我在用allegro导入网表时出现下面错误,请问怎么回事?如何解决?高手指点,谢谢
2 C5 G- p2 L$ d--- Preparing to read pst files ------* B0 N( E/ D( `" T8 l
/ K4 n: Q+ r; n6 b" x) ?
# x/ {# R$ p+ J1 E) p+ P#1 ERROR(24) File not found
+ `7 y) k& ]% t# l4 \' y Packager files not found# s( Q7 o1 Z& `( _0 `( n- z
7 x0 R( L' U6 @4 s: J* o. W5 w" }. N
#2 ERROR(102) Run stopped because errors were detected( X# k1 _ _; Y3 g$ Z
7 H5 f1 `1 V0 D# }& ]netrev run on Aug 24 18:05:55 2011
) ^! o, X; a0 I/ ^/ Y: R
- N. Y& R$ j+ G8 h COMPILE 'logic'6 ?& V3 D# G. K2 o9 }
CHECK_PIN_NAMES OFF1 x6 [0 w( U3 F6 r4 Q& }' N
CROSS_REFERENCE OFF. p0 e5 P, h f5 w) m
FEEDBACK OFF/ f5 `8 O1 e4 `5 [1 R2 [
INCREMENTAL OFF
6 d$ A( g8 R: e o) C$ j t INTERFACE_TYPE PHYSICAL5 Z3 m9 q: A' i3 Y9 K
MAX_ERRORS 5008 f- o. L" O+ b9 D) f: h
MERGE_MINIMUM 5) y1 h. x+ W4 i2 i8 _0 N
NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'7 E- k' F7 P3 O1 c4 m& p! b2 L
NET_NAME_LENGTH 24
+ i" x6 M* g& L$ G i' [ OVERSIGHTS ON
8 z% B: w9 ~5 E8 ]+ m REPLACE_CHECK OFF
2 y6 T- g1 j: @" J* {' v9 l SINGLE_NODE_NETS ON4 m: C8 U& z `4 Q
SPLIT_MINIMUM 0
8 X- ]: Z5 j4 f# H- D. t7 \9 r SUPPRESS 20
, n' J) t0 B, ^9 J WARNINGS ON
5 M- B( |; s5 w; Y" N6 R8 a3 } G+ [- G4 a9 t( D- w( @6 p% x
2 errors detected
4 W# c" p( |1 D; s No oversight detected
( V g; e0 f0 n8 u No warning detected |
