查看: 1063|回复: 0
我的PADS的原理图检查有三个页间连接符是单独的,有问题吗?
发表于 2010-5-29 22:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我的pads的原理图检查有三个页间 F-SLMB20.rar (78.97 KB, 下载次数: 13) 连接符是单独的,有问题吗?     帮忙看看。原理图的PCB文件我放在附件里了。不知道这样行不行?
Reading file --- c# g/ g4 v; |
d:\PADS Projects\padsnet.asc
Loading <ZENER\1N5822> from library
Cannot create attribute with name <PART NO.>
Name PART NO. contains spaces between points.
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal IPM_RESETX
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal OC_REF
*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal PROGRAM_RELAY2X
ATTRIBUTE VALUES
NET +5V
Warning: Attribute of type VALUE not allowed for specified object
Warning: deleting signal IPM_RESETX
Warning: deleting signal OC_REF
Warning: deleting signal PROGRAM_RELAY2X
**INPUT WARNINGS FOUND**
上面三种颜色的名称是页间连接符的名称。我传网络表过去,就有这种错误提供,我发现只有一个叶间连接符。。。 一般应该是两个呀,请高手分析。
GMT+8, 2025-6-26 19:37 , Processed in 0.078125 second(s), 28 queries , Gzip On.
