在Command命令行中输入
L<n> [n] [n]...
n表示所在层序列,支持多层输入。例:显示第1,3层 Command > L1 3回车
axlCmdRegister("layernumvisible" 'layernumvisible ?cmdType "general")
procedure( layernumvisible( @rest num)
_LCSetNumLayVis( num)
);end-procedure
;# number layer visible #
defun( _LCSetNumLayVis ( lnum, @optional msg)
prog( ( class, i, n, layer)
n = 0
ln = nil
foreach( enum, lnum
num = atoi( enum)
if( num then
if( num <= axlGetParam( "paramLayerGroup:ETCH") -> nChildren && num > 0 then
class = nthelem( num axlGetParam( "paramLayerGroup:ETCH") -> groupMembers)
i = makeVector( 11 nil)
i[0] = axlGetParam( "paramLayerGroup:ANTI ETCH") -> visible != nil
i[1] = axlGetParam( "paramLayerGroup:BOUNDARY") -> visible != nil
i[2] = axlGetParam( "paramLayerGroup:ROUTE KEEPOUT") -> visible != nil
i[3] = axlGetParam( "paramLayerGroup:VIA KEEPOUT") -> visible != nil
i[4] = axlIsVisibleLayer( "BOARD GEOMETRY/CONSTRAINT_AREA")
i[5] = axlIsVisibleLayer( "ROUTE KEEPIN/ALL")
i[6] = axlIsVisibleLayer( "ROUTE KEEPOUT/ALL")
i[7] = axlIsVisibleLayer( "DRC ERROR CLASS/ALL")
i[8] = axlIsVisibleLayer( "VIA KEEPOUT/ALL")
i[9] = axlIsVisibleLayer( "ANTI ETCH/ALL")
i[10] = axlIsVisibleLayer( "BOUNDARY/ALL")
if( n == 0 then
axlVisibleDesign( nil)
else
axlVisibleSet( layer)
);end-if
axlVisibleLayer( "BOARD GEOMETRY/OUTLINE", t)
axlVisibleLayer( strcat( "ANTI ETCH/", class), i[0])
axlVisibleLayer( strcat( "BOUNDARY/", class), i[1])
axlVisibleLayer( strcat( "ROUTE KEEPOUT/", class), i[2])
axlVisibleLayer( strcat( "VIA KEEPOUT/", class), i[3])
axlVisibleLayer( "BOARD GEOMETRY/CONSTRAINT_AREA", i[4])
axlVisibleLayer( "ROUTE KEEPIN/ALL", i[5])
axlVisibleLayer( "ROUTE KEEPOUT/ALL", i[6])
axlVisibleLayer( "DRC ERROR CLASS/ALL", i[7])
axlVisibleLayer( "VIA KEEPOUT/ALL", i[8])
axlVisibleLayer( "ANTI ETCH/ALL", i[9])
axlVisibleLayer( "BOUNDARY/ALL", i[10])
axlVisibleLayer( strcat( "PIN/", class), t)
axlVisibleLayer( strcat( "VIA CLASS/", class), t)
axlVisibleLayer( strcat( "DRC ERROR CLASS/", class), t)
axlVisibleLayer( strcat( "ETCH/", class), t)
if( class == "TOP" || class == "BOTTOM" then
axlVisibleLayer( strcat( "PACKAGE GEOMETRY/SILKSCREEN_", class), t)
);end-if
n++
ln = append1( ln num)
else
if( num == 0 then
if( n == 0 then
axlVisibleLayer( "BOARD GEOMETRY/OUTLINE" t)
class = nil
n++
);end-if
else
axlMsgPut( "E- The %d etch layer is not exist.", num)
);end-if
);end-if
else axlMsgPut( "E- %L is not number.", enum)
);end-if
if( n != 0 then layer = axlVisibleGet())
);end-foreach
if( n == 1 && class then axlSetActiveLayer( strcat( "ETCH/", class)))
if( n != 0 && ! msg then
axlVisibleUpdate( t)
msg = ""
foreach( n ln
sprintf(layer "%d", n)
if( msg == "" then msg = layer else msg = strcat( msg, " ", layer))
);end-foreach
axlMsgPut( "The %s etch layer display.", msg)
);end-if
);end-prog
);end-defun
;# customize shortcut key #
prog( ( n, s, key)
n = 0
while( n < 255
sprintf(key "l%d", n)
sprintf(s "layernumvisible %d", n)
axlSetAlias( key, s)
sprintf(key "L%d", n)
n++
);end-while
);end-prog
