查看: 3447|回复: 0
Orcad capture生成网表时出错,大家帮我看看
发表于 2011-6-12 12:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
大家好,以前用AD6,pads, 与在用SPB16.2,很不习惯呀。
& n# n- K' H' t) H5 f: c) d8 @& b     在做完原理图,DRC检查没有错误后,生成网表时,出现:7 R3 C+ I6 h0 l6 K5 g* @
   #248 ERROR(SPCODD-248): All physical pins are common in section 1 of physical part 'CEJMK212BJ106KD_T'.  Each section must have at least one non-common pin.
0 t! p& e) s" l4 D- C8 u        Open the part in Part Developer and ensure that you have at least one non-common pin for each section of a physical part./ e+ b( v* V8 w; F. T9 D
      我检查了原理图SYMBOL和PCB封装,也换另外的PCB封装试了试,错误依旧。/ M9 r) M& r  K0 `/ H) Q
  大家帮我看看,是什么原因呀。
$ e% U% |. g  Q) c1 k8 D7 F    我在画原理图时还碰到其它的问题:* a* n  P( M* ~* S5 M
      1:元件编号如电阻电容之后,总自动出现一个A或是B,  如:R120A
$ [& n0 b6 @$ c4 P% P      2: 在COPY一个元件到另外一个地方去时,本应每COPY一次编号都自动增加,可现在是每COPY两次,编号才自动增加一次。
$ A# y1 h0 s* f0 m; _; l     原理图工程我加在附件里了,大家可以打开F3文件帮我看看。* H5 n+ o- v& s4 X
     为方便大家检查,我把生成网有的出错贴在下面了:
- \3 f* O6 q# R# l+ H: x# t      ********************************************************************************8 s6 D/ h; T: J" O8 a
Design Name:" |6 W! U  o; t( c) H& U' b
E:\Hi3515FJ_cadence\hi3515fj.dsn
& u* E: Y( H" S5 _2 ?Netlist Directory:
: s9 p, `, F4 y. X# qE:\HI3515FJ_CADENCE\NETLIST
  h+ d. K; y+ |* T& ~: XConfiguration File:
  j! @0 p: @9 N! I3 G" r% lD:\Candence\SPB16.2\tools\capture\allegro.cfg
! {+ P. o; i/ r% k+ \& ?" o% USpawning... "D:\Candence\SPB16.2\tools\capture\pstswp.exe" -pst -d "E:\Hi3515FJ_CADENCE\hi3515fj.dsn" -n "E:\HI3515FJ_CADENCE\NETLIST" -c "D:\Candence\SPB16.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint", M8 ?$ S$ {+ y8 E( M% \( |
#1 Warning [ALG0016] Part Name "PHONE JACK-4_0_PHONEJACT_4_PHONE JACK-4" is renamed to "PHONE JACK-4_0_PHONEJACT_4_PHON".  {7 X- I. z: t- O. H
#2 Warning [ALG0016] Part Name "SN74CBT16214_0_SOP56-20-250-550_SN74CBT16214C" is renamed to "SN74CBT16214_0_SOP56-20-250-550".8 \) f6 o& v- y
Scanning netlist files ...4 ^% J$ N) X$ i( w+ s; }" Q
Loading... E:\HI3515FJ_CADENCE\NETLIST/pstchip.dat+ d+ c2 S1 M/ j9 U$ ^; u
#248 ERROR(SPCODD-248): All physical pins are common in section 1 of physical part 'CEJMK212BJ106KD_T'.  Each section must have at least one non-common pin., R. g3 \' j' R" {! o. B1 v/ _
        Open the part in Part Developer and ensure that you have at least one non-common pin for each section of a physical part.) y% O# _4 r& p# y( ]
              ERROR(SPCODD-47): File E:/HI3515FJ_CADENCE/NETLIST/pstchip.dat could not be loaded, and the packaging operation did not complete. Check the pxl.log file for the errors causing this situation and package the design again.
% P# i/ `5 \& C#53 ERROR(SPCODD-53): Packaging cannot be completed because packaging has encountered a null object ID. The design may not have been saved correctly. Save the schema8 L  p( W5 W/ j# K4 U' D& K$ B
tic and rerun packaging.
* E+ M- I* E! `  ~  W2 G$ N* f  S#3 Error   [ALG0036] Unable to read logical netlist data.
/ S- F1 m+ ?7 f  ~% pExiting... "D:\Candence\SPB16.2\tools\capture\pstswp.exe" -pst -d "E:\Hi3515FJ_CADENCE\hi3515fj.dsn" -n "E:\HI3515FJ_CADENCE\NETLIST" -c "D:\Candence\SPB16.2\tools\capture\allegro.cfg" -v 3 -j "PCB Footprint"
, ]3 w, Q) D) R; [
& ?% A5 `; _6 F$ C3 S1 t*** Done ***
GMT+8, 2025-7-6 08:13 , Processed in 0.109375 second(s), 24 queries , Gzip On.
