Adding a Command to the Tools Menu
* s" G7 D3 U. rAdd a command to the Tools menu as a shortcut for running the command.! k! ]: O; O: L4 A- p
Procedure4 C2 q7 j- V: ~% W; w" c
1. Select Tools > Customize to display the Customize Tools Menu dialog box." ]% s5 q# E. w) N1 {$ @
2. If you want the command available to all users who log on to your PC, select the
, k1 T! l; M7 d) y& JCommon option from the Menu Item Types section.0 M( h2 F0 |3 Q" ^; c4 l) K: G$ \
3. Enter the name that you want to appear as the new menu command in the Menu Text+ F2 L3 B8 i/ P, x$ h7 |' j) u
field.2 R' R. d, e: h6 X/ b; }3 L: o8 g
4. You can specify a letter in the menu title as a menu accelerator by entering the title with. a# C( G' }8 q* r( e* `
an ampersand (&) immediately preceding the accelerator letter. If you do not specify an
7 \4 X3 L! c% h, ~accelerator, the first unique letter in the title is the accelerator by default.) s) D2 R5 F. W; r
5. Enter the command that invokes the new application in the Command field.
k* P- f3 i" T7 c% AClick the Browse button to select the appropriate drive and directory, and then select the
# m& v! B9 g& l; d7 y( ~5 eexecutable you want to add from the list of file names.
2 }5 V1 k, s( `( R" S j6. Enter the arguments associated with the command in the Arguments field.
( t7 w$ x) f9 y @' k, g& x+ bFor information on valid arguments, refer to “DxDesigner Arguments” on page 29.+ ?$ E4 j" s5 p
7. Enter the working directory for the tool in the Initial directory field.0 X, C C; W7 |9 ]1 l j
8. Click the Add button to add the menu item to the Tools menu.
, Q0 S0 I z9 z6 J9. Click the OK button to dismiss the dialog box. |
