TA的每日心情 | 开心 2024-3-29 15:04 |
签到天数: 71 天 [LV.6]常住居民II
{ Using PSTWRITER 16.6.0 d001Jul-10-2020 at 16:24:03 }
+ h; c, \ \+ W3 S) H' D& f* J
6 R! T( b* p* `$ I( V8 B) u& y6 {
6 {0 A$ V* m3 v% m" m+ p#1 ERROR(ORCAP-36071): Illegal character "Dot(.)" found in "PCB Footprint" property for component instance U4: SCHEMATIC1, PAGE1 (238.76, 114.30) . p8 z+ C ~" V+ S% z
" M1 [4 w+ S. [1 z5 ?/ q b$ g
#2 ERROR(ORCAP-36002): Property "PCB Footprint" missing from instance E1: SCHEMATIC1, PAGE1 (13.46, 6.60).
6 L7 D2 t: b1 m# ]- z @( U* Z( C& Z) H0 @; {3 G
#3 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E5: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.' h4 |/ ~0 y! }* H- x4 o9 c
P$ X5 ?4 s8 ^; R2 ]: A#4 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number F2: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
5 p! H' G) W: ]5 E: d4 ]& i( A0 x6 x6 [# c: P
#5 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number D7: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.8 k) [' v! d9 `: z3 v
) d$ y9 I. o: j1 L9 ~# x#6 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E7: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these. u+ t' ?1 U/ J, C9 z. g* L' P
# ^5 y4 i b, q3 y5 j- g#7 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number D6: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.
8 y+ g1 @6 U4 K% K( F/ m
7 i6 Z+ M* o, s T6 Y8 B! o/ W#8 ERROR(ORCAP-36041): Duplicate Pin Name "GND" found on Package AB1536 , U4 Pin Number E6: SCHEMATIC1, PAGE1 (238.76, 114.30). Please renumber one of these.+ |3 \" u) A/ T6 y. ]
: H) [3 S0 c! f+ b, K- ?#9 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , RST_N1: SCHEMATIC1, PAGE1 (40.39, 86.36). All pins should be numbered.
: r6 Q. s: n) @7 o8 H3 S$ ?5 e5 ^% c5 p& V2 h4 p5 `# \7 h
#10 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , UART_RX1: SCHEMATIC1, PAGE1 (19.56, 109.22). All pins should be numbered.
. Y9 h* w" q) V- n: D
# J. b- r0 s+ H- J% g: L. s4 u2 t9 k#11 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , BATP1: SCHEMATIC1, PAGE1 (20.07, 86.36). All pins should be numbered.
* w8 s! b# L7 A
" ?! v9 B. Y8 [# q4 z% [2 T#12 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , UART_TX1: SCHEMATIC1, PAGE1 (18.03, 99.06). All pins should be numbered.- \7 l* w: ~. d% [' X/ X
0 }/ R4 ^; @: k#13 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , GND1: SCHEMATIC1, PAGE1 (40.13, 109.22). All pins should be numbered.
8 K( R8 a$ l! ~6 x* M% v
& f6 |: R* E! }) z#14 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , REGEN1: SCHEMATIC1, PAGE1 (40.64, 99.31). All pins should be numbered.! J$ T+ _- q' x2 R3 [
2 I3 F( ]1 _, J+ r0 @& a" Y
#15 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , OD_GPIO1: SCHEMATIC1, PAGE1 (19.81, 119.38). All pins should be numbered.& ]0 d9 X' p! f9 n( C, M
A1 S4 U) U' G
#16 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package TP_1 , L-1: SCHEMATIC1, PAGE1 (241.81, 4.83). All pins should be numbered.
9 y8 W' X' q% S' T
0 l- a8 {% R/ k. A8 J2 ?0 ?#17 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package CON1 , PIO1: SCHEMATIC1, PAGE1 (40.64, 119.38). All pins should be numbered.' V4 ~2 w3 }9 q5 h. Y* h
# f0 X: Z5 ]4 k) T. u8 T9 l+ M
#18 ERROR(ORCAP-36022): Pin number missing from Pin "1" of Package TP_1 , L+1: SCHEMATIC1, PAGE1 (238.51, 27.69). All pins should be numbered.
# r6 ?$ M9 H4 v6 o
6 w4 t7 J( p+ f/ [2 B#19 INFO(ORCAP-36107): PCB Editor does not support Dots(.), Forward Slash(/) and White space in footprint names. The supported characters include Alphabets, Numerics, ' g9 {6 ^0 `) r6 x0 p- |9 V
0 k* m. C7 r1 o$ G D" y, J+ |0 D3 ~$ `! I! O
Underscore(_) and Hyphen(-).% _. k9 X3 G5 l9 z3 G6 O! t! v" j
/ K3 Z j' A$ l* k. @1 e7 f
3 K q c8 U# b% u
+ _" s( V* Y8 F1 O( }! M7 ~
#20 ERROR(ORCAP-36018): Aborting Netlisting... Please correct the above errors and retry.
2 F& F8 Z- _3 |+ a' r7 y5 W
/ x* c% }6 K3 n5 C3 t请问大家这么多的错误,除了红色部分外,应该如何更改?
* y1 ?6 A5 ^' V+ C3 B d) x4 _5 _第一,做元件的时候说GND告警可以忽略,这里警告改如何修改?我通过把GND加数字办法已经修改成功,请问高手还没有其他办法?
! m" e0 ~) I4 E& p第二,那些焊点的错误,因为是要做测试夹具,程序下载口可以随便放置,因此做的是一个焊点算是一个封装,这里是我最明白的,希望能得到大神的指导。
) i& @5 V& u0 b, ]# K& k希望有大神不吝赐教,谢谢了!8 A, K0 J% v% L
, g# n( v; d/ l5 @# g |
