查看: 1716|回复: 2
The directory pointed by the FileDir INI file entry cannot be found.Aborting...
发表于 2020-5-6 14:07 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
9 C) G3 p& R1 U2 d: ~* g
' p& }, v/ F; k8 |$ d+ y
点击pads后就会出现以下: "The directory pointed by the FileDir INI file entry cannot be found.Aborting."点确定后,
* Z4 m9 j) F  o/ M4 ]软件自动关闭。. W6 B& g) O, r7 M7 @; {3 _
& `$ ]/ W8 r. c& ?
解决办法:7 E! z, J( R3 D- b" _/ {" x. ~
打开(X:\mentorGraphics\2005PADS)\SDD_HOME\Programs\powerlogic.ini,注意:括号中的路径为PADS在用户磁盘上的安装路径;
% X8 v/ w' s( Q! \0 R按PADS Logic软件的错误提示框中显示的内容,定位至powerlogic.ini文件中相应设置项,如“FileDir”等逐一修改为磁盘上存在的路径,即可。
; H. H& a4 `* g+ i- i3 P/ g+ r* }  D4 j$ ]1 \: M
Pads, Power Logic:% ^+ Y& v+ u+ M+ F
Notes, tips & workarounds.
Logic default settings & paths in the ‘ini’ file V2005.
9 `, S1 Y- ~0 H7 ^Sadly Pads logic doesn’t allow you to set the default paths & settings of a project from within the program itself. So a little digging around in the ‘ini’ file is required.# r$ j7 z/ I; V* x& ~
Go to:3 Z4 ^% a" G6 H% R7 u
C:\MentorGraphics\2005PADS\SDD_HOME\Programs\powerlogic.ini
5 F7 E! e* L) i* O4 ^+ Q9 kOpen the file in Notepad or a text editor & near the top you’ll see;
7 _2 g6 P2 w/ ~. b3 a
FileDir=C:\PADS Projects\; w: W9 \3 G$ v* E7 |' U# y$ Z
LibDir=C:\MentorGraphics\2005PADS\SDD_HOME\Libraries* [0 s, W& I! l' p9 r
UserDir=C:\MentorGraphics\2005PADS\SDD_HOME\Settings& z; h9 ^' [% F: N
SystemDir=C:\MentorGraphics\2005PADS\SDD_HOME\Programs/ ^' p8 m- ~9 n' F$ b$ k/ i- \
ReuseDir=C:\PADS Projects\Reuse
- T9 J7 y( x2 D* UCAMDir=C:\PADS Projects\Cam
$ F8 H0 H: \- O+ d5 h: U- i# C$ Y) j
FileDir: This is where the program will open a file from, so if you have a project location or mapped drive you wish to work from, place it here.
# y' y- S- I; H) Q7 c, sLibDir: This is set in the Library menu under ‘Manage Lib List’" b- l) P$ d" u, c% K
UserDir: This is the settings location & is normal left as the default path set by Mentor, unless of course you want to move the settings files also!+ d4 `5 y* t, G; t4 G% w
SystemDir: As the name suggests this is the Logics system path & really needs to be left as the default installation intended.9 w! S- V$ Y* h# w7 p6 M$ D9 }
ReuseDir: Location for Reuse libraries
& F# m/ m- g: w# q/ `CAMDir: Location for CAM output.) ?  w& }# f! g- }3 j9 j7 w: M: ^
However if you have many different clients with different library sets etc, a quick tip to get around re-setting these settings all the time is to keep separate ‘ini’ files for each client named with the clients name & just copy it & rename it to the default name each time you need to change over settings.
' V$ q6 F/ M2 y  ^8 {$ ?! w
发表于 2020-5-6 17:40 | 只看该作者
以前见过那个问题,忘了怎么解决了。
发表于 2020-5-6 18:17 | 只看该作者
这个方法好,谢谢分享。
GMT+8, 2025-6-29 02:45 , Processed in 0.078125 second(s), 23 queries , Gzip On.
