Q: I don't understand "polar" command. how to use it? i want place symbol as circle. for ex. i have LED circuit 36 pcs.(LED1-LED36) import from logic and i want place LED as circle start 0 degree increse 10 degree..20 30 40.... i can't copy led symbol. ( S6 j; t5 B- ~5 U7 ]
1 b/ O& v8 L' l1 y4 W
A: you could place the first LED as per normal then copy it around using the polar command. You will then use the Logic/assign refdes command to place the remaining LED's % ~9 g' I7 Z* u1 i U$ W% R L6 ]' n) y2 d. {# ?2 W
: _% G( E) x" _3 g" ~2 a
