查看: 3777|回复: 1
生成网表出错
发表于 2011-9-17 19:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
看了于博士的视频,想把某一页的原件快速放到pcb上,添加page 参数,设置page参数,按照视频上的 ,设置输出网表参数。. x, H7 O, \5 }* t$ n, a. V
出错了。
' f- ?/ n0 l0 s% ]3 H, `   以前能够正常输出网表。  那个大侠能帮忙啊: Y+ B3 i$ [# l3 d8 m  X
   session log的内容如下:- x2 Q) h6 a% z
Design Name:  v: R' D- g1 @% h% V+ w
G:\lianxi\DSP\dsp.dsn- a$ e% ~* f& J: \1 ]- D+ m% w# h
Netlist Directory:
4 d& w* B8 `/ ~/ ?( d1 UG:\LIANXI\DSP\allegro_PAGE* A( t8 j9 z( \1 j& u! n
Configuration File:
; H! y1 K  O7 rD:\cadence\SPB_16.3\tools\capture\allegro.cfg
5 p- _' c$ R) x9 N6 r  [/ i7 |
' [$ n2 z6 r0 |" N  mSpawning... "D:\Cadence\SPB_16.3\tools\capture\pstswp.exe" -pst -d "G:\lianxi\dsp\dsp.dsn" -n "G:\LIANXI\DSP\ALLEGRO_PAGE" -c "D:\Cadence\SPB_16.3\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint"
1 h& f7 v  k3 g#1 Warning [ALG0051] Pin "GND" is renamed to "GND#1" as visible power pin of same name already exists in Package AUDIO_RJ , J6: SCHEMATIC1, OPA_BUF (360.68, 53.34).
# i; R9 ]4 _9 H- M" F# ^5 F" C7 _#2 Warning [ALG0051] Pin "GND" is renamed to "GND#6" as visible power pin of same name already exists in Package AUDIO_RJ , J6: SCHEMATIC1, OPA_BUF (360.68, 53.34).
" K$ \3 \: f, G#3 Warning [ALG0016] Part Name "SW PUSHBUTTON-DPST_RESET_DSP-RESET" is renamed to "SW PUSHBUTTON-DPST_RESET_DSP-RE"./ C- d& V# F9 M+ M3 f% J7 E3 n
#4 Warning [ALG0016] Part Name "TMS320C6713GDP_BGA272DSP_TMS320C6713GDP" is renamed to "TMS320C6713GDP_BGA272DSP_TMS320".
8 J- z5 F) a7 j( m( |6 W#5 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U6.$ r2 ]) X8 u7 p" f
              PAGE
! `: X, P  T" e7 G#6 Error   [ALG0013] Conflicting values of following Component Instance properties found on different sections of U6.
/ |& T- x% c* _' Z' i/ n& c9 w              PAGE4 X6 ]* g. R) k7 [6 R0 C7 b2 [# Q
#7 Aborting Netlisting... Please correct the above errors and retry.
; h+ G( b' d: l7 S$ ^" ^$ w, z+ V8 ]; s% {7 w* q5 _2 R( p# k, c- g4 O
Exiting... "D:\Cadence\SPB_16.3\tools\capture\pstswp.exe" -pst -d "G:\lianxi\dsp\dsp.dsn" -n "G:\LIANXI\DSP\ALLEGRO_PAGE" -c "D:\Cadence\SPB_16.3\tools\capture\allegro.cfg" -v 3   -l 31 -s "" -j "PCB Footprint"
; }6 U! v/ k& ~4 d5 ^( J4 v9 H- [7 F7 e, t1 W0 G
( \6 j; T6 }1 I*** Done ***! H8 G* k$ @) m8 |5 L
发表于 2011-9-17 19:45 | 只看该作者
U6不同部分发现相互冲突的元件实例属性?, Q0 ^: d. |. E
大概你是层次设计的吧?
0 z" w& Y1 n; q9 d$ ], F" T8 H我没用过层次设计,不大了解啊。
GMT+8, 2025-7-22 04:13 , Processed in 0.125000 second(s), 24 queries , Gzip On.
