用pads不是很熟,别人画好的logic和layout文件,在我电脑上打开后不能在logic里用“layout/router link properties” 功能,compare PCB后报错如下,应该是我的电脑里没有这些封装;
& q8 t* Q5 ^' c" N- v请教:怎么样把画好的logic和layout文件里的封装(PART TYPE, CAE, DECAL)保存到我的库中,一个一个点“Edit decal”再保存的话太麻烦了,有没有快速的办法。期待高手。( G& \$ K( Q: Q2 ^: v3 v; f
! K3 j9 g! i2 M% n6 U! O
& h' R: \* R" f; T5 w4 ~# ?( s8 P8 H; A2 b0 q0 p7 S2 g
PCB Net List Errors Report - xxxxxxpcb.sch - Tue May 25 08:52:38 2010
3 `+ @# X9 C$ p- `0 I----------------------------------------------------------------------------------
# N! A; M0 W' p& j3 h) f3 vDesign to Library Part Consistency Check
% b% x/ K) Q9 c1 e* A----------------------------------------- I+ O7 Y% H* H4 h# ?- ?/ \" p) U
Part Type Z8HM2-I not found in Library - not able to check following parts:$ o' r* E. x; m8 X* l% K6 ^
U1.3 K3 X! T G. t+ U) e& F
Part Type L0402 not found in Library - not able to check following parts:
6 r9 F6 y z3 o L2 L40 L1 L3 L4 L5 L6 L31 L7 L8
: l6 L$ K) R# W; O L53 L52.4 a: m5 _ Z% {. `4 w$ R
* ?3 v, `& F w# P: h7 `7 k.; k6 y0 w% y) D: ]4 v
1 _2 i8 s- C4 i" Q9 R& A7 E
3 B4 y& |6 D( J8 b3 r. zSingle/Zero Pin Net Warnings
5 F8 \% ~( D5 i* E----------------------------' a7 h; u# j3 E3 s) n3 m: C$ |
Net ANT has less than two pins in PCB net list file.7 n5 V1 F: C8 z- O0 ^
Schematic Connectivity Errors9 f9 P1 V% s. |0 X
4 m) s* f# Z: Q; Q/ r3 FSubnets with Off-Page Reference to no other Subnet& q; B% a+ O% I' ?, `
ANT
: V/ j7 [ L. P4 n- o( ?! k. cZI2121 X13260 Y4810 |
