO_EDITOR   DATABASE             Edit >Move; spin creates 'connect record not found' message
发表于 2010-2-3 10:09 | 只看该作者
还没看到有下载呢,没下载到没法解哦。
 楼主| 发表于 2010-2-3 10:10 | 只看该作者
只可惜没有权限传到ftp上,只有等待了
发表于 2010-2-3 11:32 | 只看该作者
电驴共享啊
发表于 2010-2-3 11:59 | 只看该作者
上传到纳米盘吧,国内比较大的网盘
发表于 2010-2-3 13:09 | 只看该作者
沒有下載幫不上忙
发表于 2010-2-3 13:51 | 只看该作者
whq888 你好请问一下有没有CADENCE16.2的HOTFIX26或27 或是更新的补丁,本人正想需要,谢谢
发表于 2010-2-3 23:05 | 只看该作者
用shooters破解 提示如下,你是怎么解决的呢?
发表于 2010-2-3 23:43 | 只看该作者
stroke的bug似乎没解决!
发表于 2010-2-4 12:37 | 只看该作者
https://www.eda365.com/thread-30967-1-1.html用这个方去破解成功
发表于 2010-2-4 16:47 | 只看该作者
但是stroke的问题还是没有解决掉啊
发表于 2010-2-4 20:43 | 只看该作者
上面的问题是打开capture时出现的,大家用shooters的方法有这个现象吗?
13#
发表于 2010-2-5 09:44 | 只看该作者
使用原来的RunMe!.bat也可以破解成功.
14#
发表于 2010-2-5 14:43 | 只看该作者
重新安装就没事了 stroke问题也解决了
15#
发表于 2010-2-6 09:06 | 只看该作者
回复 8# nathon * a) w+ \2 S! [' D
2 Y. E2 j, u& T) c- C8 A
把.\tools\bin\orDb_Dll.dll  copy到 .\tools\capture 下 试一下
GMT+8, 2025-7-21 19:36 , Processed in 0.140625 second(s), 28 queries , Gzip On.
