[ComponentDefinitionProps]
3 W2 ~6 [( r6 ]+ `ALT_SYMBOLS=YES
( w i, g2 N* I" e7 N7 z3 P/ }, } KCLASS=YES" ~3 F2 u1 C5 N, l1 U/ T0 ~/ l
PART_NUMBER=YES
8 A0 w6 S2 W& K, j+ i v- fTOL=YES. ]; M' k: n+ w5 c; o1 ~
VALUE=YES7 V; V) L- H" H. W0 L; h& U
POWER_GROUP=YES
, v, H3 B# t0 e5 {. A1 oSWAP_INFO=YES
) O8 @) F x+ O3 x! v! B" b0 [[ComponentInstanceProps]
; {, \2 q f8 B6 gGROUP=YES6 D) ?, {, l4 t2 s: a# ?( Q" V
ROOM=YES
; b3 H- z3 f# {/ C5 S5 d7 tVOLTAGE=YES/ y1 U7 x' g& y, ~/ A
$ t; H1 v9 D9 `. H) G- X2 D r[netprops]
! T0 G7 o: N1 aASSIGN_TOPOLOGY=YES
( u; g! l( z( O2 b9 FBUS_NAME=YES
2 I f/ X p9 `. D" Q1 [CLOCK_NET=YES8 B& y& C) ?( ^: a
DIFFERENTIAL_PAIR=YES9 j/ ~ I" K9 u' W7 X2 e
DIFFP_2ND_LENGTH=YES% n, j6 d3 z0 h
DIFFP_LENGTH_TOL=YES
; N. h' M+ p' X; {7 kECL=YES& g- U+ u" d* x/ j; S' U
ECL_TEMP=YES. P. k! c0 h& g% X
ELECTRICAL_CONSTRAINT_SET=YES7 J$ b7 r/ [0 B
EMC_CRITICAL_NET=YES# o0 `# Y0 |6 G0 r1 h
IMPEDANCE_RULE=YES& K& d# V2 T8 Q
MATCHED_DELAY=YES4 F$ b$ x; _6 ~' G# h9 }0 v( h. x/ c
MAX_EXPOSED_LENGTH=YES7 C, u& x1 t' w* m
MAX_FINAL_SETTLE=YES
# L3 D! j6 Q+ ZMAX_OVERSHOOT=YES2 s* C p) Q- H
MAX_VIA_COUNT=YES
) |6 i$ C# [" @! X4 cMIN_BOND_LENGTH=YES
, V! e& |$ m/ sMIN_HOLD=YES
; A4 `6 N0 `! ^4 aMIN_LINE_WIDTH=YES
+ B# R. ]+ U5 x: J+ [MIN_NECK_WIDTH=YES
! j/ r V& `; d$ z n% _' JMIN_NOISE_MARGIN=YES
9 ^6 w7 a6 r; l+ @+ I( kMIN_SETUP=YES; T4 }; p. D2 z& `2 O# K
NET_PHYSICAL_TYPE=YES) z2 Q: B& y3 i" _. g' `: w
NET_SPACING_TYPE=YES+ a6 d" B% R- q; [
NO_GLOSS=YES- C7 o, D* ]1 J8 J, ]
NO_PIN_ESCAPE=YES, b0 o# ?! i* N, R* a) i
NO_RAT=YES; i" Q8 L! S( F2 ^& K% a+ S5 b
NO_RIPUP=YES; D( Q7 B& J# l6 V o. B8 B
NO_ROUTE=YES- m: }3 f$ {# P/ E# R
NO_TEST=YES$ |" D6 `/ }. \
PROBE_NUMBER=YES
! G; ]9 ^" q# Q' N. BPROPAGATION_DELAY=YES. U- F6 C; J6 K) X/ {
RELATIVE_PROPAGATION_DELAY=YES
& q) j0 ~+ ^4 x( Y/ HRATSNEST_SCHEDULE=YES* ?# }+ p9 g5 f1 _6 @3 M
ROUTE_PRIORITY=YES
5 a5 _* P6 }" R" K0 p7 ^# `+ m- _) bSHIELD_NET=YES
6 k" b) B! n& S; |" m+ HSHIELD_TYPE=YES% D3 ?3 D) _* H1 V5 F# P2 Q
STUB_LENGTH=YES
+ n& Q# H, n2 v0 a: _SUBNET_NAME=YES: u' v9 K' f9 P/ y7 I
TS_ALLOWED=YES1 ]$ H& P) [9 ?* C2 D: ^
VOLTAGE=YES
' u$ h9 m+ c, h$ L2 |VOLTAGE_LAYER=YES1 V0 M; V; e) a( N( j' G2 G
[functionprops]
3 {3 ?. E% M: [8 d; m$ {0 yGROUP=YES
6 F: c4 v, Y( s) n' d& p+ OHARD_LOCATION=YES; M* L% K/ y1 d; }3 x
NO_SWAP_GATE=YES
3 t3 u; v) ?. |$ u7 k% r3 mNO_SWAP_GATE_EXT=YES
+ l; E0 g- G2 @NO_SWAP_PIN=YES5 ~4 J/ j+ D' G' f+ m
ROOM=YES: K( E$ r. q# M; n4 j0 u
[pinprops]6 q/ Q1 H t3 _ t8 G
NO_DRC=YES
0 h7 a' E. a! b+ B5 E7 Q. zNO_PIN_ESCAPE=YES! {/ P6 V7 d, V4 }9 d$ e
NO_SHAPE_CONNECT=YES
# e0 L! c1 f( zNO_SWAP_PIN=YES+ K/ ^% n' K; V) R' r) ^/ h
PIN_ESCAPE=YES
! n ~6 q2 s/ y6 Y1 A3 K5 c* c2 z+ U
5 H; W1 D; x9 V1 P+ S+ E
, Z: `1 s8 F6 s8 v; f7 c8 O5 l修改allegro.cfg文件可以屏蔽导出网络表:非法字符的报错吗
& g$ [. U: z- q |
