小弟初学cadence,原理图制作好了,生成了网表之后,又制作了PCB封装,导入网表的时候却出错了,如下所示:
( w; k0 l8 W# o' G/ Y(---------------------------------------------------------------------)8 ?; N9 y6 W$ n+ F
( )% q% G. C6 U2 e
( Netrev allegro Import Logic )
$ H( F- Y/ o; U5 b( )2 q3 ]) V* g% h. D" Y8 f
( Drawing : 10G.brd )" J: t7 J/ C! b* u; Q7 x# x
( Software Version : 16.3p004 )! |/ F$ I% I, N; K5 v% |+ b
( Date/Time : Tue Jan 03 13:32:03 2012 )) O/ T! d" c9 {6 ^& X/ ~% O
1 v1 V+ c1 r) h1 e; r8 }6 X3 D(---------------------------------------------------------------------)
w7 t1 l9 ]' y7 }" }+ L5 ^6 N) P1 X! X) n2 o
3 |! p; D3 g! @) X2 s( t
------ Directives ------
; p% u( \+ Y, x( u% Y+ v* @! Z! p4 Z/ t: z
RIPUP_ETCH FALSE;/ e: G. F( e6 g1 w% f+ p) u
RIPUP_SYMBOLS ALWAYS;2 L5 i; u ^! H- M
Missing symbol has error FALSE;
+ c6 y0 W% Z- m* A) h: KSCHEMATIC_DIRECTORY 'F:/公用盘/电路原理图-20120102';
& [, L2 c7 S L8 x; m' ZBOARD_DIRECTORY '';/ M5 M4 [; i9 D$ H7 ~
OLD_BOARD_NAME 'F:/公用盘/封装库/10G.brd';
1 i* X0 C8 a" e$ f& JNEW_BOARD_NAME 'F:/公用盘/封装库/10G.brd';! I [6 X" w/ w, v, j6 j
5 `9 Q& M! ]" f( \( J
CmdLine: netrev -$ -i F:/公用盘/电路原理图-20120102 -y 1 F:/公用盘/封装库/#Taaaaaa00560.tmp; l% L4 T, o* r8 |) `; H
7 a# }: \8 h* r% B1 U, ]. I' y------ Preparing to read pst files ------
1 l) ?4 F3 X4 z1 e' C. X) N7 D" [5 H; O5 x
; ^8 ~+ |% G% o* I6 s
#1 ERROR(24) File not found
% G' Q- A# i4 N Packager files not found5 L$ j' ?" e; |. M
. z9 n- h9 o0 T( ~. j
#2 ERROR(102) Run stopped because errors were detected
4 k: @$ a- _0 R6 Z
3 T6 D1 d" Z& j% n6 \6 }netrev run on Jan 3 13:32:03 20122 U) D* }( }+ C
2 R3 I! y y' i1 H
COMPILE 'logic'
% B$ B# c9 V k, E7 s" N CHECK_PIN_NAMES OFF
% R6 q; O0 Z [3 G CROSS_REFERENCE OFF3 a/ G2 U9 W, L* y/ d+ t1 }
FEEDBACK OFF5 ]- p, f0 L: R5 W0 P7 z5 ?) v
INCREMENTAL OFF
8 F2 J. f7 {5 S3 j2 B2 a' @3 N6 V INTERFACE_TYPE PHYSICAL
1 {$ ~: F$ z/ a& D1 {8 t* t9 R- h MAX_ERRORS 500
6 [1 g6 L, v$ R: h$ n MERGE_MINIMUM 5
+ O1 \3 _% |! e/ w n, ]5 c5 A0 X NET_NAME_CHARS '#%&()*+-./:=>?@[]^_`|'7 v' K4 P2 T% n
NET_NAME_LENGTH 246 l' o7 }) w6 J6 m: t6 w; @4 t
OVERSIGHTS ON
* W* i# `* p" t, c' [" t5 u; ^ REPLACE_CHECK OFF0 b0 F/ c5 p* ?( g1 C' X
SINGLE_NODE_NETS ON* [0 k- ]' ?% n5 m
SPLIT_MINIMUM 09 N* t' n" I5 v! y0 j; T6 {
SUPPRESS 20- q' ~0 d. O* e! I
WARNINGS ON8 U/ e+ }* z* R6 q( S9 N0 w
/ ^) q' n3 K# H/ [4 X* ^
2 errors detected
3 t1 P0 l4 N+ S5 v2 e# Z+ E4 Y* { No oversight detected
3 K+ Y/ N* ?* x. C No warning detected% X. {) X- ~2 D0 w. H! \* O
- n/ s P/ ^$ V7 ]
cpu time 0:00:407 ?" h: Q, M# _. S" y
elapsed time 0:00:00
1 ~0 ^6 D5 u; s2 J不知道什么原因,修改了一下封装库的路径什么的也没用。请各位大侠指教一下啊,感激不尽啊! |
