.dsn
8 w3 ?7 ?1 N- _1 q$ JNetlist Directory:
& G( u3 Y: b$ JF:\TEST\TEST\02
( I2 c% H$ _7 B" F$ j; MConfiguration File:" ?( G6 X9 H! A5 C3 ^) S7 A& |6 l
E:\cadence\SPB_16.2\tools\capture\allegro.cfg/ q$ _. W- x- s, Y4 |: _% g' b
Spawning... "E:\Cadence\SPB_16.2\tools\capture\pstswp.exe" -pst -d "F:\test\test\02\test.dsn" -n "F:\TEST\TEST\02" -c "E:\Cadence\SPB_16.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"6 F5 ~( q+ s3 @: V; q2 j( Q
#1 Error [ALG0014] Conflicting values of part name found on different sections of "U1". a& t f3 R7 U4 ~% \9 g% P
Conflicting values: HC14_6_SOP_14P_25_HC14_7 & HC14_7_SOP_14P_25_HC14_7 % `0 r; W! D4 b8 m8 R
Property values of "Device","PCB FootPrint", "Class" and "Value" should be identical
3 q9 G- r( L, Z( t) J$ S on all sections of the part.7 {& h4 r0 J6 q7 q. N1 W2 ^
#2 Aborting Netlisting... Please correct the above errors and retry.
) f3 C$ \5 O' ?! g5 JExiting... "E:\Cadence\SPB_16.2\tools\capture\pstswp.exe" -pst -d "F:\test\test\02\test.dsn" -n "F:\TEST\TEST\02" -c "E:\Cadence\SPB_16.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
) B. |/ b8 q( ^3 ^: D' B" i9 [: i* }* T/ M+ G/ Y/ H
*** Done ***3 `" {3 c5 q4 }9 Y. g" _
orcad netin时出现了上面的问题还请那位高手指点!!!!7 ~4 [. L* {" u& }7 q6 E4 a8 K
我在线等!!!!!!!# ^" o E4 n. w6 Z, x; o
谢谢!!!!!!!!!!!! |
