鼠儿果 发表于 2011-9-21 16:55 ![]()
+ j8 J( i( o, }* B* r% h& {0 K出光辉不需要添加photoplot outline,我做7年的layout,就没用添加过photoplot outline,你的问题,请贴出 ... 9 w! }% `& U! w# f. ]7 W' J
您好!报错文件如下:高手指点一下,谢谢
$ i5 n* {) b' v' I' W )
$ C9 S# y" \6 m5 i( Q1 }! m( ARTWORK LOG )( B4 [; W/ _$ T) O: K' o8 s
1 H" G5 K5 i$ ]& Z( Drawing : R.brd )# w/ W/ B e7 b t* E! j' b& r
( Software Version : unreleased )* o1 V3 | Z/ ]# v x/ x/ P" U
( Date/Time : Wed Sep 21 17:10:00 2011 )
3 B; D- Q! _7 E, p2 C( )0 a8 q [; N: B" j, E8 l
# }3 i2 {8 C# M$ O2 q/ R# j7 s8 r1 ]0 Z* L, O3 ?) D6 i! r
7 l& L+ M \- I# K- c. t
Z/ W/ X3 e2 k5 ~8 O
Results from parameter file ...
# Q( |) w- A, i+ l/ R& D7 @' C( u DEVICE-TYPE GERBER_RS274X' a g! y! D8 c$ a- Q
OUTPUT-UNITS MM
$ U' F. }& R9 J' I( _9 c6 ] FILM-SIZE 24000 160008 S" _* b% k* S6 B+ I0 `
FORMAT 5.3
& Y9 _; g2 w# z' m2 S ABORT-ON-ERROR NO' L% @/ t8 z2 K, X7 L
SCALE 1
; |7 |* e8 N9 g9 m% A S3 q SUPPRESS-LEAD-ZEROES YES$ X4 L$ N. X+ p* O
SUPPRESS-TRAIL-ZEROES NO
3 y1 J$ e1 R) \- o2 L6 W SUPPRESS-EQUAL YES
, P$ F1 e; P5 p2 Q3 [ UNDEF-APT-CONT NO
! y4 L# n* U. N" R4 w" L) R: Y3 f2 ~0 K1 H
WARNING: for raster artwork formats, artwork accuracy must be% f( G6 H: E: B& b
at least one place greater than the database accuracy, up4 k$ I+ P1 s: a1 B
to the maximum accuracy allowed by the selected output format.. |' N7 `2 k+ _. F3 S1 ?! v, R, o% n- z
6 K, C+ @% g. G! D# ~ Increase the accuracy by increasing the "Decimal Places" in8 B6 B0 |8 [) D8 F3 w
the FORMAT section of the artwork parameters and then rerun
) x$ K+ N8 I- _' h artwork.
f* P5 H" V0 g3 a5 D( } e, Y9 J- J% s$ Q$ C8 V0 |
The current output is rounding down the data. Failure to change/ p, K5 u: V- D ?% l) X
the format may result in inaccurate arc coordinates in the output
1 _6 O$ Z; u; _& b5 b5 x H0 \1 g files and possible shape/void plotting failures.
- O3 s) [! S+ K- E
% \1 \+ O0 p. ~ e1 I) i) Z* ?5 T/ ~* `, J
================================================================6 ]+ U" _6 z7 @* k6 _& t, z
PROCESSING FILM < TOP >- W3 J5 W _% L# a" h
TO FILE < C:/Documents and Settings/Administrator/桌面/TOP.art > ...0 e3 ]1 Z0 c/ t" _1 \ B# q
================================================================7 w' ?, t' ?8 I5 Y8 V; o
) ?8 y. Q% t3 c
FILM PARAMETERS :
: Y' T2 A& m8 X' p3 B% A. h ---------------------------------------------------------4 d; ]. i% _; V
Undefined line width 0.0000& \3 a+ \5 F: @. u
Mirror code NONE @- N8 |) q. r2 Q
Rotate angle NONE2 W- i* c( i+ y+ Q0 r
Offset x: 0.0000
: i( ~" B$ T% ]+ W+ R9 e Offset y: 0.0000
, _& @* \/ y. i5 s+ E) ~ Plot negative NO
1 R' F4 v5 T8 m5 c Suppress unconnected internal pads NO5 {3 K4 i# g7 o$ L7 x
3 E6 V# P: ^4 Z, h: J% [ WARNING: rectangle or unfilled shape composed 0 width line found at (0.0000 0.0000)
1 ^0 ~. Z3 ?) y# B2 ~ ... ignored!( w0 Z; x3 T- p3 \
5 _8 T# \9 [/ m2 @0 l WARNING: Shape at (-0.5020 11.2980) contains void at (-0.5020 11.2980)
8 V2 A6 @: J% R/ ~ which touches another shape.8 A7 A6 e0 [# a- L$ i
You need to manually resolve this problem.! Q; ]" F* O6 T' i7 i' d. g
$ B: Z* C3 ?2 \
ERROR: aborting film - artwork will not be generated!6 q6 E& Y# Q7 i$ t% k( u
Error in TOP--halting output. Artwork file not generated.
6 P- G5 r5 `: P. q$ L" Q6 e, B' T* O *** ERROR with TOP
1 \; G2 X$ h. _2 e8 h
5 i7 |- V. {2 I1 V: ]/ _5 s
; R. U5 g, \; W8 {1 ] X# f9 o- @( x* @7 {( }' w0 u) S# g/ l
6 ~) i8 N) _' C, q2 j------------------------------------------------------
/ @# C1 }. p4 p% c+ A- v SUMMARY:
# e, u S% e, X$ Y W- H5 A1 v *** ERROR with TOP! Q0 c+ b0 F& J* Q# |- W
+ ^. n$ _8 B' l8 X' b" b ARTWORK Error
9 D1 F+ M; h6 a! E; ?* V, O7 e1 O" n$ `6 w q. s
