RT:下面是DRC的描述~求高手指教!8 s4 O- g& t( Y" D- E
6 u5 C' E, q1 u2 P! ]LISTING: 1 element(s)
$ D# [6 ]# l( D! ^7 n. K4 K J% S. B4 R8 N
< DRC ERROR > 8 u- O5 y" T0 }# J8 L
8 O! L9 _; u+ d0 c# l
Class: DRC ERROR CLASS
! ?0 T( Q/ w, T3 d Subclass: PACKAGE_TOP
, u6 J9 ~' ? B6 ], _3 C Origin xy: (-27.500 -2.500)) V/ u4 Y9 h- z$ A( G% ~$ K
Constraint: Package to Package Spacing' f6 w) r( ` G* |
Constraint Set: 8 c. v3 B; s4 p. Q' v
Constraint Type: " W$ f* S2 p, U1 `
9 S. c" D2 }1 } Constraint value: / S3 z Y. B. k
Actual value: 3.81 MM
+ v* k8 E7 [: e9 v0 I h
& E3 I; m5 A' A3 G+ V3 U1 P$ } - - - - - - - - - - - - - - - - - - - -
5 u6 [; W/ n" A; { Element type: FILLED RECTANGLE/ c" T. m$ r n, u6 \" f/ W w
Class: COMPONENT GEOMETRY: N* O" G [6 d8 e. w& c
Subclass: PLACE_BOUND_TOP2 }) }8 I6 M+ ?) g( `3 `2 L
0 r0 f) B1 A" T4 N8 m) c Z( U5 q RefDes: U9
2 \. h6 A/ v9 a. k3 T xy-lower xy-upper g, R* ]4 ]; i1 p6 m
Rectangle Top: (-27.500 -2.500) (-17.500 -2.500)
- }. p6 {6 n+ F9 [) B- p1 ?* c' J2 A& u Rectangle Bottom: (-27.500 -14.000) (-17.500 -14.000)
9 O' R+ R" C+ {" ~4 W
* p- y/ l* i, c3 o Height: 11.500 millimeters
8 T# W: s T! J8 p$ T y, B8 l Width: 10.000 millimeters) u2 G- D! L( |4 _+ b
Area: 1.1500 (sq cm)
0 d3 a2 {5 F2 ~4 G! p: [
* Q1 ~( r4 O* i5 ] p) N" b1 Z1 B% D4 B1 Y
- - - - - - - - - - - - - - - - - - - -; x- U% @& p# f' o
Element type: FILLED RECTANGLE$ g3 s/ M/ ?# `
4 n# g; ~1 \9 \6 U+ C/ t. J' l Subclass: PLACE_BOUND_TOP& S0 a4 s8 ~# i9 @
) V" \, l- _0 j/ N( | t1 r; {% ]9 `; U6 T
RefDes: U17" y- M$ W- n. w: n) W( L& h
xy-lower xy-upper/ u# W# ?, u" d1 \9 L3 P( n
Rectangle Top: (-27.500 -2.500) (-2.500 -2.500)
) o# T' ~9 @+ i# v Rectangle Bottom: (-27.500 -27.500) (-2.500 -27.500)
4 O- Y) ?( l; M: m0 t7 a& Z: A
Height: 25.000 millimeters
5 x4 ?- {; @" l4 R Width: 25.000 millimeters; T3 [) T* k- ^; [
Area: 6.2500 (sq cm)" T- x6 u9 [, {; c+ v
, P: F/ c& r* D$ ]
/ D$ U( F1 M, t& c6 M& I6 ?( U7 v- y - - - - - - - - - - - - - - - - - - - -
+ A2 T3 q! a4 ~6 v( ]! {% G/ G4 \ |
