查看: 481|回复: 4
cadence allegro17.2 从原理图向PCB导出设计时(export physical),报错
发表于 2022-2-11 09:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Error: Schematic supports automatically creating XNets using DML but the Layout will not automatically create any XNets. Change setting in Layout or Schematic, re-generate files, and re-run the flow.' v7 A  f1 j* ~. m8 S- S$ V
发表于 2022-2-11 11:11 | 只看该作者
这个错误是指原理图中支持自动创建Xnets,但是PCB中不支持自动创建Xnets,所以更改PCB或者原理图的设置,然后再生成一遍网表。
发表于 2022-2-11 11:13 | 只看该作者
Add the following to your <normally home folder>/PCBENV/ENV file:  set CDS_XNET_STATE_UI=15 c- N; r2 @/ Q
" j) C9 c  B- ~Restart the tool and open Constraint Manager
9 }6 }  {6 B* ^5 `8 Y! e3 V5 S6 I1 n  _
In Constraint Manager, select Tools > Options and enable the option "Create XNets and Differential Pairs using DML Models "
  X- q8 c, J) q: }+ M/ t" `, c. t
' T; Z" w1 S2 ]* I! X' _/ DSave the design to a new name and try running the flow again.
2 z. \4 w" ?5 R# ~8 L$ x
  `' ^5 l$ G- |" I0 D9 CI intentionally stated to save the design to a new name so you have a back-up before making any changes running the flow. :-)1 @, x% p8 i' b1 g- T- U7 B7 R9 b% B
; I$ [' u/ M1 |- H+ ^# {; \
NOTE: If there are any XNets that are auto-generated in the design, without DML assignments, they will be removed after running the flow. (It sounds like you don't have any XNets anyway but I figured I would mention it)
% ~3 f$ N" g/ s; N- |
发表于 2022-2-11 13:20 | 只看该作者
下一次再导线路会不会自己更改现有的constraint设置9 N1 |( L, G. \& d8 q5 Y$ s; D( P9 L
发表于 2022-2-11 14:10 | 只看该作者
想知道别人是怎么说的' `, @; r4 j# t" Y
GMT+8, 2025-9-13 16:16 , Processed in 0.125000 second(s), 23 queries , Gzip On.
