这块板子在覆铜的时候,不自动避让,造成了很多DRC错误。。。。。。
8 X, V- F* a" ]0 B5 C! V% v; z为啥会出现这种情况呢??
/ T% j7 @) [! r/ ?, V% ^4 d
! ]1 F& A& |& p6 K: j+ L
( @1 t$ r; P+ F( F2 j1 W; m设置是这样的
4 D3 R' \4 v( ]. O
% `" Q! f; c1 M. Z2 |
* H1 W6 q8 }1 T0 _9 ?
j2 F$ b. G, w0 c+ M6 k, q7 f5 X7 u' c) f6 u. P
覆铜不避让2 P1 z% i/ r( J0 {7 W5 S, ~; [
. _* O. O- k/ m' _6 L; R! j# U
2 u6 o% B: V3 N
" w; |$ r1 j3 ]) n f% v& k* u7 o
产生错误
8 K% [# u; }, G2 d* z: p' I5 y U- A
# r' g2 Y' Y' j) j4 [) W" h) [( m# ?" B' E/ z
4 ` s0 h3 {0 }" h+ C
7 m, ^3 |& i9 m6 E( Y6 {9 t; PLISTING: 1 element(s)8 v* q. d, i( M' E3 h, F; m* g" c4 z; e
< DRC ERROR >
% N& _4 L% k: U/ ]/ k Class: DRC ERROR CLASS6 E8 A0 K4 A* {! z9 p! E7 U
Subclass: GND- i. g; L. s9 g0 s0 j
Origin xy: (121.4757 -1.8869)" O0 n5 f8 Y; \( F; v. w
Constraint: Line to Thru Pin Spacing
) J' K4 G) V: [5 y# w3 ] Constraint Set: DEFAULT" F' Q2 e- P, Y, H) K D$ l# p
Constraint Type: NET SPACING CONSTRAINTS
5 R/ b( L# [- D% [$ c% Q" f! m- b Constraint value: 0.2032 MM. D$ K# l2 O( W
Actual value: 0 MM |
