Bad component pin number D2 3
2 I' M) r1 b1 O! aD2.3 R3.2
+ D& S3 ]5 |. o! K3 V P; W*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N13425
% B9 Z# N2 I- B; lBad pin number in connection D3.3
/ F* n& x) ^) c* `' z- m' f5 ?R3.1 D3.3
& z+ T. V/ \% f9 l; |# a*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal N13568: S% G4 o, a6 _- Q& ?6 k2 I
Bad pin number in connection CON4.13
. \( V3 U) K4 d$ f! ?C9.1 C8.1 R1.2 L1.1 CON4.13 CON4.14 CON4.15# V/ h" g$ S7 A6 w4 ?8 m' Y# J. A
Bad pin number in connection CON4.12
# M; t' O0 A! x5 q) _C13.1 R9.2 CON4.12
8 K5 l( c$ M# @# p) g6 v; EBad pin number in connection CON4.11
3 P2 S$ ^3 X [; }8 \D3.2 CON4.11
; `, ^/ E6 A4 t+ [( t*Bad *CONNECTION* ascii data format, nets must contain more than one pin. Signal ADJ1 U1 l; Z+ E4 b4 _% B; \
Bad component pin number D1 3+ }- A" I+ |) ~& N6 N/ E
D1.3 C7.1 C6.1 C5.1 C4.1 C3.1 C2.1 C1.1
0 P% X5 f: F* t9 eBad pin number in connection CON4.10
# N9 ~8 A2 p: u) UR15.2 R17.2 R18.2 R16.2 CON3.6 CON4.6 CON4.8 CON4.10$ Z0 C# B( x# j' b6 l; x
Warning: deleting signal N134252 D5 a5 J& j& ~; Z
Warning: deleting signal N13568: ]$ G8 _% _2 {5 A, x0 a
Warning: deleting signal ADJ
: ]$ }0 f0 J8 m$ s**INPUT WARNINGS FOUND**2 f" p8 O, f( \" H1 d
. n5 M7 U" i6 p6 w
8 L+ [% \7 w T3 a2 r- a$ I) B" r以上為導入pads後出現的錯誤提示,且上面元件在PADS中無連接(無鼠線連接),但orcad中進行DRC是好的,其封裝設置也沒問題,請指教是何原因造成的,附件為原理圖,先謝謝各位了。 |
