查看: 1242|回复: 2
ibs转换 dml 模型时 出现 messages 求解
    2025-7-21 15:00
  • 签到天数: 85 天
    [LV.6]常住居民II
    发表于 2011-9-15 09:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
    4 n& J5 e7 V! ]' S( W: t5 oRUNNING IBISCHK COMMAND: ibischk4 "\SignalPartLib\Xilinx\virtex2.ibs\SignalPartLib\Xilinx\virtex2.dml"
    % K: x$ E# i/ [; s* n- MIBISCHK4 V4.1.15 J  T5 {5 v! J' |! d* u9 t" f
    ERROR - File Name Requires '.ibs' Extension.
    0 V8 H. M5 H* }8 n5 ]1 Q! ^  w- z7 S# U, e! o8 n9 Z2 x* X/ b
    END OF IBISCHK COMMAND OUTPUT
    6 o/ [4 P9 c* U. wCould not open the file \SignalPartLib\Xilinx\virtex2.ibs\SignalPartLib\Xilinx\virtex2.dml
    , w# a& X* h% E, O3 A( |. P1 i% ?+ ~; I' Q6 q; H
    RUNNING DMLCHECK for \SignalPartLib\Xilinx\virtex2.ibs\SignalPartLib\Xilinx\virtex2.dml.dml2 C9 R* Q& x0 H+ S: C( h
    5 f) Y3 H' A  K8 W5 P6 ~
    # _0 W+ v3 r6 H6 i* nTranslation failed due to IBIS2DML errors., y5 W5 f1 }/ g) a1 ~9 b
    Output saved as \SignalPartLib\Xilinx\virtex2.ibs\SignalPartLib\Xilinx\virtex2.dml.dml.txt.
    5 |* g& m9 u0 M! B  H2 eRun ibis2signoise -d, a DML will be generated.
    " _1 m7 C5 d; U: q6 AExamine it with line numbers from the log message.
    9 O6 z8 \% N9 h 这是 哪里出错了...
    发表于 2011-9-16 07:18 | 只看该作者
    ERROR - File Name Requires '.ibs' Extension.( [1 H; r6 M2 R/ \# Q
    源文件后缀名不对,要求*.ibs格式....
    2025-7-21 15:00
  • 签到天数: 85 天
    [LV.6]常住居民II
     楼主| 发表于 2011-9-16 10:37 | 只看该作者
    了解谢了
    GMT+8, 2025-7-22 03:57 , Processed in 0.109375 second(s), 24 queries , Gzip On.
