, o8 c- d2 R& B" ~8 A% o& b3 ]7 u0 F; H' h- u% [; ]
大家好,我是新手用allegro 15.7 导入网络时出现以下提示,不知道错在哪,请教各位高手帮忙解决.
5 H( ^) e) l% I. V( Q" O
. h- f5 S5 V- i6 p
cadence Design Systems, Inc. netrev 15.7 Fri Jul 08 15:35:43 2011
4 o; ?) C' R' Q, K3 v(C) Copyright 2002 Cadence Design Systems, Inc.) _% ?* C1 a9 u# R- v
------ Directives ------$ ]: o' U3 _+ l' ^- S' E
RIPUP_ETCH FALSE;# b6 Y2 a; X' E" a
RIPUP_SYMBOLS ALWAYS;4 Y- s; V p* w3 j! ^
MISSING SYMBOL AS ERROR FALSE;& x* C- T. j# c
SCHEMATIC_DIRECTORY 'E:/GG WORK FILE/MID/T1/ALLEGRO';
% O+ @( e* W0 y- b7 IBOARD_DIRECTORY '';; K% _: I- U2 ]" K+ |( D* w! G
OLD_BOARD_NAME 'E:/gg work file/MID/t1/MID7019-256M-BMP-140-R258-V2.1-0429-1000.brd';- R7 c% O. |' `$ Y7 ^
NEW_BOARD_NAME 'E:/gg work file/MID/t1/MID7019-256M-BMP-140-R258-V2.1-0429-1000.brd';8 |# L# D. K% ]' S, K' @
CmdLine: netrev -$ -5 -i E:/GG WORK FILE/MID/T1/ALLEGRO -y 1 -z E:/gg work file/MID/t1/#Taaaaaa03156.tmp
( L9 i! E; L' S+ ^4 S7 ~------ Preparing to read pst files ------
% e6 U3 z* K% XStarting to read E:/GG WORK FILE/MID/T1/ALLEGRO/pstchip.dat # U$ O& d" n) F1 A$ m- @& F. v. o
Finished reading E:/GG WORK FILE/MID/T1/ALLEGRO/pstchip.dat (00:00:00.03)8 m/ C/ l' J5 ?; w* t
Starting to read E:/GG WORK FILE/MID/T1/ALLEGRO/pstxprt.dat % f1 o- x6 b& b0 }
Finished reading E:/GG WORK FILE/MID/T1/ALLEGRO/pstxprt.dat (00:00:00.04)
2 C$ i( H- {: c6 B2 y: N% }Starting to read E:/GG WORK FILE/MID/T1/ALLEGRO/pstxnet.dat % s: V: G/ b# L2 K ]
Finished reading E:/GG WORK FILE/MID/T1/ALLEGRO/pstxnet.dat (00:00:00.04)6 `! L' B- f3 O# K g: h( s6 ]
------ Oversights/Warnings/Errors ------
+ h. T; _/ _- r; ?5 q8 q- }
9 U1 C7 I4 k. V$ q/ K p0 m; e#1 ERROR(102) Run stopped because errors were detected# C0 u/ K" [9 {
netrev run on Jul 8 15:35:43 2011
1 d9 t; v2 E; `& x/ g DESIGN NAME : 'MID7_256M_7INCH_V01'! Q* ~ D/ y6 r1 X
PACKAGING ON May 28 2006 22:05:31
3 }# N" }1 x. i COMPILE 'logic'4 G# ~/ b3 j4 d: G4 |' I
CHECK_PIN_NAMES OFF
, n& v$ k% m3 C" A( X CROSS_REFERENCE OFF
* ?8 z }# Y9 |0 P+ X FEEDBACK OFF
/ |. \6 ^; A, {. G/ ]6 l* g1 H INCREMENTAL OFF, V: @( S$ ~# K
INTERFACE_TYPE PHYSICAL
1 ^' L9 W- b2 }* h! d) r MAX_ERRORS 500$ B$ _0 s. q: `
MERGE_MINIMUM 5- \( V& D/ f) x
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'
& b, A f/ M+ Q; R5 B* v NET_NAME_LENGTH 24- Z ^ q* X: C* L) J1 ?
OVERSIGHTS ON
& n* g/ M+ N0 W' _ REPLACE_CHECK OFF
7 f: P. ]$ y4 e* |" q9 g; r7 ~ SINGLE_NODE_NETS ON
2 a8 E$ x7 ~. [# V1 b% ?9 {8 a* [ SPLIT_MINIMUM 05 a8 r) _: ]5 U5 {2 L( u6 o
SUPPRESS 20
X& x; F3 C1 \0 J5 v WARNINGS ON; t# _& O2 b, Q) p
1 errors detected4 _; H" F* B0 F$ Z
No oversight detected! M0 m* B+ B8 \2 {! X# k9 q
No warning detected
0 b/ j% g: {5 ecpu time 2:44:53
4 j7 ~ a! J0 E( ?4 Welapsed time 0:01:39$ v* V8 [1 ?1 h) K" D* p
+ [ v, b1 q: I |
