查看: 1204|回复: 3
求助,此PADS转入ALLEGRO走线一根都没有了
发表于 2011-10-12 00:37 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Translating E:\WORK\TEST\1.asc.; ], M8 ^$ ^4 C2 |! r
Reading pads ASCII file header.
9 ^* f( Q( ~* L Version = PowerPCB5.0* C5 w3 j+ ?! Y" E
Route Layers = 4
  ]  e1 f- Y$ n! ~4 E: s1 _ Units = METRIC" u  k9 o3 `- p/ [. W- R# _6 Q) L
Hatch mode = Vertical / Horizontal
" P* @2 M0 o( X5 H Hatch grid = 2.000000, angle = 0.000000, anti-pad spacing = 0.000315# R  L1 O, R% z6 A
Initializing new database.1 F# Y9 }9 A; e4 G$ K
Creating layers.
& g( I+ I" b. J& d6 ~1 YReading PADS ASCII file body.
* e) N3 E, J6 Q/ I+ F *PARTTYPE*
3 E/ f$ n: }8 k1 R2 M5 H+ {5 i: j; F *MISC*
# J) l) P& G) P' C- |- q *MISC*: a' m1 v1 |4 G9 u
*MISC*
  C& L- ^! r2 p- ?9 Q9 i* B# r *MISC*3 R1 U, y* k  z9 r/ z: J8 K
*MISC*5 I0 S; \9 O( U
*REUSE*: _' l1 ]7 H4 {; C% q& _) s
*TEXT*2 ]; F/ i$ {6 a5 J: i1 @. d
*LINES*, V1 t7 U9 H# X( f! l
*VIA*: Y9 C" ]3 r' _! C& }
*PARTDECAL*1 @4 e* K  H1 R6 X
*PARTTYPE*
$ u1 M# @3 f+ |! p; P, W5 P *PART*( ]' |% d/ \- Z4 c* Z9 G7 u
*ROUTE*1 u. i. l8 d: E; W* m1 g
Writing routes.
6 o  N: D% O0 ~) E  e; Q6 g *END*0 Q! \6 Y9 j' c2 z1 }9 \' k
, w. e" d; ], U4 m/ ?  y2 a/ K===============================================================================
1 z8 \) g3 X2 s1 i& N9 ~1 @ PADS layer usage summary:
. s" @  I, Z  Q8 k" ?  s+ l  Layers 1 to 4 are route layers.- u4 k6 t& q" l5 k
  LINES:" E% A$ T% ~5 \0 Q
     0 BOARD GEOMETRY - ALL
6 D( ^5 U/ z/ K1 O/ h     1           ETCH - TOP
% x3 |" A0 n" `8 w     3           ETCH - INTERNAL2- H9 ]5 J) o( y# Y
     4           ETCH - BOTTOM
/ Z4 l- r* t: [- z+ l3 O$ [- u     9  * Not mapped!# j* O+ G  M, g( i  G8 E/ F4 s
    10  * Not mapped!* S% T) k5 D: P7 `0 v. v
  COPPER:# V( U; R/ E/ w: r9 g) R
  TEXT:; _* B" g9 j! E
     1           ETCH - TOP) N3 a# N. C* f* v0 i+ H; E7 S
    26  * Not mapped!: c8 \( i; g& ]) A0 D6 @6 G
  DECALS:
" w3 d; b( M) N$ |4 M1 g* U( {. s5 z: Q     0 PACKAGE GEOMETRY - SILKSCREEN_TOP: x/ B# M. N# L2 q1 }) F
     1 PACKAGE GEOMETRY - SILKSCREEN_TOP
% a# p8 A/ F! F% ^: Q4 v    12  * Not mapped!
% D5 h1 K  @6 Q0 |0 j3 q4 x0 U    19  * Not mapped!
+ A* V8 ]4 f% V' A$ ^/ [! t7 j+ @+ v    26  * Not mapped!2 ^, |0 P0 x. U4 }
  PADS:
0 n$ U' u8 N, N7 j. _5 J) v  R     0           ETCH - internal_pad_def
; H$ ]8 R& {. ?. e, @3 I. g: ~     1           ETCH - TOP; i3 q* g& W1 D7 Q* [% u
     2           ETCH - INTERNAL13 Q; b4 X) e' l; b; K' W3 U
     3           ETCH - INTERNAL22 N1 |/ G; q+ X2 l' R" a
     4           ETCH - BOTTOM
/ h/ B' F4 I4 l0 W6 e- Q+ G& r' g  Z1 E     6  * Not mapped!
# L0 O3 @' O" n2 t! w/ t: H    15  * Not mapped!# [5 h+ G5 O5 d( g# j) R$ q
    16  * Not mapped!; X3 [/ U- I' q5 W
    23  * Not mapped!
& i* C9 M. O# h  [  VIAS:
/ W" K. _5 G# P5 [     0      VIA CLASS - internal_pad_def$ B" b4 r$ K7 c3 q+ I8 x( d
     1      VIA CLASS - TOP
' I7 J$ c' v- D' C! I     2      VIA CLASS - INTERNAL1
* Q& A; }/ l* W4 i! }     3      VIA CLASS - INTERNAL2
5 P* C7 l( K  f. ^& w, v     4      VIA CLASS - BOTTOM! v) u# @! |2 f5 l$ H( n; u
9 G6 V9 f0 S6 q6 O# R" }2 F7 b# S
WARNING: 63 data objects mapped to the UNUSED class were ignored.( U8 r" O( ~# {9 b2 P
===============================================================================( A. }- I) F! K) y2 f1 q5 A2 p
" y% d$ F& g: tCreating E:\WORK\TEST\1.brd.
; w, \! }+ Y5 V6 Q6 `Loading netlist:
/ L& }: X5 w7 o* [4 u: [E:\WORK\TEST\1.TXT1 `3 o; T; p$ u% a/ P2 d
Writing database.
+ o# j$ v3 f& ]ERROR: Error while writing the allegro database.
3 q# a9 A$ u9 c& j6 MClosing database.
7 I  t2 _3 Y8 n7 M2 \& ZTranslation complete.2 i: K( p8 @! C* m- N" ?+ D) Q
Finished with errors!
4 @/ P) b( z  _$ r7 G% j
发表于 2011-10-12 09:06 | 只看该作者
这个问题说明你的在导出的时候选择有些问题,在导出的时候这是非常关键的一步骤!
 楼主| 发表于 2011-10-13 13:07 | 只看该作者
兄弟别的板子我随便都导成功,只有这个板怪得很
    2023-10-12 15:00
  • 签到天数: 4 天
    [LV.2]偶尔看看I
    发表于 2011-10-13 13:23 | 只看该作者
    这个接口做得一般,,
    % D" B9 r+ F% d% G
    & @- S; d/ \' G; b9 {. |% Q+ B' n所以有问题很正常
    GMT+8, 2025-7-22 18:36 , Processed in 0.125000 second(s), 24 queries , Gzip On.
