查看: 2955|回复: 18
有沒有像PADS那樣快速定位到器件放大並高亮器件的功能呢
发表于 2011-5-31 00:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
可以考慮用ctrl+F做快捷鍵
    慵懒
    2025-10-23 15:05
  • 签到天数: 639 天
    [LV.9]以坛为家II
    推荐
    发表于 2020-11-10 17:34 | 只看该作者
    lidin 发表于 2011-6-2 09:27
    回复 szc1983 的帖子
    search.il  收藏好多年了,发出来共享给大家
    元件搜索skill  ,不错。
    2025-10-29 15:11
  • 签到天数: 272 天
    [LV.8]以坛为家I
    推荐
    发表于 2017-7-20 09:53 | 只看该作者
    设置快捷键,很方便
    推荐
    发表于 2017-7-19 14:46 | 只看该作者
    下载试试,谢谢分享
     楼主| 发表于 2011-5-31 00:35 | 只看该作者
    allegro找個器件找個網絡都要費老大勁,唉
     楼主| 发表于 2011-5-31 09:36 | 只看该作者
    找到個源程序,這個程序不錯有點不足就是器件放大的不夠大
    不能夠手工輸入器件名稱查找只能從列表定位
    還有就是不能按網絡名搜索
    沒有高亮選項
    ;                       Find Components from List
    ;   This routine will open a form which displays all currently placed
    ;   components. When the user selects a ref des from the list the component
    ;   is highlighted and the working window is resized to the components
    ;   bounding box with 500 drawing units (500 mils) on each side. The "Filter"
    ;   in the form allows the user to select only components beginning with the
    ;   specified character. The "REFRESH LIST" button updates the list with the
    ;   current data taking any filter setting into account.
    ;   To run the routine within Allegro type "find component".
    ;   Written by David J. Scheuring
    ;   Sr. Applications Eng. Cadence Design Systems
    ;   May 31, 1995
    ;   Rev A
    ;   March, 19,2000
    ;   Adjusted behavior of Refresh List button and Ref Des Filter
    ;   Rev B
    ;   June 23,2004
    ;   Adjusted behavior of Refresh List button and Ref Des Filter for use in 15.x release
    ;   Changes
    ;   June 24,2004 - Included changes from Charlie Davies (Harris GCSD)
    ;                 - modified window parameters to work with any DB units.
    axlCmdRegister( "find component" `Find_Component_Routine ?cmdType "interactive")
    ; Set the global variables
    Ref_Des_Filter="*"
    Comp_List=nil
    Placed_List=nil
    (defun Find_Component_Routine ()
    axlDBRefreshId(axlDBGetDesign())
    axlClearSelSet()
    ; Declare variables
    (let (Find_Component_Form Command)
      ; Clear variables
      Find_Component_Form=nil
      Command=nil
      ; Build the placed component list form
      Find_Component_Form=outfile("Find_Component_Form.form" "w")
      fprintf(Find_Component_Form "FILE_TYPE=FORM_DEFN VERSION=2\n")
      fprintf(Find_Component_Form "FORM\n")
      fprintf(Find_Component_Form "FIXED\n")
      fprintf(Find_Component_Form "PORT 25 20\n")
      fprintf(Find_Component_Form "HEADER \"Find Component\"\n")
      fprintf(Find_Component_Form "TILE\n")
      fprintf(Find_Component_Form "TEXT \"COMPONENTS LIST\"\n")
      fprintf(Find_Component_Form "TLOC 4 0\n")
      fprintf(Find_Component_Form "ENDTEXT\n")
      fprintf(Find_Component_Form "FIELD Placed_List\n")
      fprintf(Find_Component_Form "FLOC 2 2\n")
      fprintf(Find_Component_Form "LIST \"\" 21 10\n")
      fprintf(Find_Component_Form "ENDFIELD\n")
      fprintf(Find_Component_Form "TEXT \"Current Ref Des\"\n")
      fprintf(Find_Component_Form "TLOC 2 25\n")
      fprintf(Find_Component_Form "FIELD Current_Ref_Des\n")
      fprintf(Find_Component_Form "FLOC 2 27\n")
      fprintf(Find_Component_Form "STRFILLIN 16 10\n")
      fprintf(Find_Component_Form "TEXT \"Filter:\"\n")
      fprintf(Find_Component_Form "TLOC 2 30\n")
      fprintf(Find_Component_Form "FIELD Ref_Des_Filter\n")
      fprintf(Find_Component_Form "FLOC 10 30\n")
      fprintf(Find_Component_Form "STRFILLIN 5 10\n")
      fprintf(Find_Component_Form "FIELD Refresh_List\n")
      fprintf(Find_Component_Form "FLOC 2 33\n")
      fprintf(Find_Component_Form "MENUBUTTON \"REFRESH LIST\" 15 3\n")
      fprintf(Find_Component_Form "FIELD done\n")
      fprintf(Find_Component_Form "FLOC 2 36\n")
      fprintf(Find_Component_Form "MENUBUTTON \"Done\" 6 3\n")
      fprintf(Find_Component_Form "ENDTILE\n")
      fprintf(Find_Component_Form "ENDFORM\n")
      close(Find_Component_Form)
      ; Generate list of placed components
      axlSetFindFilter(?enabled '(noall components) ?onButtons '(noall components))
      Comp_List=axlGetSelSet(axlAddSelectAll())
    (foreach Item Comp_List
       (if Item->symbol!=nil then
        Placed_List=cons(Item->name Placed_List)
       ); if Item->symbol!=nil
      ); end foreach Item Comp_List
      ; Define the place list form action
      (defun Find_Component_Form_Action_Routine (Find_Component_Form)
       (case Find_Component_Form->curField
        ("Refresh_List"
        Placed_List=nil
        axlClearSelSet()
        Comp_List=nil
        Comp_List_Unfiltered=nil
        (if Ref_Des_Filter == "*" then
         Comp_List=axlGetSelSet(axlAddSelectAll()) else
         Comp_List_Unfiltered=axlGetSelSet(axlAddSelectAll())
         (foreach Item Comp_List_Unfiltered
          (if getchar(Item->name 1) == getchar(Ref_Des_Filter 1) then
           Comp_List=cons(Item Comp_List)
          ); end if
         ); end foreach
        ); end if
         ); end if Item->symbol!=nil
        (if Placed_List==nil then
         axlFormListDeleteAll(Find_Component_Form "Placed_List")
         axlFormSetField(Find_Component_Form "Placed_List" "No Match")
         axlFormSetField(Find_Component_Form "Ref_Des_Filter" Ref_Des_Filter)
         axlFormDisplay(Find_Component_Form)
         axlUIWPrint(Find_Component_Form "No Match")
         else
         Placed_List=sort(Placed_List nil)
          axlFormSetField(Find_Component_Form "Placed_List" Placed_List)
          axlUIWPrint(Find_Component_Form "Select Component")
        ); end if Placed_List==nil
       ); end Refresh_List
        ("Ref_Des_Filter"
         (if Find_Component_Form->curValue == "" then
          Ref_Des_Filter="*" else
          Ref_Des_Filter=upperCase(Find_Component_Form->curValue)
          t
         ); end if
        ); end "Ref_Des_Filter"
        ("done"
         Placed_List=nil
         (axlFormClose Find_Component_Form)
         (axlCancelEnterFun)
         axlClearSelSet()
         axlFlushDisplay()
         axlShell("redisplay")
        ); end "done"
        ("Placed_List"
         axlSetFindFilter(?enabled '(components) ?onButtons '(components))
         Component=axlGetSelSet(axlSingleSelectName("COMPONENT" strcat(Find_Component_Form->curValue)))
         axlHighlightObject(Component)
         window_buffer = axlMKSConvert(500 "MILS")
         Lower_X=car(car(car(Component)->symbol->bBox))-window_buffer
         Lower_Y=car(cdr(car(car(Component)->symbol->bBox)))-window_buffer
         Upper_X=car(car(cdr(car(Component)->symbol->bBox)))+window_buffer
         Upper_Y=car(cdr(car(cdr(car(Component)->symbol->bBox))))+window_buffer
         Command=sprintf(dummy "window points;x %f y %f;x %f y %f" Lower_X Lower_Y Upper_X Upper_Y)
         axlFormSetField(Find_Component_Form "Current_Ref_Des" Find_Component_Form->curValue)
         axlShell(Command)
         t
        ); end "Placed_List"
       ); end case
      ); end defun Find_Component_Form_Action_Routine
      ; Display the form/list
       Find_Component_Form=axlFormCreate( (gensym) "Find_Component_Form.form" '(e outer) 'Find_Component_Form_Action_Routine t)
        axlFormSetField(Find_Component_Form "Placed_List" "No Placed Comps")
        axlUIWPrint(Find_Component_Form "No Placed Comps")
        else
        (foreach Ref_Des Placed_List
         axlFormSetField(Find_Component_Form "Placed_List" Ref_Des)
        ); end foreach Ref_Des Placed_Lis
    ); end let
    ); end defun Find_Component_Routine
    发表于 2011-6-1 17:35 | 只看该作者
    呵呵,早就有这样的SKILL了,可以输入零件序号搜到后放大,还可以搜索NETS
    发表于 2011-6-1 17:38 | 只看该作者
    回复 szc1983 的帖子
    2019-11-20 15:05
    发表于 2011-6-1 18:17 | 只看该作者
    这个方面还是Pads 做的好
    发表于 2011-6-1 19:14 | 只看该作者
    这个功能我有个程序,不过是加密的,没源码。不好共享。
    发表于 2011-6-1 20:58 | 只看该作者
    回复 szc1983 的帖子
    ;之前发过一段代码,现修改成CTRL+FaxlSetAlias( "~F" "skill x_search_net_comp")
    defun( x_search_net_comp ()
    let((db)
        when((obj = axlUIPrompt("\307\353\312\344\310\353\322\252\262\351\325\322\265\304\301\343\274\376\303\373\273\362\315\370\302\347\303\373:" "" ))
            db = axlDBFindByName('net obj)
            unless(axlIsDBIDType(db) db = axlDBFindByName('refdes obj))
            when(axlIsDBIDType(db)
                axlHighlightObject(db)
                axlZoomToDbid(db , t)
                axlShell("zoom out")
    ;www.eda365.com
    x_search_net_comp.zip (460 Bytes, 下载次数: 57)
     楼主| 发表于 2011-6-2 00:04 | 只看该作者
    lidin 发表于 2011-6-1 17:38
    回复 szc1983 的帖子
    这个skill叫啥名字啊
    发表于 2011-6-2 06:03 | 只看该作者
    感谢版主。这次找器件方便多了。
    发表于 2011-6-2 09:27 | 只看该作者
    回复 szc1983 的帖子
    search.il  收藏好多年了,发出来共享给大家 search.rar (1.66 KB, 下载次数: 92)
    元件搜索skill ,不错。  详情 回复 发表于 2020-11-10 17:34
    发表于 2011-6-2 09:29 | 只看该作者
    用法大家都知道把,在相关文件里添加解压后的名字,命令:s
    13#
    发表于 2011-7-4 16:45 | 只看该作者
    感谢“lidin”
    14#
    发表于 2011-12-12 20:35 | 只看该作者
    回复 szc1983 的帖子
    谢谢,不过,新版allegro查找功能没问题,很快很好.
    GMT+8, 2025-10-30 16:19 , Processed in 0.203125 second(s), 33 queries , Gzip On.
