请教各位老大,现在我有个PCB是在原来板子的基础上改的,原来allegro可能用的低版本,我现在用16.2,想新加尺寸标注,结果发现原来的标注不能删除,我尝试下新加尺寸再删除可以啊,后来看了下属性,显示Item 1 < VERTICAL LINE SEGMENT > # U5 S: j% V: [+ X; V& K: D! J4 z
class BOARD GEOMETRY% |2 M3 o, }% i$ U
subclass DIMENSION3 P" s. V$ t# f2 o; \" L
Segment length: 3542.32 MIL
6 C; Y6 q, m7 L- T7 x2 R; h segment:xy (224.80 4407.68) xy (224.80 7950.00) width (0.00) font (Solid)
/ F! j; a" e4 W! d- w, `$ _ Inherited properties attached to line4 K4 S) Y- l% B1 b8 ^5 B8 Y
Symbol: LINEAR_DIMENSION at 224.80, 4307.68 FIXED 是fixed,然后发现有unfix选项但不能unfix,很困惑啊,求高手指导!# F V" i& G6 q8 V2 J
