查看: 3215|回复: 18
导网表时出现封装找不到,但是库里有,好几天解决不了这个问题 ,万能的论坛救救我吧
发表于 2011-10-11 11:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
ERROR: Cannot find device file for 'CANTIGA_34_7'.- g0 \: k5 ^* c. W$ K) {" e" t( W
-------------------------------------------------------------------------------/ C4 n( j/ A+ @1 B% T1 P
BGA_ICH9_31MM_676_D! BGA_ICH9_31MM_676_D; U12) P$ R6 e$ I! F
                                         ^5 H+ y) T  V2 ]9 F# V; n
ERROR: Cannot find device file for 'BGA_ICH9_31MM_676_D'.
8 a% ?1 d: a; D* o; J+ l-------------------------------------------------------------------------------
( v& r. i' p" C- }SO8_50_150! SO8_50_150; U13
! s- k' V1 i8 n7 RDIP8_300! DIP8_300; U14
% M3 d  o: s% S+ ?4 C/ B& gTSSOP20_0D635! TSSOP20_0D635; U15
' j; s6 ^  ~! x4 R9 AQFPS48_0D5_1D6! QFPS48_0D5_1D6; U16
3 X4 j  X( V: @( y) nTSSOP64_0d5_6d1! TSSOP64_0d5_6d1; U18; |; v( s0 S  S2 z
QFPS48_0D5_1D6! QFPS48_0D5_1D6; U199 V8 t1 P) |7 `  p
TSSOP20_0D635! TSSOP20_0D635; U20
8 e3 `( d) P: t, d1 J+ T% K1 ~SO8_50_150! SO8_50_150; U22; p; U$ P0 v5 n- G$ B1 c: f5 }
dip12p_2d54_trans! dip12p_2d54_trans; U23
' r" Z/ e7 l7 F9 rSOT223! SOT223; U46
" R. i6 D" O: F  o$ H9 NQFN48P! QFN48P; U49
. I! y' _9 }( s- }# E) J4 DSO8_50_150! SO8_50_150; U5
8 q: N% B- j' j. eSO8_50_150! SO8_50_150; U6
) U1 J. V1 T! wSOT223! SOT223; U7
/ a! ]$ R' @) O4 b9 oSOIC8! SOIC8; U8
. t# ~. C3 Z4 {8 G: \% k, aQFP_128! QFP_128; U9
* a# f  H( q/ I" u4 D2 [: {$ B% SDB15M_VGA! DB15M_VGA; VGA4 }7 g( |; w% X3 q
SOT223! SOT223; VR16 T' \$ I( e8 h" _2 j( [
XD4_R! XD4_R; X1% Q* L, j/ G4 _- t0 b; x/ Z/ }
XD2! XD2; X33 C- [- J* Y" B  k
XD2! XD2; Y29 |+ l7 q: n7 U% p
$NETS0 g: r1 n+ ~! B; m
LAD2;  U12.L6 U9.25 R370.1
& Q2 _; z6 k- W/ v             ^7 G1 C7 R* K, O0 `5 S1 c/ f9 z( n
ERROR: Reference/function designator 'U12' not found, pin ignored.
# ?8 ^0 `% g. G, ?% H# a) v-------------------------------------------------------------------------------
/ R- w4 [- g% D9 y6 Z' XN83818660;  SATA4.6 C264.2( S/ i5 j7 ~+ h' x2 e4 w2 E4 r
MDI1+;  U16.5 U23.1 R546.1
4 Q6 d, T& D7 d  Z& B                          ^
$ r5 D* u! {$ ?3 @' |' TERROR: Reference/function designator 'R546' not found, pin ignored.1 g' \. w* z( h9 D# G
-------------------------------------------------------------------------------5 V6 ?/ L8 X8 Q$ i& ]
H_TEST;  R502.2 U1.C9
9 z3 X/ P- {( G3 L7 `MDA22;  U11.BB41 DDRIII_1.146
* k7 ^7 Y2 O4 {& w                ^
1 D3 @. c' ]" T- W& j$ HERROR: Reference/function designator 'U11' not found, pin ignored.! }' W- R5 ^9 |, O- k, u6 z% n, S
) J$ G* b: Z' a# Z4 s3 UTX0N;  U49.16 HDMI.9
; b+ ~! a* B2 d+ [, a9 O8 sN82628566;  U12.AE8 TP31.1
% f. H, u  e6 d                   ^& I! `5 }( j5 W$ ]- w
8 R5 r8 m  J4 x. q- n-------------------------------------------------------------------------------
+ o% s7 @. V* c, K7 I/ t8 i Tue Oct 11 11:14:18 2011                                Page    25
& |  m  u& n0 ^* K! w7 D( A" W7 f0 n
allegro NETLIST IN Log File
! H/ \% X+ V( }% n, P4 h===========================================================+ _( s2 ?4 H2 b+ Y/ ?
. {# m9 S; {6 H! i. wN83818908;  SATA2.6 C259.2
3 U8 e4 I) g& ?5 SMSDAT;  FB26.1 RN11.3 U9.66
# [7 T0 O$ @9 j, Y- K/ y4 gRX+;  U23.7 LAN_USB.L4 R546.2
: B/ ^7 _$ x$ B& ~! s$ a$ D                      ^3 n' g) ?5 u1 Z* R  {1 s
ERROR: Reference/function designator 'LAN_USB' not found, pin ignored.
0 w2 G" y7 k: }9 v. o-------------------------------------------------------------------------------
' f" _  J; e1 b( e# W  ~$ i                             ^
) I  {3 a( m5 T, ?* oERROR: Reference/function designator 'R546' not found, pin ignored.) t; E- m8 F1 Z0 ?
$ |+ r. O; ~0 q1 ~* d5 L& J  W9 J* T
还有一千多个这个的错误 说pin找不到,库里有封装而且跟原理图的名字是对应的。) k) e& F: L6 K
1 i( H  J, b  Q9 @) h另外我把封装重新建了一下也是同样的错误请求帮助!!!- }9 O& d* L; X
- F, o! [) E. F& g
发表于 2011-10-11 11:25 | 只看该作者
你确定footprint名字正确的?
发表于 2011-10-11 11:29 | 只看该作者
你有些pin没定义number吧
 楼主| 发表于 2011-10-11 11:31 | 只看该作者
piedgogo 发表于 2011-10-11 11:25
) n8 S; J* Y( R4 P1 ~3 B8 k  Q你确定footprint名字正确的?
- I1 ?3 ^+ P. D2 D( M- m) u+ g+ Q9 h4 X是正确的 我copy  pass了几次了    网表里名字我都对应过 是一样的7 t* b# e5 |! V% T: L4 w
这里网表里的
' Z4 l: m) H* t7 \1 x7 p
( Q* U2 D  H+ t* vCANTIGA_34_7! CANTIGA_34_7; U11
" Z# I) W! R9 s
" Q# I& B) T, t% V" yBGA_ICH9_31MM_676_D! BGA_ICH9_31MM_676_D; U127 b/ L% R) z1 }# X' R5 X( }
: F- y5 `. N; H3 E( O  t
. H" p% n2 C8 A' o. h6 p2 b+ U封装名这个 BGA_ICH9_31MM_676_D也一样的
( D! A# ]8 \1 T7 |- w8 x" D% V$ ^+ y8 E- h. U' G2 H: u
         这个  CANTIGA_34_7
发表于 2011-10-11 11:37 | 只看该作者
用的哪个版本,看看原理图里元件属性的device一栏,它提示的是找不到BGA_ICH9_31MM_676_D! BGA_ICH9_31MM_676_D,不是BGA_ICH9_31MM_676_D
 楼主| 发表于 2011-10-11 11:40 | 只看该作者
819535006 发表于 2011-10-11 11:29 * M/ z5 f# K, i& @! M3 E; C
你有些pin没定义number吧
2 y2 }" z- h1 c$ Y7 b9 n3 h
pin都有number 封装跟原理图都是COPY下来的  有一千多PIN没定义number应该是不可能吧
 楼主| 发表于 2011-10-11 11:45 | 只看该作者
piedgogo 发表于 2011-10-11 11:37 6 l1 \' L- X, w. y/ r
用的哪个版本,看看原理图里元件属性的device一栏,它提示的是找不到BGA_ICH9_31MM_676_D! BGA_ICH9_31MM_6 ...
" T! q7 u& V/ [4 m  X6 V! x
BGA_ICH9_31MM_676_D 名字是一样的
 楼主| 发表于 2011-10-11 11:46 | 只看该作者
yangmingen 发表于 2011-10-11 11:45 / h* \3 \. |" e' e% S2 w) r
/ a* [" u9 i% m% R3 c7 I9 Xallegro15.7
发表于 2011-10-11 11:47 | 只看该作者
或者找到devie文件随便折腾下,反正就这么几个地方
发表于 2011-10-11 11:50 | 只看该作者
我记得15.7会自动生成device名称还是怎么回事,忘记了。。。如果封装画的没问题,反正就这三点:footprint,device,命名错误。
真是高手 以后这种问题肯定可以解决了 就这三点说的没错!  发表于 2011-10-11 11:56
参与人数 1贡献 +2 收起 理由
yangmingen + 2 赞一个!
发表于 2011-10-12 09:39 | 只看该作者
线路上标的footprint要和封装命名一样,封装都要添加到psmpath。
 楼主| 发表于 2011-10-12 16:17 | 只看该作者
maomao123 发表于 2011-10-12 09:39
4 y" P3 z8 a/ t2 y线路上标的footprint要和封装命名一样,封装都要添加到psmpath。
% o$ y, G0 a7 y+ @2 v5 R
封装都有PSM , 名字那些都对过了  结果还是全部这种错误ERROR: Reference/function designator 'U11' not found, pin ignored
5 g' p. J. q5 T( i
0 l! t0 e" ^  ~: m都郁闷死了
    2021-11-3 15:21
  • 签到天数: 56 天
    [LV.5]常住居民I
    13#
    发表于 2011-10-12 16:30 | 只看该作者
    实在不行把资料发上来,大家一起看看是怎么回事。
    14#
    发表于 2013-2-26 23:31 | 只看该作者
    今天遇到了你这样的问题,本以为能在这里找到答案。但是。。。. l1 c0 V3 s8 w2 D# V  g: g
    嗨。。。折腾了半天,嘻嘻,解决了。
    % n. C2 \, F. S$ {方法是:到对应的封装里FILE/CREATE DEVICE就OK了
    * H" o- R7 u. P/ E我的就是这样解决的,遇到这样问题的筒子们可以试试
    15#
    发表于 2013-2-26 23:33 | 只看该作者
    yangmingen 发表于 2011-10-11 11:31
    / l5 [8 h8 I! K是正确的 我copy  pass了几次了    网表里名字我都对应过 是一样的5 ^% Q3 _, |' P9 X- o# n
    这里网表里的
    ; n) |- h6 f, M7 K$ j
    还缺少一个描述device的 .txt 的文件
    GMT+8, 2025-8-24 08:33 , Processed in 0.156250 second(s), 32 queries , Gzip On.
