查看: 1518|回复: 25
有个问题!
发表于 2020-10-11 19:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
公司的产品!把遥控器靠近红外接收头就很不灵敏,离得稍微远一点效果就会好,这是为什么呀,
“来自电巢APP”
分享一下你的發射端和接收端紅外型號吧!^_^  发表于 2020-10-12 21:48
推荐
 楼主| 发表于 2020-10-12 19:25 | 只看该作者
startostar 发表于 2020-10-12 10:52:22
& Q) G4 [; o6 `4 M( P查下红外对管角度范围
7 L) H' J9 D! m% |
# D& ^' p: J  J) p- w$ O
正对都不行哦, B1 s2 z* ]2 a9 ~( ]+ T4 N- r
“来自电巢APP”
发表于 2020-10-12 09:03 | 只看该作者
用示波器看一下对着按的时候有没有信号
    2021-2-25 15:13
  • 签到天数: 22 天
    [LV.4]偶尔看看III
    发表于 2020-10-12 10:52 | 只看该作者
    查下红外对管角度范围
    xiaowenwu1989 发表于 2020-10-12 09:03:42
    % }' b1 I! S+ v- Y用示波器看一下对着按的时候有没有信号
    . G2 H  X5 Z; N5 R! M% f
    ) T/ ^% v+ z) I7 j" s& h. z有信号的哦
    , {# `. |2 q) ~6 G$ |, {
    “来自电巢APP”
    发表于 2020-10-12 20:49 | 只看该作者
    The maximum possible transmission distance of an IR remote control system depends on various parameters, but is mainly conditional on the radiant intensity of the emitter (Ie) and the sensitivity of the receiver (Ee min.). Additionally, the reflective conditions of the test room, the optical transmittance of windows or light guides in front of the receiver and the disturbance conditions influence the maximum distance obtainable. Of course, also the minimum possible distance (saturation irradiance) is an important parameter for a remote control system. The TSOP IR receiver modules from Vishay will work even with zero distance between the emitter and the receiver module.
    " [5 r( L) d  l" \* }0 i) Y
    3 d+ ]- X5 w9 I
    + T& z3 |# o8 B4 z! r/ q4 J/ C5 i( n2 u( t' g* z2 R* q" N
     楼主| 发表于 2020-10-13 08:26 | 只看该作者
    超級狗 发表于 2020-10-12 20:49:17
    ( ?7 P: O: S# P1 l! I% O( LThe maximum possible transmission distance of an IR remote control system depends on various parameters, but is mainly conditional on the radiant intensity of the emitter (Ie) and the sensitivity of the receiver (Ee min.). Additionally, the reflective conditions of the test room, the optical transmittance of windows or light guides in front of the receiver and the disturbance conditions influence the maximum distance obtainable. Of course, also the minimum possible distance (saturation irradiance) is an important parameter for a remote control system. The TSOP IR receiver modules from Vishay will work even with zero distance between the emitter and the receiver module.
    ( \' Z& V, \6 z4 H- {8 s" L9 m5 y1 w9 j2 I
    ; X9 m& B- T5 U8 o& @5 g9 Y6 l, L/ y. o& h5 v$ i* ]3 L# G
    有考虑到饱和度这个问题,但是从wifi板拿到蓝牙板这个红外头又可以正常工作。一大串英文,谢谢大佬解答!
    " I2 h8 W/ Q+ e6 w
    “来自电巢APP”
    发表于 2020-10-13 11:23 | 只看该作者
    天线有问题啊,哥哥
    “来自电巢APP”
    奋斗
    2023-2-28 15:46
  • 签到天数: 77 天
    [LV.6]常住居民II
    发表于 2020-10-13 11:41 | 只看该作者
    你这到底是蓝牙天线,还是普通的红外遥控?看你的板载天线像是2.4G的。。。。。
    发表于 2020-10-13 16:20 | 只看该作者
    看看是不是信号饱和了,导致信号失真
     楼主| 发表于 2020-10-13 20:31 | 只看该作者
    luckyzy2000 发表于 2020-10-13 11:41:56- n  D; Y: e8 J& ~
      r0 H8 S6 ]% T. w4 r' z
    + ]7 |0 k  R: Y, s8 o0 iwifi 红外的!!; H+ K6 p# K+ b! f/ V# Y7 j
    “来自电巢APP”
    zzpwangyue123 发表于 2020-10-13 11:23:41! j7 K: u- w) j( T) a3 Z
    天线有问题啊,哥哥
    2 L  Q" A# _, D9 g/ F% k+ n7 a( _8 P' Z4 S: E
    红外呢,不关天线  M5 f- g6 ]# h& [
    “来自电巢APP”
    13#
     楼主| 发表于 2020-10-13 20:32 | 只看该作者
    李震 发表于 2020-10-13 16:20:56
    + c# _) b0 [9 J2 ?8 E看看是不是信号饱和了,导致信号失真
    6 ?. w# y/ Q3 ]4 N/ |2 M. `0 c9 x( _
    ; d2 b& s" }$ W+ F
    信号都正常呢
    8 f1 l' Z' g& G' h: z+ E7 ~2 H
    “来自电巢APP”
    14#
    发表于 2020-10-24 19:42 | 只看该作者
    看到Q1. Q2. 两级三极管放大?是该看下最后输出级信号是否正确
    “来自电巢APP”
    15#
    发表于 2020-11-1 14:48 | 只看该作者
    把原理图放上来分析
    “来自电巢APP”
    GMT+8, 2025-10-2 22:11 , Processed in 0.140625 second(s), 28 queries , Gzip On.
