You can import netlist data from the following file types:
* V$ ^7 ~ }# ^: M. \Allegro PCB Editor Third-Party Netlist File - a netlist imported from a third-party tool using the netin command " u! ?6 x- |0 K4 O- n
Allegro PCB Editor Net List Report File - a netlist created by running the Allegro PCB Editor Net List report on an Allegro PCB Editor board
" P& M+ U7 O VAllegro PCB Editor Net View Extract File - a netlist created using the Allegro PCB Editor extracta command - Q: K4 P3 v% |2 C- S6 B
Mentor Nets File - a netlist and component list in Mentor format " V/ v5 x- }: W" \- [/ P
Mentor Neutral File - a Mentor file in ASCII format that provides information about nets, geometry, pins, board locations, drill holes, pads, and testpoints8 H4 D; d% s0 l/ q, p
To maintain the data in XML format, you can save the netlist files in the Design Compare window. |
