; W+ C5 s, B1 k7 s" J
4 h% n* g" z1 e# U这样的一个网络表,我们应该注意哪块?我个人感觉
4 k3 ]5 L5 _0 g. ~' m; g+ tcadence Design Systems, Inc. netrev 16.2 Thu Jun 30 09:25:40 20110 B" ~ ^) ~, I6 z
(C) Copyright 2002 Cadence Design Systems, Inc.: Y2 V$ L. V3 Z9 O
------ Directives ------————————————这个是不是就是一些信息类的,是不是可以不看?(1)
/ e8 r4 E- i. Z, i$ _! KRIPUP_ETCH FALSE;8 g' v5 t+ j+ e1 `) h
RIPUP_SYMBOLS ALWAYS;
. x9 u1 q! p" P* e- jMissing symbol has error FALSE;$ t7 I2 L! d% y# r# e
SCHEMATIC_DIRECTORY 'E:/WORK/飞尚气体检测项目/甲烷气体监测/硬件原理图及PCB';) T* A# @- g2 i1 _2 U' S" C
BOARD_DIRECTORY '';
0 Y1 x; L2 l9 _2 _) I# U8 ^OLD_BOARD_NAME 'E:/Gongzuo/cadence/FAS_PCB_library/Pcb_lib(new)/text/demo_brd.brd';) f& r1 h$ C; ~ n2 D4 \4 \1 [
NEW_BOARD_NAME 'E:/Gongzuo/cadence/FAS_PCB_library/Pcb_lib(new)/text/demo_brd.brd';
; l8 m3 k. `+ {& qCmdLine: netrev -$ -i E:/WORK/飞尚气体检测项目/甲烷气体监测/硬件原理图及PCB -y 1 E:/Gongzuo/cadence/FAS_PCB_library/Pcb_lib(new)/text/#Taaaaaa02400.tmp
( o' p ^1 E2 J) m) S6 \------ Preparing to read pst files ------——————————这个部分是不是专门来看错误的地方吧(2)
$ w& B b. U' A/ `7 Z2 v
+ Y3 h. T- H7 s#1 ERROR(24) File not found
4 Y4 Q9 l" v$ Z1 T) l7 z- _5 I Packager files not found" i- A3 M# p- L+ {. j
#2 ERROR(102) Run stopped because errors were detected——————————是不是就看这两个就可以啊?(3)
, b3 I8 i) x8 w. v* Vnetrev run on Jun 30 9:25:40 2011# W. ?$ a# i7 n8 J
COMPILE 'logic'
5 e$ T# M+ ]! d0 Z CHECK_PIN_NAMES OFF
9 p2 U2 P: k" I CROSS_REFERENCE OFF8 Y/ o5 m9 h& Q* t4 B4 R
FEEDBACK OFF5 s" D) } P2 T8 d
INCREMENTAL OFF
, K( n5 p3 [( F2 n( z INTERFACE_TYPE PHYSICAL
) k1 S! }! n" l# B. V$ O, M MAX_ERRORS 500
& } W" X; L& t+ p4 y4 ? MERGE_MINIMUM 5# F* P; D1 ?& M
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
/ r' J5 M4 U" K( W NET_NAME_LENGTH 24
& J# _* u v% y3 t' z- Q4 \ OVERSIGHTS ON
% w* F# T2 G1 f- o/ v* P REPLACE_CHECK OFF
p: [) ?8 Q/ J0 L9 h* t& h SINGLE_NODE_NETS ON
. R7 y% r A6 t3 k SPLIT_MINIMUM 0
: u8 J" @2 [/ W# F" m8 h% j, l SUPPRESS 20% w8 M. X& s, Z" I" _
WARNINGS ON/ B1 T) ^) O: b: H8 C7 R# J; g4 K
2 errors detected& C& W6 [3 m. x: e5 V- @
No oversight detected
. H) p( M3 k1 @: fNo warning detected6 Q8 M' |1 ~8 k2 T& x
cpu time 0:00:29
* r# o: _; J; j+ Welapsed time 0:00:004 n- N* O- N) Q" I; L
哪位高手知道这个错误是什么原因造成的?不吝赐教,不胜感激!!!
& L: O, k( X, J K! o/ z3 ^2 b1 B. X9 O% j) s/ N
