查看: 12574|回复: 3
这些警告是什么意思?(求助)
发表于 2011-8-31 17:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
------ Oversights/Warnings/Errors ------
* u6 C: N& s. ?
1 N6 E2 Y1 J5 D* R" Q+ j% K0 Y' i
#1   WARNING(SPMHNI-192): Device/Symbol check warning detected.* @6 [2 [$ Y  S. M) U( ~
: y! B9 Q+ L* i" V2 u
WARNING(SPMHNI-194): Symbol 'C1000UF' for device 'C_C1000UF_1000UF' not found in PSMPATH or must be "dbdoctor"ed.
7 l& |5 \5 m# j5 S
7 ]; ?( d- O! M8 X  s4 E1 r#2   WARNING(SPMHNI-192): Device/Symbol check warning detected.
# Y. f; H$ E* N1 [8 |0 K0 x! E, c$ E7 }* p
WARNING(SPMHNI-194): Symbol 'HOLD118C197' for device 'HOLD_HOLD118C197_HOLD' not found in PSMPATH or must be "dbdoctor"ed.
8 F. b: `2 c$ K9 {4 N& E
$ p; M/ Y9 a* k" R#3   WARNING(SPMHNI-192): Device/Symbol check warning detected.
7 o9 k5 a! N: M- X1 k& Y, j7 w
& R, E9 ~0 b+ M! ~WARNING(SPMHNI-194): Symbol 'CON2' for device 'J2_CON2_J2' not found in PSMPATH or must be "dbdoctor"ed.
5 I, U4 c2 ?( P  D. z4 H/ M) @
( o. V9 C) o# l1 U# y* N9 X. \/ f#4   WARNING(SPMHNI-192): Device/Symbol check warning detected.3 ^6 ?6 }7 i! R3 c5 w3 l8 e
' k% F. b) N3 D' B" W' ?
WARNING(SPMHNI-194): Symbol 'L100UH' for device 'INDUCTOR_L100UH_100UH' not found in PSMPATH or must be "dbdoctor"ed.
" S( X% n; `, ]; ~2 W* y+ V  V( N6 \9 u" K* Q" V. i
#5   WARNING(SPMHNI-192): Device/Symbol check warning detected.' ?2 o; n6 B" s; B7 ^+ t6 F
1 ?- ^5 L" b% ]% G7 U- F9 R
WARNING(SPMHNI-194): Symbol 'SMCTVS' for device 'TVS_SMCTVS_TVS' not found in PSMPATH or must be "dbdoctor"ed.
9 i: e* D; E" f# U  e; @% o& H9 q, s
* [1 S0 c% A" L#6   WARNING(SPMHNI-192): Device/Symbol check warning detected.
( C) W! Z7 o$ c" s! u- ]& k) [# W: I, v
2 @- ]6 O6 D/ b! x1 [! @) _WARNING(SPMHNI-194): Symbol 'SMCTVS' for device 'TVS_SMCTVS_TVS_15V' not found in PSMPATH or must be "dbdoctor"ed.- b. p: |: F, @- k/ z5 j: h
/ q# L3 L" f1 a#7   WARNING(SPMHNI-192): Device/Symbol check warning detected.
6 _' s6 _0 _2 f; t$ `. A4 b: V7 |" X& `; d
WARNING(SPMHNI-194): Symbol 'DF06' for device 'DF06_DF06_DF06' not found in PSMPATH or must be "dbdoctor"ed.
/ T0 {+ S. B* m
3 W" b8 u) U+ i0 @0 A) {/ u#8   WARNING(SPMHNI-192): Device/Symbol check warning detected.
, V4 B' \3 j* D; J* e5 L# g- H4 N, r' m& D% }! g
WARNING(SPMHNI-194): Symbol 'IN5822' for device 'IN5819_IN5822_IN5822' not found in PSMPATH or must be "dbdoctor"ed.8 }" ?3 B. o: `: [1 N
2 d* }9 c+ Y. x: @3 C( m- P8 d
#9   WARNING(SPMHNI-192): Device/Symbol check warning detected.3 z0 B, G' d  i+ G, \
! ?% y. w. h% k; g4 tWARNING(SPMHNI-194): Symbol 'JZ-DCDC' for device 'JZ_DCDC_JZ-DCDC_JZ-DCDC' not found in PSMPATH or must be "dbdoctor"ed.! H- D: S+ s( o- i: ?  o# k
! M  V: n% d, o: \( q; N#10  WARNING(SPMHNI-192): Device/Symbol check warning detected., l; t2 w+ ]) C  ]
& {  E( R" L( y5 \: p6 b6 h
WARNING(SPMHNI-194): Symbol 'PQFP64' for device 'MSP430FX1XX_PQFP64_MSP430F1611' not found in PSMPATH or must be "dbdoctor"ed.
, y) w. s4 H9 f2 E/ v3 j% G) P4 g1 P# o5 t
#11  WARNING(SPMHNI-192): Device/Symbol check warning detected.1 A8 D4 Z) M$ I4 q  P# C- G
2 w$ f, h, A4 t) PWARNING(SPMHNI-194): Symbol 'SIP3' for device 'CON3_SIP3_CON3' not found in PSMPATH or must be "dbdoctor"ed.
: y8 i+ S+ {% r6 u0 g8 H+ y( I
& L/ d) E: t7 K#12  WARNING(SPMHNI-192): Device/Symbol check warning detected.2 P( i' }' V, Z( S7 Y
4 v5 A7 X1 e$ H4 c/ x7 s
WARNING(SPMHNI-194): Symbol 'DIN32' for device 'CON32_DIN32_CON32' not found in PSMPATH or must be "dbdoctor"ed.& y8 y$ a. B9 q" |9 F, _
这些问题是没有对应的封装吗?请高手指教一下!!!
# J; n# d* E, p7 q; T9 j" u( E# i/ v, e
发表于 2011-8-31 17:15 | 只看该作者
" not found in PSMPATH  "  确认在psm路径下有相应的psm文件
 楼主| 发表于 2011-8-31 17:16 | 只看该作者
art_li 发表于 2011-8-31 17:15 * a. L+ j( }$ ]. Z; A$ Q
: h$ F# J) |" F/ I2 g8 dxiexie
发表于 2011-8-31 18:08 | 只看该作者
封装库 没有对应封装文件。
GMT+8, 2025-7-21 09:17 , Processed in 0.140625 second(s), 24 queries , Gzip On.
