查看: 3650|回复: 1
光绘文件无法提取出来,请帮忙看看是什么错误?
发表于 2011-8-23 11:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  FILM PARAMETERS :
( W. c/ m% G8 C. f. p  ---------------------------------------------------------# L5 V( ?1 b- @9 u+ c( X
  Undefined line width                0.0000
2 m( \8 S2 m$ K% i  Mirror code                         NONE* m7 o8 W* S5 P! k) S9 X
  Rotate angle                        NONE
6 n+ J/ Y1 C, ~" q  Offset x:                           0.00007 Y5 E' {$ }9 ?( o5 T
  Offset y:                           0.00001 h4 o9 z5 M" I2 F6 O
  Plot negative                       NO/ \1 i0 V( N5 E2 a" r' e5 |
  Suppress unconnected internal pads  NO8 v1 L! c+ s9 p& \  `- J* a
* @# k2 k2 d( C* I    WARNING: text composed 0 width line found at (81.9150 117.1448)% C! ?( B$ M) k0 p9 O
           ... ignored!
* r' a7 m/ Q  ?
4 Q% q; P6 }5 z& @! n* g# Z4 Q    WARNING: text having Multiple 0 width lines; all will be treated the same as the first.
: a' W( `: g2 ^+ ]* z2 F6 Q           ... ignored!6 X  i2 r- [$ d0 d
) R) q( v, |  ]- w$ i
    WARNING: rectangle or unfilled shape having Multiple 0 width lines; all will be treated the same as the first.
4 m& f) |5 t2 D0 @9 I; r7 p           ... ignored!5 i0 v0 A+ N+ w" e
2 ?# C/ ~. x: X8 C- e+ m; i/ ^
; S4 l8 T! m; z: R. ?    ERROR: aborting film - Shape with first seg=(158.6992 10.4140) [layer=(null)]
& v2 T9 S/ y8 Q$ V2 A% v        has a void with extents [(160.6042 2.7940) (166.3192 9.1440)] that touches
, W) y8 h: ^: w) I8 J* T        another shape with first seg=(158.6992 10.4140). Manually resolve problem.
/ v, f8 i7 k# v' @2 D; o$ S: |" y2 j9 ]
    ERROR: aborting film - artwork will not be generated!
8 c- j5 O; o  }$ q6 D- g  A Error in SILK_TOP--halting output.  Artwork file not generated.3 x; J5 X. ^7 Q; h/ R" ^, L
*** ERROR with SILK_TOP
发表于 2011-8-23 13:19 | 只看该作者
aborting film - Shape with first seg=(158.6992 10.4140) [layer=(null)]   建议在主板上找到坐标(158.6992 10.4140) 处,修一下那个地方的shape ~  就ok了
7 {5 ~' q1 M4 Q+ m! T, q
GMT+8, 2025-7-19 13:36 , Processed in 0.109375 second(s), 24 queries , Gzip On.
