查看: 2118|回复: 7
cadence 16.3 导入网表时出错
发表于 2011-9-27 19:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
$ O9 M; Z% s& r$ Z6 N' Z* ~0 F9 h4 K& A(        )
+ h. B/ v; [0 K  ](    Netrev allegro Import Logic                                      ), A7 ]8 J. R$ o! D
' C; Z4 M8 \" v% i(    Drawing          : DSP6713.brd                                   )
) Q0 A! \- K# E* E& K! O(    Software Version : 16.3p004                                      )
$ p( M  S+ N7 k: X3 W1 }(    Date/Time        : Tue Sep 27 19:31:12 2011                      )9 ~& N. A, z4 H/ A0 s" T
(        ), A  P, z# l: k0 s* [% {" C
(---------------------------------------------------------------------)3 W+ N- @' R% F8 e" K# C
9 S! N- @0 I3 k: [$ a& j
: i# X; E' ~9 Q1 w------ Directives ------
3 T& \  V2 F* J) b1 s
4 J: z6 U. o2 P4 @# HRIPUP_ETCH FALSE;
, y# Y3 K4 f2 z7 mRIPUP_SYMBOLS ALWAYS;
* y& s$ g% Y" nMissing symbol has error FALSE;
+ m. W) C' ]* r, x' rSCHEMATIC_DIRECTORY 'F:/SPB_Data/test';( w# g9 B" W) v9 P2 Q0 Y7 x
BOARD_DIRECTORY '';
! |9 a5 H3 v' m8 E1 i% K4 ZOLD_BOARD_NAME 'F:/SPB_Data/DSP/DSP pcb/DSP6713.brd';+ _( k& g- l0 Q. i2 O' r
NEW_BOARD_NAME 'F:/SPB_Data/DSP/DSP pcb/DSP6713.brd';0 b6 y( j) _1 t5 g; q6 a8 O
6 K5 Z. O8 f3 K0 r2 f! c( m
CmdLine: netrev -$ -i F:/SPB_Data/test -y 1 F:/SPB_Data/DSP/DSP pcb/#Taaaaaa03192.tmp
+ k, {1 m, b* M8 ?+ w  ?" k; G3 r& _$ S
------ Preparing to read pst files ------
0 Z# ~1 M) Z- {- j" V* ~/ C( s$ c9 d* j, S6 m
; q3 `  k5 b; k# m- a#1   ERROR(24) File not found
& P, t; U" {0 a: `     Packager files not found
+ V, M9 K1 m# ^% a1 T. T- E9 D1 a# i, I
#2   ERROR(102) Run stopped because errors were detected
! X3 [$ P2 s& r1 u& z' a$ N
# I8 h8 ^( E8 H  A+ Bnetrev run on Sep 27 19:31:12 2011: w% K. u$ }0 A! m; \. q
4 C: o  f5 L+ K3 k3 L
   COMPILE 'logic'# k: ]* q  }. C2 {
   CHECK_PIN_NAMES OFF% A' ?5 r# w* M- r- C: ~3 U
   CROSS_REFERENCE OFF
( k! `; Q9 O' D0 R* L3 K) N  X3 F   FEEDBACK OFF! H* j% a3 q1 q$ f4 z/ o
   INCREMENTAL OFF, C+ s( W3 M* A/ w; U
   INTERFACE_TYPE PHYSICAL
) k* c: i9 r4 H) i. I   MAX_ERRORS 500
$ d5 H# d! b# D/ w   MERGE_MINIMUM 5- W- @6 X1 m9 J2 V/ }
   NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'! \' ^2 O+ F# y/ h9 c% h. R
   NET_NAME_LENGTH 24. d" X7 H  }" P
   OVERSIGHTS ON
, z5 f5 S! i2 \  u   REPLACE_CHECK OFF/ q  j' K- G) j- y& o$ s
   SINGLE_NODE_NETS ON; s- B) z5 I5 S" i% h, L
   SPLIT_MINIMUM 0
4 ^7 T4 Y1 d# e/ H; y+ w7 w4 u   SUPPRESS   20; Z% S+ I3 T9 {6 c9 k! X
   WARNINGS ON7 z7 n# ?" h' i2 [# r4 a% h( _+ k
2 R- D2 U! s4 @  d2 d7 Q
  2 errors detected
4 O8 J' I/ v) k/ s No oversight detected& R- r4 J) _/ ^& p$ U& w
No warning detected2 P. j8 y8 ]! _0 n9 D
  c; |4 `' Q* x4 ~7 }% ~cpu time      0:01:35- ~/ k8 i9 e: b( r0 C, k# B7 _0 U
elapsed time  0:00:01  h5 F: I3 A- F# |
' H; T+ [2 U3 i
请高手帮忙解决下
发表于 2011-9-27 19:56 | 只看该作者
  H& X+ j/ J' G+ x     Packager files not found# D' F4 X& R2 s
应该是封装文件所在文件夹找不到了 可能是你把他的位置改变了
发表于 2011-9-27 19:58 | 只看该作者
把封装文件家进入就行了
 楼主| 发表于 2011-9-27 20:20 | 只看该作者
感谢各位的指点
发表于 2011-9-27 21:23 | 只看该作者
原理图里面有器件没有添加封装
发表于 2012-12-29 11:05 | 只看该作者
没有找到网络表;确保原理图生成了网表且更新的.brd文件正确;指定网表所在的文件夹;就OK把
发表于 2012-12-29 13:23 | 只看该作者
导入时 ,网络表文件没指定对吧
 楼主| 发表于 2012-12-31 13:59 | 只看该作者
这个问题是我当时刚学cadence时出现的,记得当时折腾了很久,后来发现当PCB文件放到我的原理图文件夹里面时,该问题就解决了,只要PCB文件不和原理图文件放一起,就出现这个问题!谢谢各位的支持,今后有时间会把我遇到的问题统一整理,供后者学习
GMT+8, 2025-8-21 09:41 , Processed in 0.125000 second(s), 23 queries , Gzip On.
