pads的logic画的原理图传进LAYOUT有错误提示,怎么回事??2 ]; [" }+ m4 [4 a* X8 C& ]! F
Reading file -- d:\PADS Projects\padsnet.asc( p% G F' f! k, ^9 H, m$ f
Part name already used T1
8 l: X$ U8 u- I! `T1 EE13A@DIP65 J; l* S- \7 k1 G
Part name already used D4
) F% l! \2 L" z, \* hD4 [url=mailto IO-MLL34@MLL34]DIO-MLL34@MLL34[/url]
. n# u& O. j; k) B7 Y% MPart name already used C5! d; t+ C/ y$ v+ R- o# L
C5 CAP-AE4@AE4
; ^0 m4 c |6 d" t9 ~ SPart name already used R6
' u1 `& w! |! aR6 RES-1/2W@R1/2W* n& \7 _6 [) q+ H
Part name already used DCOUT% C) {3 B, a# m' J2 g' ?
DCOUT ACDY@TP03
$ Z& L& B1 k0 m2 H0 S5 E. o5 j5 A" ?Part name already used R8
2 Z/ _* a/ |& n! D# [R8 RES-1/2W@R1/2W0 T0 J! V; ~6 E- z2 P8 G2 K
Part name already used LED1# @/ W& c/ v u6 n' w
LED1 [url=mailto ED@LED]LED@LED[/url]8 w7 `; {, f5 t% {* C: l( ]
Part name already used R7
7 I4 I% e5 Q; |2 xR7 RES-1/8W@R1/8W
4 \/ G, o2 F- E. m, v0 ^Part name already used GND
9 T1 }: L. Q5 N: UGND ACDY@TP03
7 A' C2 r" w/ P$ e4 E% D9 ~: _Part name already used R3
0 K5 e4 }3 k2 L, P6 P' R6 W! b8 {R3 RES-1/2W@R1/2W$ m* l% e4 N/ E3 E" R) C( `! x+ e
Part name already used C1+ l$ ], f0 T' u* M+ F) q
C1 CAP-AE4@AE4
+ f1 I7 m# ?/ A }+ [ o# t5 k' wPart name already used D1
2 Y- y; c- R. R& Q$ \/ ^D1 [url=mailto IO-MLL34@MLL34]DIO-MLL34@MLL34[/url]
# [3 b1 a1 m1 D6 g( w4 g6 PPart name already used R1
, w7 }3 X, P; N# |/ K3 JR1 RES-1/2W@R1/2W
6 A. y/ j" X# L( @* g X( nPart name already used AC1
# j* ^9 n6 o2 j$ sAC1 ACDY@TP03
) G4 ?/ A; }* ], K' TPart name already used Q2/ b5 s6 ~9 g! V* r2 o: \
Q2 2N1893@TO-39
; [! x$ _2 _, h: X, d4 [4 ]) HPart name already used Q16 }0 d, Y+ a I, r4 {- Q9 o
Q1 2N1893@TO-39
; W+ i. h9 g: z# FPart name already used C2
7 k! H: P! F& c, `3 x# V, gC2 CAP-CC08@CC08$ ]1 ^. ?3 ^' m/ b
Part name already used R2
; \2 C9 q# @2 K( ^* q# M5 v6 `R2 RES-1/4W@R1/4W
( ^! D. O [1 V) X2 j: XPart name already used R4& T! P9 A9 Y- C! X0 w8 M w( z) Q
R4 RES-1/4W@R1/4W0 n( F8 e$ U7 U1 z7 {6 b
Part name already used D2
8 {) |0 Q$ N" z, l8 h' C8 JD2 [url=mailto IO-MLL34@MLL34]DIO-MLL34@MLL34[/url]9 P% W4 O/ ]/ G% j: ~3 \) Q" v
Part name already used AC2
: O+ c% s# U/ n& t) {" xAC2 ACDY@TP03
/ L- l, p. L y3 @% p% Y' w# EPart name already used D3
3 ?1 c) y) T/ bD3 DIO-MLL34@MLL34
4 b2 E# b) R. H- nPart name already used Z1: C4 @, L3 i8 @1 P+ @3 I/ a
Z1 [url=mailto 6KE10@17-02]P6KE10@17-02[/url]
. \0 \4 f( I- d: B' q LPart name already used C4, N3 L, f- O( Y" V9 G! W9 |
C4 CAP-AE4@AE4+ U' m2 O) W& w7 g
Part name already used R5
# C' Q p w F% S& d% {, vR5 RES-1/4W@R1/4W
5 K6 K. `6 H/ }8 t8 gPart name already used C3( t% u5 U& J- U0 ?: h
C3 CAP-CC08@CC08
# O+ @: I& ?) d) a. M1 aATTRIBUTE VALUES+ Z% c w! q; U, V
PART R6
% [. ]1 G4 h3 p- S DError: String /2W is treated as Volt but such treatment is prohibited9 }. v: z4 r K, u8 ~
ATTRIBUTE VALUES- y: H( F6 E; p+ `2 x& H _- L3 S
PART R8
% L$ W$ E$ U5 ?0 PError: String /8W is treated as Volt but such treatment is prohibited- \. S% w" d- S$ }' i
ATTRIBUTE VALUES6 y0 b6 A3 g: N' \8 g" }% O
PART LED19 N1 S% T* _7 \" S9 Z
Error: Number not found, n: }/ Z- V7 f' ]- d2 N
ATTRIBUTE VALUES
& P4 H$ K0 m) g8 X; c4 m* A1 _4 @4 [PART R7
: u# l; s+ y+ `. U# C& q& v) J: NError: String R is treated as Volt but such treatment is prohibited
0 _6 l- p, V9 x D/ O0 ~ATTRIBUTE VALUES
[5 X+ c- l- c% V! x7 J5 `' Q+ hPART R30 F( t+ m* ?. U0 W
Error: String M is treated as MegaVolt but such treatment is prohibited2 ~4 }1 |9 c( _; `# t7 G. y
ATTRIBUTE VALUES
/ a3 h* E, ^, b; k! S: r& mPART R1
+ {0 U" H3 c4 C0 E, F U5 K5 D, CError: String /2W is treated as Volt but such treatment is prohibited
& X a1 W# |7 E/ z# u, E: ?; G- kATTRIBUTE VALUES% `* p% \$ \, h7 A8 I! X
PART R2
& r9 j+ l+ e2 |5 [: h+ bError: String /4W is treated as Volt but such treatment is prohibited/ l7 i q+ R' U0 N v
ATTRIBUTE VALUES( n& W- m$ G2 e3 S1 R
PART R4
" y! m/ x- m9 o2 X/ P1 `3 ?! DError: String /4W is treated as Volt but such treatment is prohibited
, j8 K8 K& `- P3 I7 @" lATTRIBUTE VALUES
* z- G: G. S8 h2 f+ W3 D ^PART R5
8 W) G, V( g+ G, Z* d$ V, ]Error: String /4W is treated as Volt but such treatment is prohibited
, h* b4 c. A) r/ m- i**INPUT WARNINGS FOUND** |
