查看: 317|回复: 3
[仿真讨论] 这是HSPICE中EDIT LL中的lis.......我awaves老出现no data in design
发表于 2022-5-27 11:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Init: read install configuration file: C:\synopsys\Hspice2005.03\meta.cfg
" J' K( Q2 m1 u****** HSPICE W-2005.03 (20050128) 14:21:42 05/19/2011 pcnt: U( h' [: T) F( @: C
Copyright (C) 2005 Synopsys, Inc. All Rights Reserved.0 }: n: `2 _: i1 j8 z5 U# c+ G& B
Unpublished-rights reserved under US copyright laws.
1 I7 i3 C5 a" F9 Q' X) J6 CThis program is protected by law and is subject to the- X. P5 z9 ~; S
terms and conditions of the license agreement found in:
7 y2 p2 c- F+ JC:\synopsys\Hspice2005.03\license.txt5 E0 N4 U. u" d+ {5 O+ a5 d
Use of this program is your acceptance to be bound by this
0 W8 O) b0 A, |: U, x& C/ ?' Jlicense agreement. HSPICE is the trademark of Synopsys, Inc.
* @- u! f& l. |  s6 D- |Input File: c:\av.sp
& w# _' Q1 i$ t( z/ S  [lic:- s/ L# U- s0 G6 S3 n
lic: FLEXlm: v8.4b
' i. g& `; ?* S3 @9 _  m4 m2 N5 Plic: USER: Administrator HOSTNAME: www-38163aea6a01 \/ w5 z  {1 L. z% i6 h+ r9 n; ^% k5 q
lic: HOSTID: 000c29937566 PID: 1132
/ Z# _$ e% T! C# jlic: Using FLEXlm license file:
6 Q- V5 q. S. h: j' D4 K7 L0 [2 slic: C:\synopsys\Hspice2005.03\license.dat* E* `( ?$ b2 o* B: C' G2 P1 M
lic: Checkout hspicewin; Encryption code: DCFE951F005EC01439B71 k; y1 }7 g2 k  n% d2 ^
lic: Notice: NOT TO BE SOLD
) L* L! C/ x! H, Wlic: License/Maintenance for hspicewin will expire on 31-dec-2050/2005.3
& a+ B6 w. d. u" i) E' P* D& `lic: NODE LOCKED DEMO license on host 000c29937566  h! r5 \4 n3 a& Z$ @
lic:  m+ u4 e7 l: u1 n
% O8 }6 h' |( P. i# GInit: hspice initialization file: C:\synopsys\Hspice2005.03\hspice.ini2 [. @5 h: @3 ?2 F% Y; x- c
* hspice.ini
5 F% L" X1 }7 C  M6 k* o. t*
- k" X( e0 w  z( _  Q' N. O* use ascii only for initial pc hspice release: {; [1 Y3 t/ O( ^( c7 p+ D
发表于 2022-5-27 13:15 | 只看该作者
你看看EDIT LL最后有没有ERROR出现,看看是不是aborted?% Q' v, {; t+ z; O. s! N0 ~" l6 A
另外再去看看你那个放置仿真文件的文件夹里有没有.tr0(这是瞬态仿真后出现的文件)或是.ac0(交流分析出来的文件),我估计是没有,因为如果有,就不会出现no data的提示。8 v- n. }, e& w
发表于 2022-5-27 14:46 | 只看该作者
你发的这些看不出是否记录了波形.1 d. N0 u' b9 E% p; W5 N
在OPTION命令里加POST1 e' S- B5 s5 h# v
发表于 2022-5-27 14:55 | 只看该作者
楼上说的很不错1 d( e7 u% ]" z. m5 y
GMT+8, 2025-11-4 01:50 , Processed in 0.140625 second(s), 23 queries , Gzip On.
