回复 art_li 的帖子( j! H+ u+ e! k: o: O" \! k
5 y1 G7 C( ~3 m6 O
1. 找个你allegro的allegro.men,打开,在后面加一个你要菜单.& F! D! S3 A9 J) p% \
eg. X# v) x5 p3 i7 v, ]
POPUP "&Skill"
8 X& h% q$ _0 U" t: Y/ S, m BEGIN
. N) L A/ n: z/ P MENUITEM "Align symbol", "xasym"3 M0 b i$ v1 E- p# C
MENUITEM "Align_text", "align_text"
' T, W2 k3 u5 z MENUITEM "Assign_via_net", "cvia"+ ^& G$ V- u/ D; t5 H4 W
MENUITEM "Change_Origin", "co"0 e1 ?# H' j3 `( U' _' A2 h
MENUITEM "Check no_reference", "ch_noref"
1 k2 a* L; S8 |0 y MENUITEM "Check over_test", "ch_text_overlap": y5 l) P4 C- [8 ?; C
MENUITEM "component compare", "component_changes"! ~! g# ?: t) n n
MENUITEM "Display no-testpoint", "hl_ntp": w7 Z6 I2 m' b7 x+ |$ _' e" Q
MENUITEM "Delete_isolating_vias", "del_via"
$ h W- V( C$ ~# j) d3 H0 S MENUITEM "Export pad", "dumplib"
% M+ L5 Q7 j* X7 V MENUITEM "Find Dang Line", "find_dang"
0 f5 \, b* p9 _: @7 q9 @8 U MENUITEM "Hil_null_pin", "hl_pin"4 }2 d% E7 c1 y& u# k( j
MENUITEM "In out Text", "T"% ?8 ?- w# |" x7 h( t
MENUITEM "Mil<->MM", "cale"
9 _# n: m6 t* d0 V+ D, O MENUITEM "cut_shape", "split_shape"; G! q: |* g3 s
MENUITEM "silk_in", "silkin"" W: Y/ y- V& L( W/ i1 U7 f
MENUITEM "silk_out", "silkout"
( g6 ]* ]# i* x5 P( W/ F( J" @; @ MENUITEM "Xpage", "skill xrfin") C6 u/ S j( g1 L/ W+ K$ [
2 J: N( [; z6 H8 l( |, h5 k END
+ _6 x1 p) h! A% y5 d3 l$ s0 K$ @- w2.你要加SKILL在这个菜单下的话,就直接在这个下面加
+ u- w3 C( E3 L- ]6 q! l+ q" MENUITEM "Align symbol", "xasym"" eg. Align symbol 这个名字就是见名知意的符号, "xasym" 这个就是这个SKILL 会去你加载的地方allegro.ilinit(load("xasym.il"))和放SKILL地方(setSkillPath(buildString(append1(getSkillPath() "D:/pcbenv/skill")))
& p* W( O3 g. x& p9 x调用.
" j8 I9 o. j* p1 f4 B; ~3.重新开板子 就可以了。 9 r7 `4 [$ A$ g `$ K' Y5 \9 |
9 S5 t& K! {' }& [8 p" _8 G! @
