TA的每日心情 | 慵懒 2019-11-18 15:01 |
签到天数: 1 天 [LV.1]初来乍到
原本功能是via會有top的shpae覆蓋
想要改成所有的via挖掉白漆shape
請問高手該怎麼改?
謝謝!
axlCmdRegister("gsd" 'gnd_shape)
defun(gnd_shape ()
let((via_p via_net shape_Radius via_drill via_Broad Geometry/Silkscreen_top poly_via)
axlClearSelSet()
axlSetFindFilter( ?enabled '( "NOALL" "vias") ?onButtons '("vias"))
LCBpopup = axlUIPopupDefine( nil (list
(list "Done" "axlFinishEnteRFun()")
(list "Cancel" "axlCancelEnterFun()")
axlUIPopupSet(LCBpopup)
while(axlSelect(?prompt "Please select via")
foreach(via axlGetSelSet()
via_drill = via->definition->drillDiameter/2
via_net = via->net->name
via_p = via->xy
foreach(pad via->pads
when(pad->layer == "via_Broad Geometry/Silkscreen_top" && pad->type == "REGULAR"
via_Broad Geometry/Silkscreen_top_pad = caadr(pad->bBox)
);end foreach
shape_Radius = (via_Broad Geometry/Silkscreen_top_pad - via_drill)/2 + via_drill
poly_via = axlPathStartCircle(list(via_p shape_Radius) 0)
axlDBCreateShape(poly_via,t,strcat("via_Broad Geometry/Silkscreen_top"),via_net)
);foreach
);while
);end let
);defun
